Generate a new .XML database with subfolders, is it possible?
sic
Hi!
I am trying to setup "Commodore Amiga Demos", but all roms I have are inside different demogroup subfolders.
Example: Fairlight\Fairlight-1989Progress.zip
VirtualDreams\VirtualDreams-40kIntro.zip
Rebels\REBELS-64_Demo1990.zip
Scoopex\scx-800Degrees.zip
Is it possible to generate a .xml database with that file structure? If that is the case, what application to use?
//Sic
Edit: There are 2478 subfolders in the main folder
I´d did go another way to solve the problem. First I checked the demobase.xml file which gives winuae the path and the config for every demo file, then used regex find&replace function to remove all the groupname folders in demobase.xml. So after that I had a config for winuae with filepaths pointing to the files instead of groupname folders. After that I moved all files out of their folders into a main rom folder, then I created a new database with Dir2XML.
That´s my solution to the problem, maybe not the best but worked for me.
  • 1 year later...
Hm dont think I have the files anymore since I use the WHDload demopack now. I will check when I get home if there is a backup the demobase files.
You can also find the WHDload versions of Commodore Amiga Demos in my signature =) Only 609 of them though.
Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc
http://grandis.nu/software
Tur-Matcher - Match your roms/media/XML files.
Another Idle Volume Adjuster - Automatically control the volume.
How to: Use MAME Extras as material for HyperPause
How to: Use eXoDOS 2.0 as material for HyperPause
