.net framework
mattyb425
im trying to get rocket launcer up and running on my cabinet.  it currently doesnt have access to the web, so im forced to setup all the files on my laptop and transfer to the cab via thumb drive.  everything workls on the laptop, but once i put it on the cab computer and try to run rockletlauncerui, i get an error massge saying "to run this application, you must first install one of the following versions of the .net framework: v4.0  contact your application publisher for instructions about obtainig the appropraite version of the .net framework"  I'm not going to protend to be an expert so I'm hoping someone on here might be able to help
You can try using the standalone installer here. I can't say whether it will definitely work or not because I always use the web installer, but that obviously isn't an option in your situation.
thanks, that worked great!!!  now I can work on the next problem lol
