skurdt Posted July 14, 2013 Posted July 14, 2013 Following the integration of HyperLaunch in 3DArcade, though it's not necessarily related, I made a program that will convert an existing HyperSpin main menu wheel into a 3DArcade Selection Set entry. With it you can, but are not limited to: - Have a standalone 3DArcade setup that uses the exact same structure/roms/medias as the existing HS setup. - Integrate 3DArcade as a HS wheel entry and enjoy the 3D part of it, with the above advantages. Here's a video of the process: (the available/current version has a GUI, an "infinite" progress bar and options to select default arcades and skins.) - "@\Databases\Main Menu\Main Menu.xml" is converted to a "HyperSpin" Selection Set entry for 3DArcade. - Each system has an emulator configuration created that's set for HyperLaunch. - Every systems are added to a gamelist selection set with the selected default arcade and skin associated - All* xml dbs from inside each system folders are converted to atf game lists. *for MAME it will only convert the full list, aka. "@\Databases\MAME\MAME.xml". The first time it runs, it will take a little while to convert all databases, especially if there are a lot of them and also if they have a lot of games within them. Important notes: - An already set up 3DArcade installation will remain intact, with only the "HyperSpin" Selection Set added. - It will never overwrite existing lists. To update an existing one, the file has to be deleted manually. - The same for emulators, it will be created only if it's not already present. - The HyperSpin menu (3DArcade side) will always be rewritten so any system that is removed or added from the HS installation will be reflected. *! It also means that any custom arcade, skin, GS 3D model, etc... associations will be lost. - By default, the HyperLaunch folder is set inside the 3DArcade folder. If you plan to use an existing HL setup inside an other folder (for example HS), you'll have to change the path in the relevant 3DArcade emulator configurations. - HyperLaunchHQ will only work with a single frontend. Using both HS and 3DArcade as standalone will require 2 separate HL/HQ setup. (Though they can use the same medias and such with the correct paths set up) http://skurdt.webs.com/softwares.htm Cheers My 3D Arcade pages: Website, Videos, Files, HD skin gallery.
Tristeele Posted July 14, 2013 Posted July 14, 2013 Don't know that I would ever use this but that part at the end looked pretty cool walking through the arcade. Thanks for sharing!
skurdt Posted July 18, 2013 Author Posted July 18, 2013 Updated with the ability to choose the HyperLaunch folder (for an existing setup) and optionally configure the HLHQ 3DArcade plugin (for standalone use). My 3D Arcade pages: Website, Videos, Files, HD skin gallery.
