LedBlinky Mame Genre wheels issues
I have created wheels for Favorite games and other genres for Mame and used Don's List Generator. When I open Mame wheel LedBlinky works correctly but when I open a Wheel i created for Favorites or other genres from Mame, LedBlinky lights all buttons and says button 1, button 2 and so on. trying to figure out what is wrong because LedBlinky is pointed to my emulator\mame folder for info that all wheels use. the only thing i see different is my database name is called favorites.xml instead of mame.xml in database folder. any help would be great or if this setup is possible.
Thanks arzoo
Hi Brian,
What's happening is HS is passing 'Favorites' to LEDBlinky as the emulator but if you can included 'mame' in the name of the favorites ring, then it should work. So for example, the name could be 'Favorites-mame'. As long as 'mame' is included somewhere in the emulator name then LEDBlinky will consider it to be a variation of mame.
arzoo
