launch_14 Posted September 5, 2013 Posted September 5, 2013 Hello pinball fans! I like to join your fantastic club of "happy pinball cab owners" Before starting the woodwork I am looking for the last piece of information... I learned that a "samsung UE46F6000" will be a good choice for the 46" playfield 1) Do you know if the bezel is different between UE46F6470 and UE46F6170???? At "amazon[dot]de" it looks different than at "samsung[dot]de". Is this true? Or is it only the plastic-case ??? Or is the "inner" display the same measurement at all samsung 6xxx ????? --> Maybe one type fits better into the cab without decasing... (and there is no hardware dealer around...) 2) And the dimensions of a widebody lockdown bar is 24,750.0 inches (=62,865cm) , isn´t it? Is there a little bit of tolerance in building my wood cab? E.g. can I build it 0,2inch more or less???? The problem I am facing: Maybe I can put the monitor in the cab without decasing it... but the lockdown bar has to fit in the end (and the lockdown bar still needs to be bought from US :-)) So it is like "Egg or henn"... Thank your for helping, regards from Europe, Andi P.S. Better than christmas: Looks, like kickstarter and pro-pinball had done it... okay it´s no "visual pinball", but I would love it on my cab, too :-)))
launch_14 Posted October 8, 2013 Author Posted October 8, 2013 For whom it may concern: 1) The (plastic-frame-work) bezel IS different! Roughly you can say: More expensive displays have a thinner plasic-frame (I am only talking of the samsung UE46F6xxx). The first numbers are "cheaper", e.g. UE46F6170 (=more plasic frame bezel) and the higher numbers are more expensive, e.g. samsung UE46F6500 (=less platic bezel)... But I think that ALL the samsung UE46F6xxx have the same dimensions, when unmounted!!! 2) Now I have got a real Gottlieb Mars of War pinball. This is an EXTREME widebody pinball... The wooden frame is 65,2 cm wide. The downlock bar is 65,8 cm wide (outdside!). On the innerside of the downlock bar you have some tolerance of.... let´s say 2mm each side. (In germany you would say: "2mm Luft"). Regards, Andi
