HardRom Posted May 14, 2016 Posted May 14, 2016 Has anyone tried to get things like SiriusXm (Canada) to work as a launcher? Currently, I have a pinned tab in Chrome that autologs-in- but I wouldn't want all my other tabs to open (treat it like a dedicated session). Exitting chrome would also be interestingly accomplished. Steam and Kodi don't really seem to work with my setup for some reason, either. Steam Big Picture _will_ load, some days. It takes it's sweet time (up to 20 minutes, when I forgot I launched it and am doing something completely different). Kodi? Nope. I've been mucking about and trying to find where I went wrong, but seem to have something set wrong in my settings. TLDR; want a dedicated browser session for SiriusXm, looking for more things and ideas to make this an AIO cabinet. A whole entertainment system center, if you will. https://3dwarehouse.sketchup.com/model/095b7528-e4b0-41ef-8aae-a5fa2a296ff6/Custom-Arcade-Cabinet-V3
HardRom Posted May 14, 2016 Author Posted May 14, 2016 Has anyone tried to get things like SiriusXm (Canada) to work as a launcher? Currently, I have a pinned tab in Chrome that autologs-in- but I wouldn't want all my other tabs to open (treat it like a dedicated session). Exitting chrome would also be interestingly accomplished. Feel free to reply if you know a better way, or if this worked for you. I found a workaround way to do this- goto (website) in chrome, Settings-More Tools-Add To Desktop. Choose open as window. Open the [Properties] on the new desktop shortcut. In the RUN box, copy the input from the TARGET box. Create a new .bat file called whatever you want, and paste the data from the target box in the last step. Save the <yournamechoicehere>.bat (SiriusXm.bat) file and run it to test. If it works, you can delete the Chrome-saved "app" on your desktop. Add the .bat file to RocketLauncher as a new system. Create a file called SiriusXm.xml, copy the SPOILER text below and put it in the folder you also have to create (SiriusXM) in \HyperSpin\Databases\: <?xml version="1.0"?> <menu> <header> <listname>SiriusXm</listname> <lastlistupdate>05/14/16</lastlistupdate> <listversion>Online</listversion> <exporterversion>HyperList XML Exporter Version 1.3 Copywrite © 2009-2011 William Strong</exporterversion> </header> Again, create a file called SiriusXm.ahk, copy the below text and make a folder to put it in \RocketLauncher\Modules\SiriusXm\: ;---------------------------------------------------------------------------- ; SiriusXm ; PC Engine 1.7.0.49 ; Edit by HardRom ; 1.0a ; ;---------------------------------------------------------------------------- Run, %executable%, Hide Sleep, 2000 ;[MOUSE CURSOR] hideCursor = false Process, WaitClose, %Executable% ExitApp CloseProcess: Process, Close, %Executable% return Finally, set these HyperHQ Settings: Execution: Normal PC Game: Enabled Executable: <WhereverYouSavedThe.Bat>SiriusXm.bat ** I stored the SiriusXm.bat in the root of HyperSpin. WinState: Hidden Launch HyperSpin and it should work. Mine does! W00t! --until 12 Hours Later. Then, for no visible reason, my xml is invalid. https://3dwarehouse.sketchup.com/model/095b7528-e4b0-41ef-8aae-a5fa2a296ff6/Custom-Arcade-Cabinet-V3
