Auto HotKey assistance - key hold functions
majorspawn
Hi Guys,
Just need some AHK help if possible I am sure this will be basic for most people here.
I need 2 AHK scripts to do the following:
script 1:
When I press and hold button "x" this then presses and "holds down" button a + b + c for the duration of the hold of a. So a sleep command will not do here
To put it in practice, neogeo king of fighters i hold down x to allow the abc function to change power for fighter or when i play ssfiv and use x to function as a LP+MP+HP to perform super move, the script will fulfill both potentially.
script 2:
When I
press and hold "a" button down as a function key then press direction right it throws button b (alt key function)
press and hold "a" button down as a function key then press direction left it throws button c (alt key function)
in practice I wanted to map alternate keyboard keys in shank 2 to act as a dodge left / dodge right, by default it only allows you to map Left shift as alt hold key.
Thank you very much in advance
  • 2 years later...
Hi.  Did you manage to do this?  I need a hotkey script that will hold down the “enter” key for 4 or 5 seconds after being pressed.   I use “enter” to start a game
This eliminates all sorts of problems with led blinky and the problem of sound from menu videos playing in background after a rom loads.   I’ve no idea how to o do this.  Been reading a hotkey tutorial but it might as well be in Chinese.
