seanr28 Posted February 6, 2014 Posted February 6, 2014 Hello, I have been trying to get the both WinUAE2700 and or WINUAELOADER v1.78 working from hyperspin, both without any success WinUAE works fine directly from the emulator, when using via Hyperspin, the emulator load but and just gives you the Amiga prompt (no game attempts to load) WinUAELoader fails after doing nothing for around 20 seconds (log attached) I have read the Amiga emulator guide found on here, but has not helped. Would somebody kindly shed some light on the issue and advise which one is best to use please? 14:55:15:376 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.1c 14:55:15:516 | HL | INFO | +140 | Main - System Specs: HyperLaunch Dir: C:\Hyperspin\HyperLaunch OS: Microsoft Windows 7 Ultimate SKU: Ultimate Total Memory: 4095.05 MB Free Memory: 1359.44 MB Used Memory: 2735.613 MB SystemType: x64-based PC Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce 8800 GTS GPU 1 RAM: 640.00 MB GPU 1 Driver Version: 9.18.13.3221 Sound 1 Device: SoundMAX Integrated Digital HD Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1172 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 14:55:15:519 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 14:55:15:522 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 14:55:15:525 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.1.1 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 910336 bytes Created: 2/3/2014 - 4:51:29 PM Modified: 2/3/2014 - 10:19:06 AM 14:55:15:527 | HL | INFO | +16 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\itextsharp.dll exists 14:55:15:531 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:09 AM 14:55:15:533 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists 14:55:15:537 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:540 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\gsdll32.dll exists 14:55:15:542 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8818688 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:09 AM 14:55:15:545 | HL | INFO | +15 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe exists 14:55:15:549 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:552 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 14:55:15:562 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 14:55:15:566 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:569 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 14:55:15:576 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 14:55:15:579 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:582 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 14:55:15:587 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 14:55:15:590 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 10586 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:593 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 14:55:15:597 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 14:55:15:601 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:604 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 14:55:15:608 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 14:55:15:612 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:15:615 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 14:55:15:619 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:623 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 1145 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:626 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 14:55:15:630 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:633 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:637 | HL | INFO | +16 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 14:55:15:640 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:644 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:647 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 14:55:15:651 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:655 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 161 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:659 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 14:55:15:663 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:666 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:670 | HL | INFO | +15 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 14:55:15:675 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:679 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:682 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 14:55:15:700 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:704 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:708 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 14:55:15:713 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:717 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 30775 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:721 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 14:55:15:726 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:731 