Atari 8-Bit and Atari800Win Plus
DJQuad
Does this help?
Atari800Win PLus 4.1: XL/XE (64 KB)
ahk_class Afx:00400000:b:00010005:00000006:2A4C0AD1
ahk_exe Atari800Win.exe
Edit: I'm not sure exactly what to change in the module.
Looks like you're not using the right version of the emulator. Have a look at the module notes to check.
In RocketLauncherUI you should check the Module notes. As tonesmalone said, be sure to use the version that's mentioned in the module.
Verstuurd vanaf mijn GT-I9195 met Tapatalk
So use Atari800 or Atari800Win PLus?
I believe you want the SDL version - hence the error message. But I haven't looked at this system for a while.
Specifically though I meant version number.
I switched back to Atari800 since Atari800Win is known to crash a lot.
I read the module notes but when I set the XL/XE bios path to atarixl.rom it says invalid checksum.
I was considering Xformer (http://www.emulators.com/xformer.htm) but there isn't a module for it. Maybe try Altirra?
Tried Altirra but depending on the rom extension it starts in several modes.
Does anyone have a working Atari 8-Bit setup? At this point I don't care what emulator is used.. lol
  • 3 months later...
