Jp's spiderman B2s table
tonyg241
Ok I have my screenres.txt file set so that on all of the music tables and on Scarface Balls and Power my dmd appears on my third screen , exactly as I want it to. The problem is, I installed the b2s version of jp's spiderman table and when I start it the dmd is nowhere close to where it's supposed to be. I'm sure I could move it by adjusting my screenres file, but then I will be moving the dmd on my other tables. Any suggestions are appreciated!
You can have separate screenres files for specific tables. E.g. if the table is called Spiderman.vpt and the backglass is Spiderman.directb2s you need to save a copy of your screenres file as Spiderman.res and make the necessary changes to it to get your DMD in the right place for this table.