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 36816 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:734 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 14:55:15:743 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:748 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 83008 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:751 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 14:55:15:756 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:761 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 26153 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:764 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 14:55:15:770 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:774 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:778 | HL | INFO | +15 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 14:55:15:785 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:789 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 80791 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:793 | HL | INFO | +16 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 14:55:15:798 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:802 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:806 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 14:55:15:812 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 14:55:15:816 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:07 AM 14:55:15:821 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Databases\Main Menu\Main Menu.xml exists 14:55:15:825 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 1657 bytes Created: 1/28/2014 - 11:03:11 AM Modified: 2/6/2014 - 8:46:09 AM 14:55:15:863 | HL | INFO | +31 | Main - HyperLaunch launched directly 14:55:17:322 | HL | INFO | +1467 | Main - HyperLaunch received "Commodore Amiga" and "Lotus_v1.1_0774" 14:55:17:336 | HL | INFO | +15 | Main - Lotus_v1.1_0774 is using the default emulator: amiga uae loader 14:55:17:341 | HL | INFO | +0 | Main - Checking for a [amiga uae loader] section in C:\Hyperspin\HyperLaunch\Settings\Commodore Amiga\Emulators.ini 14:55:17:346 | HL | INFO | +0 | Main - Found [amiga uae loader] in C:\Hyperspin\HyperLaunch\Settings\Commodore Amiga\Emulators.ini 14:55:17:351 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\WinUAE Loader\WinUAE Loader.ahk exists 14:55:17:356 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 4631 bytes Created: 2/3/2014 - 4:51:29 PM Modified: 2/3/2014 - 10:19:11 AM 14:55:17:362 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 14:55:17:366 | HL | INFO | +0 | Main - Lotus_v1.1_0774 will use module: C:\Hyperspin\HyperLaunch\Modules\WinUAE Loader\WinUAE Loader.ahk 14:55:17:389 | HL | INFO | +31 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 14:55:17:398 | HL | INFO | +0 | Main - INI Keys read 14:55:17:403 | HL | INFO | +16 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 14:55:17:409 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:17:414 | HL | INFO | +15 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 14:55:17:420 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 2/3/2014 - 4:51:27 PM Modified: 2/3/2014 - 10:19:08 AM 14:55:17:424 | HL | INFO | +0 | CheckPaths - Started 14:55:17:429 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Roms\Commodore Amiga\Lotus_v1.1_0774.zip 14:55:17:434 | HL | INFO | +16 | CheckPaths - Found rom: E:\Roms\Commodore Amiga\Lotus_v1.1_0774.zip 14:55:17:438 | HL | DEBUG1 | +0 | CheckPaths - Current romName: Lotus_v1.1_0774 14:55:17:442 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: E:\Roms\Commodore Amiga 14:55:17:445 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .zip 14:55:17:449 | HL | INFO | +16 | CheckFile - Checking if C:\Emulators\Commodore Amiga\WinUAELoader\WinUAELoader.exe exists 14:55:17:454 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription WinUAELoader FileVersion 1.0.0.0 InternalName WinUAELoader.exe LegalCopyright Copyright © 2008 OriginalFilename WinUAELoader.exe ProductName WinUAELoader ProductVersion 1.0.0.0 File Size: 477184 bytes Created: 1/28/2014 - 3:47:08 PM Modified: 4/1/2013 - 9:09:01 PM 14:55:17:457 | HL | INFO | +0 | CheckPaths - Ended 14:55:17:462 | HL | INFO | +15 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 0 hlMode = frontendPID = 0 frontendPath = C:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = C:\Emulators\Commodore Amiga\WinUAELoader\WinUAELoader.exe emuPath = C:\Emulators\Commodore Amiga\WinUAELoader emuName = amiga uae loader emuExt = exe romPath = E:\Roms\Commodore Amiga romPathFromIni = E:\Roms\Commodore Amiga romExtension = .zip romExtensionOrig = .zip romExtensions = zip executable = WinUAELoader.exe systemName = Commodore Amiga dbName = Lotus_v1.1_0774 romName = Lotus_v1.1_0774 romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = C:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false logFile = C:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = true sysLang = English_United_States navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1200 dtEnabled = true dtPath = dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = C:\Hyperspin\HyperLaunch\Data HLMediaPath = C:\Hyperspin\HyperLaunch\Media HLErrSoundPath = C:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = C:\Hyperspin\HyperLaunch\Modules moduleFullName = C:\Hyperspin\HyperLaunch\Modules\WinUAE Loader\WinUAE Loader.ahk moduleName = WinUAE Loader modulePath = C:\Hyperspin\HyperLaunch\Modules\WinUAE Loader moduleExtension = ahk moduleExtensionsPath = C:\Hyperspin\HyperLaunch\Module Extensions libPath = C:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\temp 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\Hyperspin\HyperLaunch\Profiles\xpadder keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin defaultProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default systemProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga xPadderSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga\_Default emuProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga\amiga uae loader romProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga\Lotus_v1.1_0774 HyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch blankProfile = C:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank ahkFEProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga ahkEmuProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga\amiga uae loader ahkRomProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga\Lotus_v1.1_0774 ahkHyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false statisticsEnabled = true 14:55:17:466 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 14:55:17:470 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 14:55:17:474 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 14:55:17:477 | HL | DEBUG1 | +16 | BuildScript - Module starts on line: 2 14:55:17:482 | HL | INFO | +0 | BuildScript - Module: MEmu = WinUAE Loader MEmuV = v1.74 MURL = http://headsoft.com.au/index.php?category=winuaeloader MAuthor = djvj MVersion = 2.0 MCRC = 558D1E8B iCRC = 4E0EC826 MID = 635038268935640326 MSystem = "Commodore Amiga" ;---------------------------------------------------------------------------- ; Notes: ; Requires WinUAE v2.4.0+ ; You can configure WinUAE from the built-in GUI or use another loader that makes things a bit simpler ; To configure WinUAE settings using WinUAE Loader v1.72 or later ; Paths->WinUAE Exe->WinUAE Exe should point to your winuae.exe ; Paths->Rom Folders->WHDLoad should point to your roms dir ; Input->Exit Options->Global Exit Key should be 27 (if you use ESC). Check "Force WHDLoad Close" and set "Close Timeout" to 0 for the fastest exit ; Settings->Display Options set Full Screen and all the check boxes ; ; Don't forget to open WinUAE directly and goto Paths and set your System ROMs dir. WinAUE will scan all your roms and enables what it finds ; ; Set emupath to your WinUAELoader dir and the exe to WinUAELoader.exe ; autoResume additions courtesy of: http://www.hyperspin-fe.com/forum/showthread.php?24702-Amiga-Whdloader-module-with-auto-save-load-state ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) resolution := IniReadCheck(settingsFile, "Settings", "Resolution","1024x768",,1) ; Set resolution of WinUAE's window. Depending on Fullscreen value, there are different resolutions supported by WinUAE. autoResume := IniReadCheck(settingsFile, "Settings", "autoResume","true",,1) ; if true, will automatically save your game's state on exit and reload it on the next launch of the same game. loaderINI := CheckFile(emuPath . "\Data\WinUAELoader.ini") IniRead, currentFullScreen, %loaderINI%, Display, Windowed fullscreenResAr := Object("640x480",0,"720x480",1,"720x576",2,"800x600",3,"1024x768",4,"1152x864",5,"1280x720",6,"1280x756",7,"1280x800",8,"1280x960",9,"1280x1024",10,"1360x768",11,"1366x768",12,"1600x900",13,"1600x1024",14,"1600x1200",15,"1680x1050",16,"1900x1080",17,"1920x1200",18) windowedResAr := Object("320x256",0,"640x512",1,"720x576",2) If fullscreen = true ; get value to set in WinUAELoader's ini resolution := fullscreenResAr[resolution] Else resolution := windowedResAr[resolution] If (fullscreen != "true" && resolution >= 3) || !resolution ; if user switched from fullscreen to windowed and did not set a valid windowed resolution, or the array lookup failed, we will default to 720x576 because the default 1024x768 res is not valid in windowed mode resolution := 2 ; Setting Fullscreen setting in ini if it doesn't match what user wants above. Because the key is "Windowed" set values are opposite normal emus If ( Fullscreen != "true" And currentFullScreen = "false" ) { ; want windowed mode IniWrite, True, %loaderINI%, Display, Windowed IniWrite, %resolution%, %loaderINI%, Display, Screen } Else If ( Fullscreen = "true" And currentFullScreen = "true" ) { ; want fullscreen mode IniWrite, False, %loaderINI%, Display, Windowed IniWrite, %resolution%, %loaderINI%, Display, Screen } 7z(romPath, romName, romExtension, 