E13capt Posted May 4, 2016 Posted May 4, 2016 This is the first time I have been stumped and could not locate an answer on this forum (or BlueMsx and Rocket Launcher forums). I am trying to add colecovision using BlueMSX as the emulator and all works well except one thing, I cannot get the emulator to exit to go back to Hyperspin. I think it has something to do with this emulator using LCTRL+Cancel to exit instead of ESC. i have the latest updates (5/1/2015) for Rocket Launcher and Hyperspin installed, but I had to revert back to HS 1.3.3 because the 1.4 upgrade would not respond to any input. It opened to the system wheel and just spun continuously no matter what I did. So my current setup is updated Rocket Launcher and HS 1.3.3. Sill can't exit BlueMsx. Thanks for a great program and thanks for any help.
E13capt Posted May 4, 2016 Author Posted May 4, 2016 Thanks Agent47, did you have to do anything special in your RL setup?
thcdgaf Posted July 19, 2016 Posted July 19, 2016 On 5/4/2016 at 4:53 PM, E13capt said: This is the first time I have been stumped and could not locate an answer on this forum (or BlueMsx and Rocket Launcher forums). I am trying to add colecovision using BlueMSX as the emulator and all works well except one thing, I cannot get the emulator to exit to go back to Hyperspin. I think it has something to do with this emulator using LCTRL+Cancel to exit instead of ESC. i have the latest updates (5/1/2015) for Rocket Launcher and Hyperspin installed, but I had to revert back to HS 1.3.3 because the 1.4 upgrade would not respond to any input. It opened to the system wheel and just spun continuously no matter what I did. So my current setup is updated Rocket Launcher and HS 1.3.3. Sill can't exit BlueMsx. Thanks for a great program and thanks for any help. you might also wanna give retroarch a try it has core for this seen it the other day
ninja2bceen Posted July 19, 2016 Posted July 19, 2016 Make sure fade exit is off Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
