dreamkey56 Posted January 12, 2014 Posted January 12, 2014 Hello. How do I Register the ocx file to work for ledwiz? I have read "Put these files into your VP Tables directory: core.vbs ledcontrol.ini ledcontrol.vbs ledwizm05.ocx Next register the ocx file by typing this on the command line: Regsvr32 C:\Program Files\Visual Pinball\Tables\ledwizm05.ocx" <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< I tried this, but cannot get it working. I I go to the command line (using cmd to get this dosbox), I put in the line "C:\Programme(86)\visualPinball\Tables\ledwizm05.ocx" But it Fails. Look, as the ledwizm05.ocs cannot be found in this Folder. But I can see it, it is there.. Can anybody help me please? Thank you, HP
dreamkey56 Posted January 12, 2014 Author Posted January 12, 2014 Hi again. Does not know, why the ledwizm05.ocx cant be found. wrote it in, exactly as the Directory is. Strange. Now I putted it directly on C:, and so it could be found and worked. dreamkey56 said: Hello.How do I Register the ocx file to work for ledwiz? I have read "Put these files into your VP Tables directory: core.vbs ledcontrol.ini ledcontrol.vbs ledwizm05.ocx Next register the ocx file by typing this on the command line: Regsvr32 C:\Program Files\Visual Pinball\Tables\ledwizm05.ocx" <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< I tried this, but cannot get it working. I I go to the command line (using cmd to get this dosbox), I put in the line "C:\Programme(86)\visualPinball\Tables\ledwizm05.ocx" But it Fails. Look, as the ledwizm05.ocs cannot be found in this Folder. But I can see it, it is there.. Can anybody help me please? Thank you, HP
flip1950 Posted January 29, 2014 Posted January 29, 2014 Hi...Are you running Windows XP? Sent from my iPhone using Tapatalk
kozy68 Posted February 3, 2014 Posted February 3, 2014 Another way to register the ocx file is to drag and release it over the regsvr32 file in the system32 folder.