7zExtractPath) stateName := emuPath . "\states\" . romName . ".uss" Run(executable . " -mode whdload -game """ . romPath . "\" . romName . romExtension . """", emuPath) If (FileExist(stateName) and autoResume="true") { clipboard = %stateName% WinWait("ahk_class AmigaPowah") Send {F7} ; open load state window WinWait("Restore a WinUAE snapshot file") Send ^v Send {Enter} } WinWait("ahk_class " . (If fullscreen = "true" ? "AmigaPowah" : "PCsuxRox")) ; window class name changes if in windowed or fullscreen WinWaitActive("ahk_class " . (If fullscreen = "true" ? "AmigaPowah" : "PCsuxRox")) FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() GroupAdd,DIE,DIEmWin GroupClose, DIE, A ExitModule() CloseProcess: If (FileExist(stateName) and autoResume="true") Send {F5} ; open save state window FadeOutStart() If (FileExist(stateName) and autoResume="true") { clipboard = %stateName% ; just in case something happened to clipboard in between start of module to now WinWait("Save a WinUAE snapshot file") Send ^v Send {Enter} Sleep, 50 ; always give time for a file operation to occur before closing an app } WinClose("ahk_class " . (If fullscreen = "true" ? "AmigaPowah" : "PCsuxRox")) Return 14:55:17:486 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 14:55:17:489 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 14:55:17:493 | HL | INFO | +15 | BuildScript - Finished injecting functions into module 14:55:17:498 | HL | INFO | +0 | Main - Module is built 14:55:17:502 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 14:55:17:507 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 2/3/2014 - 4:51:29 PM Modified: 2/3/2014 - 10:19:04 AM 14:55:17:512 | HL | INFO | +16 | Main - Running module 14:55:17:516 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 14:55:17:622 | MD | INFO | +N/A | Module initialized 14:55:17:628 | MD | INFO | +0 | StartModule - Started 14:55:17:632 | MD | INFO | +0 | StartModule - MEmu: WinUAE Loader MEmuV: v1.74 MURL: http://headsoft.com.au/index.php?category=winuaeloader MAuthor: djvj MVersion: 2.0 MCRC: 558D1E8B iCRC: 4E0EC826 MID: MSystem: "Commodore Amiga" 14:55:17:636 | MD | INFO | +16 | StartModule - You have a supported System Name for this module: "Commodore Amiga" 14:55:17:640 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: Lotus_v1.1_0774 14:55:17:645 | MD | INFO | +0 | StartModule - Ended 14:55:17:649 | MD | INFO | +15 | StartGlobalUserFeatures - Starting 14:55:17:653 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 14:55:17:658 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 14:55:17:661 | MD | INFO | +0 | Module Setting - [settings] - Resolution: 1024x768 14:55:17:665 | MD | INFO | +16 | Module Setting - [settings] - autoResume: true 14:55:17:669 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\Commodore Amiga\WinUAELoader\Data\WinUAELoader.ini exists 14:55:17:673 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1655 bytes Created: 1/28/2014 - 3:47:08 PM Modified: 2/6/2014 - 2:38:25 PM 14:55:17:677 | MD | INFO | +0 | Run - Running: C:\Emulators\Commodore Amiga\WinUAELoader\WinUAELoader.exe -mode whdload -game "E:\Roms\Commodore Amiga\Lotus_v1.1_0774.zip" 14:55:17:721 | MD | DEBUG1 | +47 | Run - "WinUAELoader.exe -mode whdload -game "E:\Roms\Commodore Amiga\Lotus_v1.1_0774.zip"" Process ID: 5248 14:55:17:725 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;473d60ca-bbc7-41ee-ba7f-463407eb6276] | State: 0 | X: 198 | Y: 199 | Width: 1150 | Height: 960 | Window HWND: 0x1d0826 | Process ID: 4448 | Process Path: C:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 14:55:17:730 | MD | INFO | +15 | WinWait - Waiting for "ahk_class AmigaPowah" 14:55:47:730 | MD | DEBUG1 | +29999 | GetActiveWindowStatus - Title: WinUAE2700 | Class: CabinetWClass | State: 0 | X: 288 | Y: 108 | Width: 798 | Height: 570 | Window HWND: 0x2304a6 | Process ID: 2256 | Process Path: C:\Windows\explorer.exe 14:55:48:116 | MD | DEBUG1 | +390 | ScriptError - Playing error sound: error1.mp3 14:55:51:544 | MD | ERROR | +3417 | There was an error waiting for the window "ahk_class AmigaPowah". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 14:55:51:549 | MD | INFO | +16 | ExitModule - Started 14:55:51:554 | MD | INFO | +0 | Starting Updating Statistics: 14:55:51:558 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 14:55:51:562 | MD | DEBUG2 | +0 | gameSectionStartTime:150006349 14:55:51:566 | MD | DEBUG2 | +15 | ElapsedTime:33 14:55:51:570 | MD | INFO | +0 | CreateRomTable - Started 14:55:51:575 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Disc" 14:55:51:579 | MD | DEBUG1 | +16 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Disk" 14:55:51:581 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Cart" 14:55:51:585 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Tape" 14:55:51:589 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Cassette" 14:55:51:593 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Part" 14:55:51:596 | MD | DEBUG1 | +15 | CreateRomTable - Checking for match: "Lotus_v1.1_0774" and "(Side" 14:55:51:600 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 14:55:51:605 | MD | DEBUG2 | +0 | Statistics cleared game name: Lotus_v1.1_0774 14:55:51:634 | MD | DEBUG2 | +32 | Loaded game statistics from ini files: Number_of_Times_Played: 9 Last_Time_Played: Thursday February 6, 2014 02:51:42 PM Average_Time_Played: 21 Total_Time_Played: 192 System_Total_Played_Time: 424 Total_Global_Played_Time: 2276 14:55:51:638 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 10 Last_Time_Played: Thursday February 6, 2014 02:55:17 PM Average_Time_Played: 23 Total_Time_Played: 225 System_Total_Played_Time: 457 Total_Global_Played_Time: 2309 14:55:51:671 | MD | INFO | +31 | Game section statistics updated. 