windowlicker11 Posted November 7, 2013 Posted November 7, 2013 I had this problem a long time ago when I first set up Hyperspin. If I recall correctly it was a problem with the desktop window manager service. Try disabling the service to see if that is the cause.
monkeychunkuk Posted November 7, 2013 Author Posted November 7, 2013 I had this problem a long time ago when I first set up Hyperspin. If I recall correctly it was a problem with the desktop window manager service. Try disabling the service to see if that is the cause. Ohh I'll give that a go cheers The longer the games running the longer it takes 10min game play =28 secs to menu 20min game play =59 secs to menu
monkeychunkuk Posted November 7, 2013 Author Posted November 7, 2013 I had this problem a long time ago when I first set up Hyperspin. If I recall correctly it was a problem with the desktop window manager service. Try disabling the service to see if that is the cause. Which service? Lots are running?
monkeychunkuk Posted November 7, 2013 Author Posted November 7, 2013 Thanks for the advice I went to this site and followed the instructions to turn a few things off in the background I think the main thing was the wifi program Here is the site http://www.sevenforums.com/tutorials/2495-services-start-disable.html And as you can see it's now exiting how it should,funny it only did it on this machine??? http://www.youtube.com/watch?v=6UcivloOyzQ BIG thank you for thinking outside the box this place is so good for help on all levels ! Steve P.s now to disable the mouse and put the cp back in place
monkeychunkuk Posted November 7, 2013 Author Posted November 7, 2013 Thank windowlicker11 forgot to mention you in the post
monkeychunkuk Posted July 11, 2014 Author Posted July 11, 2014 Hmm this problem turned up again so I adjusted the Hdd power settings Sent from the smut hut
