how to set up Daemon Tools 10.2?
kratos_spartan
Hi guys! i need help, so i have Daemon Tools Lite 10.2 licensed of course, as in download section says that i have to set the path to DTAgent.exe that's what i did and nothing happens when i try to run SSF, is the only emulator that i have that needs to use DT, running it alone without Hyperspin works fine but of course i have to mount the image in a SCSI drive, the thing with this Daemon Tools is that is not like the older ones where you can create a virtual device, in this DT only creates one when you mount an image and when you close it the drive dissapears, i have windows 10 so there is no way i can use olders DT because the SPTD install file that uses those DT is not compatible with this new windows, anybody who can helpe me please, and one more thing if i left a wheel a few seconds alone then it starts to "roll" until y push a button, there's anyway to disable this?, thanks again guys!
The wheel spinning is the attract mode feature and can be disabled in HyperHQ by selecting Attract Mode Disabled on the Main Settings -> Attract tab. As for adding a drive in DT there should be an "Add drive" button on the Images tab under Mount to SCSI.
thanks for answer! well the Attract Mode thing worked of course, but in Daemon Tools there is no "add drive" and acording to a topic on DT forum the Lite version of 10.2 does not have that feature, only in Pro. is there anyway to use the Pro version with Rocketlauncher?, thanks.
