dmd size
mwg
Hi,
i need to be clear on something
Are all dmd sizes the same? What i really need to know are they all the same aspect ratio?
The Vishay DMD has Viewing Area: 12.75" [323.8 mm] (W) x 3.15" [80.01 mm] (H)
Because this is such a popular dmd i use this as a guide.
i have a 9 inch 16:9 ratio lcd for a small cabinet.
It has a Active area 198.000(W) mm × 111.696(H) mm
so to make a hole with the correct dmd ratio i need to make one
198mm (W) x 50mm (H) right?
Thank you :embarassed:
Std DMd hole size is 13.5x3.5 with 1/4" rounded corners
WWW.Xtremepinball.com
CNC Work Here.....
Thats what i meant, Vishay DMD has Viewing Area: 12.75" [323.8 mm] (W) x 3.15" [80.01 mm]
so my 9 inch 16:9 lcd is only 198mm wide (7.8 inch)
then my height must be 2 inch? for the correct ratio?
