Help with x-arcade Joystick replacement please.
ald3n3
I have been searching for a while now everywhere on what is the best way to changed the Joystick on my x-arcade tankstick. All I want is a ball top joystick. Then I found this website...
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=381
This seem like an easy way to get a ball top joystick. No need to change anything else, just the shaft. Or am I not understanding something? Does it work if I do that?
But if you guys have any Joystick suggestions that does not require any major modding the x-arcade. Please let me know guys. Thanks!
I read the description looks like u just remove the shaft from the xarcade joystick and that one replaces it.
if u go ahead with it please post back and let use know how it worked. I would be interested also in a ball top for my xarcade.
My Cab.. 1-UP ARCADE
new hyperspin irc details.. come hang out!
Sure thing! I've talked to the shop owner and he said indeed it is just a simple shaft replacement. But I got in contact with another shop and offered me this... http://www.paradisearcadeshop.com/en/58-il-eurostick-joystick He said it shouldn't be too much modding if I replace the whole Joystick with that. I'm still debating. I'll get it sometime this week. I'll post pics and instructions after I install, whichever one I go with.
Hi! I finally received the shaft yesterday. The ball top looks awesome! and the shaft fits perfectly. Also, I ordered the SST microswitch for it. They're really soft microswitches but I can't really tell the difference when used for the joystick. But they are great switches for the buttons. It's supersoft and light, it makes the x-arcade built in cherry switch look like crap =).
Here are the links, just in case you want to get them. If you do get the microswitches for your joystick make sure you specify on your comment, during checkout, that you want it with levers.
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=381
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=92&products_id=346
