excaliburlives Posted March 23, 2009 Posted March 23, 2009 I'm running project64 1.7 and it plays the games fine when i run it outside of hyperspin. When i use hyperspin the game loads and i can hear audio but the screen is black. I can't figure it out. Here are my settings for Hyperspin [exe info] path=C:\Hyperspin\Emulators\Project64\ rompath=C:\Hyperspin\Emulators\Project64\roms\ userompath = true exe=Project64.exe romextension=zip parameters = searchsubfolders=false pcgame=false winstate = HIDDEN hyperlaunch=true [themes] themes_only = false animate_out_default = false [wheel] alpha = .15 style = normal speed = high vert_wheel_position = right text_with_images = true text_width = 700 text_font = Style2 small_text_width = 260 large_text_width = 400 text_stroke_size = 8 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio = 100 shadow_distance = 0 shadow_angle = 45 Hyperspin log 02:32:26 PM | HyperSpin Started 02:32:26 PM | Startup Program Unvavailable 02:32:26 PM | Menu mode is multi 02:32:26 PM | Menu.xml found 02:32:26 PM | Entering fullscreen mode 02:32:26 PM | Setting resolution to 800x600 refreshrate is 0 02:32:26 PM | Main Menu.xml loaded 02:32:26 PM | Loading wheel images 02:32:27 PM | Entering Menu 02:34:06 PM | Menu.xml found 02:34:06 PM | Nintendo 64.xml loaded 02:34:06 PM | Loading wheel images 02:34:06 PM | Entering Menu 02:34:11 PM | Pausing Animations 02:34:11 PM | Running HyperLaunch.exe 02:34:12 PM | Command Line is: HyperLaunch.exe "Nintendo 64" "007 - GoldenEye (USA)" 02:34:36 PM | Menu.xml found 02:34:36 PM | Main Menu.xml loaded 02:34:37 PM | Loading wheel images 02:34:37 PM | Entering Menu 02:34:40 PM | Exiting HyperSpin 02:34:40 PM | Quiting program 02:34:40 PM | Exit Program Unvavailable 02:34:40 PM | Bye! and ther error i get from project64 log 2009/03/23 14:52:52.312 03312: Error : Exception caught File: D:\My Programs\home\Project64\project 64 1.7\Source\N64 System\N64 Class.cpp Line: 324 I have no D:\, that is my dvd drive. Does anyone know what this means?
excaliburlives Posted March 24, 2009 Author Posted March 24, 2009 Problem solved. Please delete this post.
sp3ctr3 Posted August 16, 2009 Posted August 16, 2009 im having the exact same problem. How did you solve it?
sp3ctr3 Posted August 16, 2009 Posted August 16, 2009 fixed it had to tell the emulator to go full screen on rom load and set use Hyperlaunch to true
Venoxy Posted August 17, 2009 Posted August 17, 2009 i have the same problem just with nulldc. altough i have set full screen and hyperlaunch and the problem is there still. Fixed by changing hyperspin to api instead of direct draw
jackcondon Posted March 7, 2010 Posted March 7, 2010 Im having this problem with the same error message, here is what i have in hyperlaunch else if (systemName = "Nintendo 64" && executable = "Project64.exe") { hideDesktop() Sleep, 2000 Hotkey, %exitEmulatorKey%, CloseProcess RunWait, %executable% "%romPath%%romName%%romExtension%" -fullscreen, %emuPath%, Hide UseErrorLevel } Lyper launch is also set to true. I dont know if nulldc is my problem, How would i go about changing direct draw to api? Thanks guys.
CobraMJD Posted May 13, 2011 Posted May 13, 2011 fixed ithad to tell the emulator to go full screen on rom load and set use Hyperlaunch to true Thank You!! It works for me. I was going crazy with this error.
Powerblaster Posted February 23, 2012 Posted February 23, 2012 Thanks for this post I was going crazy lol
gwolfkill Posted March 3, 2012 Posted March 3, 2012 Ditto.....just spent 2+ hours playing with graphics settings. Setting to full screen on load fixed me too.
jojocool111 Posted July 16, 2014 Posted July 16, 2014 Ditto.....just spent 2+ hours playing with graphics settings. Setting to full screen on load fixed me too. how do you edit hyperspin
