Hyperspin won't go past the emulator selection wheel
A1117
I've been installing Genesis/Mega Drive and NES emulaltors using retroarch, but when I select either console on the wheel it just bounces me back to the wheel. It doesn't go to the game selection. I did the same process I did for MAMe, which is working perfectly.
What is the problem? I'm fairly new to Hyperspin so any help is appreciated.
Check to make sure your ROM extensions are properly defined in HyperHQ. If that's correct, check your ROM path.
This usually happens when HS can't locate your ROMs, or match them against the DB for that system.
That worked! I had multiple extensions and it didn't like that. Changed it to just 7z and now I can get to the game level. Now I just need RetroArch to work.
