Atari Jaguar CD starts in background?
evilone
Hello,
again another small problem which im not able to figure out :-/
I setup my Atari Jaguar CD with Tempest PT emulator, without HS / RL everything runs fine, but when i use one of these then the game starts in background, after the loading screen, the screen stays black, but when i press ALT + TAP i can see that the game is running in the background you even can hear the music.
Im pretty sure its only a simple thing, but im not able to figure out :)
Thansk in advance,
REgards,
Sorry, found the problem.
For some reason it was the bezels, normally its set to "use global" but in this case it works fine if i disable, as no bezel is available for Jaguar CD.
Thanks anyway :)