14:55:51:676 | MD | INFO | +15 | ExitModule - Ended 14:55:51:680 | MD | INFO | +0 | End of Module Logs 14:55:51:783 | HL | INFO | +34274 | Main - Module ended, exiting HyperLaunch normally 14:55:51:789 | HL | INFO | +0 | ExitScript - Started 14:55:51:809 | HL | INFO | +15 | SystemCursor - Restoring mouse cursor 14:55:51:822 | HL | INFO | +16 | ExitScript - Ended
rfancella Posted February 6, 2014 Posted February 6, 2014 Sean, Did you follow this guide? http://www.hyperspin-fe.com/forum/showthread.php?30367-Complete-Guide-for-Commodore-Amiga-in-HyperSpin-and-RL Using just WinUAE, there are a couple of extra steps to allow it to work. If WinUAE just loads to the CLI 1 prompt, that means you don't have the Amiga OS directory correct. To fix that, use this post: http://www.hyperspin-fe.com/forum/showthread.php?30367-Complete-Guide-for-Commodore-Amiga-in-HyperSpin-and-RL&p=299294&viewfull=1#post299294 The first guide above should work just fine for WinUAE and WinUAELoader, if you have WinUAELoader configured. Please do not skip any steps. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
seanr28 Posted February 6, 2014 Author Posted February 6, 2014 yes i used the guide and have been over it several times, but neither will work for me.
rfancella Posted February 6, 2014 Posted February 6, 2014 yes i used the guide and have been over it several times, but neither will work for me. Ok, Read from this post on... http://www.hyperspin-fe.com/forum/showthread.php?30367-Complete-Guide-for-Commodore-Amiga-in-HyperSpin-and-RL&p=299294&viewfull=1#post299294 It shows how to use the WinUAELoader Amiga OS directory to make WinUAE run without using the Loader. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
seanr28 Posted February 6, 2014 Author Posted February 6, 2014 right, just used your fix above and it now works:) thankyou.....
rfancella Posted February 6, 2014 Posted February 6, 2014 right, just used your fix above and it now works:) thankyou..... To clean that up a bit, you could move the WHD directory from inside WinUAELoader to inside your WinUAE folder. Change the path in your Commodore Amiga.ini to reflect the change. Then you can delete the WinUAELoader directory. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
seanr28 Posted February 6, 2014 Author Posted February 6, 2014 ok thankyou, one last question if you don't mind, I have obtained a stupid amount of amiga games, but the xml lists I found cant be matched to roms, Ive used hyper tools etc, my hyperspin setup already has lots of games listed with their respective artwork etc, what do you suggest please?
rfancella Posted February 6, 2014 Posted February 6, 2014 ok thankyou,one last question if you don't mind, I have obtained a stupid amount of amiga games, but the xml lists I found cant be matched to roms, Ive used hyper tools etc, my hyperspin setup already has lots of games listed with their respective artwork etc, what do you suggest please? Sean, Keep reading through the guide. Potts just posted he has finished an xml that matches the PD set. I, personally, will play around with his files. But probably go to the HyperList xml when/if it's ever finished. Really the best option would be to rename your roms to match your artwork. If you need help with this, please PM me. Thanks, Ron PS: Opps, just noticed you don't have FTP access. Sorry. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
seanr28 Posted February 6, 2014 Author Posted February 6, 2014 I have now got a .dat file for my roms, how do I use this use as an .xml list for hyperspin? I have tried hyper tools rom renamer but its just stops and wont complete.
seanr28 Posted February 6, 2014 Author Posted February 6, 2014 this is the set Im using, just need an xml file for them, but having trouble finding one....Commodore_Amiga_TOSEC_2012_04_10
veganpete Posted May 7, 2014 Posted May 7, 2014 could you use a tool such as dir2xml? Pop it into the roms folder and run it to generate an xml based on the folder's contents.
rfancella Posted May 7, 2014 Posted May 7, 2014 could you use a tool such as dir2xml? Pop it into the roms folder and run it to generate an xml based on the folder's contents. Yes, he could for sure. I would recommend using HyperTools. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
