Joy2Key wont work to exit emulator!
cah12587
I'm having issues with joy2key...  Ive been playing around with rocketlauncher and hyperspin setup to solve my issues, I just cant figure it out!
The joy2key is working beautifully in Hyperspin, I am able to navigate menus and launch games with my controller.  When the games launch, the controller is still working fine!  I am not able to exit the emulator with the controller.  I mapped the Rocketlaunch profile and Hyperspin profile to emulate "Esc" when I press a particular button, but it does nothing while the emulator is running.  If i press the escape key on the keyboard it works fine and returns me to hyperspin, where the controller resumes working fine.  I tried changing the key it utilizes, changing the button i use to activate it, but nothing seems to work.
I think that the joy2key is not switching to my Rocketlancher profile once the emulator starts up.  I cant figure this out!!  Please Help!!!  Thanks!
The rocketlauncher profile doesn't run while using an emulator, it only gets activated when you use the pause menu. You would have to configure a profile for each emulator and add the exit command to each profile, or if using a controller just add whatever button combination to quit out of emulators from within rocketlauncherui saving urself the trouble.
If like me you are using a control pad (I'm using 360 pads) just go into rocketlauncherui, find the tab to set ur exit keys and create a new one. You can still leave ESC key as the default just click the + to add a new one. I use a combination of back + start to exit emulators.
I'm not 100% sure, but I think it's best to go that route instead of emulating the ESC key because some emulators have issues when quitting with the ESC key
Oh!  I didnt realize that rocketlauncher would allow me to set up an input from my controller without using joy2key.  Thanks so much for the quick response!  I have to check and see if it works tonight.  Thanks a million!
You still have to use joytokey. I have the same setup for my ps4 controller. I have the select button for coin( mame) and also exit( after 3 seconds). Sounds like you have it setup correctly but you have to set that up in the joytokey profile for the emulator your using. Like battle donkey said you need a joytokey profile for every emulator, and setup that emulators exit keys in the keyboard 2 tab in joytokey.
Sent from my XT1254 using Tapatalk
