Freesnyder Posted August 4, 2013 Posted August 4, 2013 Hi Everybody, I just built my first hyperpin cab. It worked very good until yesterday. I don't know why but when I start a Visual Pinball table through hyperpin the DMD window is located underneath the actual pinball window. I can get the DMD Window to the foreground with Alt/Tab but then the Table Window is inactive and won't respond to any keypresses. Running the Tables directly in VP is no Problem. Everything is in the right order. Maybe somebody came across this strange Problem and knows a solution. Thanks for all suggestions
newer Posted August 4, 2013 Posted August 4, 2013 Where are you Located in Germany.... Greetings from Stuttgart
Freesnyder Posted August 4, 2013 Author Posted August 4, 2013 Hi, I'm from Munich. Greetings to Stuttgart I forgot to mention that i'm playing on a single Monitor cab. That's why it is so much of a Problem that the DMD window is underneath the table window.
