tscottn Posted July 20, 2016 Posted July 20, 2016 Hey guys, Been running into a issue that I hope one of you hyperspin gurus can help me with. I cannot seem to get RL to load any xpadder profiles. I believe I have everything setup correctly and the right paths in RL set. I can make a profile under the keymapper tab and test it works just fine, however when I play the game from the games tab RL will not launch any profiles for the emulator. I am attaching my logs. Thanks. 21:46:01:836 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 21:46:02:045 | RL | INFO | +219 | Main - System Specs: RocketLauncher Dir: D:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 8065.90 MB Free Memory: 5349.32 MB Used Memory: 2716.582 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce 940MX GPU 1 RAM: -2048.00 MB GPU 1 Driver Version: 10.18.13.6203 GPU 2 Name: Intel(R) HD Graphics 520 GPU 2 RAM: 1024.00 MB GPU 2 Driver Version: 20.19.15.4390 Sound 1 Device: Realtek High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Intel(R) Display Audio Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: Yes RL Compatibility Flags: HIGHDPIAWARE Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1030 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 125 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 21:46:02:045 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\RocketLauncher.exe exists 21:46:02:046 | RL | INFO | +0 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: D:\hyperspin\HyperSpin.exe 21:46:02:046 | RL | INFO | +0 | Main - Raw CLI received: "Nintendo Entertainment System Super Jeopardy! (USA)" 21:46:02:047 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 21:46:02:047 | RL | INFO | +0 | Process.Process - "Exist" "HyperSpin.exe" 21:46:02:053 | RL | INFO | +0 | Main - Detected HyperSpin.exe is currently running 21:46:02:053 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 21:46:02:053 | RL | INFO | +0 | Main - RocketLauncher received "Nintendo Entertainment System" and "Super Jeopardy! (USA)" 21:46:02:063 | RL | INFO | +15 | Main - Did not find a "D:\RocketLauncher\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options. 21:46:02:063 | RL | INFO | +0 | Main - Super Jeopardy! (USA) is using the default emulator: Nestopia - NES 21:46:02:063 | RL | INFO | +0 | Main - Checking for a [Nestopia - NES] section in D:\RocketLauncher\Settings\Nintendo Entertainment System\Emulators.ini 21:46:02:063 | RL | INFO | +0 | Main - Found [Nestopia - NES] in D:\RocketLauncher\Settings\Nintendo Entertainment System\Emulators.ini 21:46:02:063 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Modules\Nestopia\Nestopia.ahk exists 21:46:02:069 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 21:46:02:069 | RL | INFO | +0 | Main - Super Jeopardy! (USA) will use module: D:\RocketLauncher\Modules\Nestopia\Nestopia.ahk 21:46:02:077 | RL | WARNING | +16 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\Global RocketLauncher.ini" 21:46:02:077 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\Nintendo Entertainment System\RocketLauncher.ini" 21:46:02:119 | RL | INFO | +31 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 21:46:02:127 | RL | INFO | +16 | CheckFile - Checking if D:\hyperspin\Emulators\Nintendo Entertainment System\nestopia.exe exists 21:46:02:128 | RL | INFO | +0 | Main - INI Keys read 21:46:02:128 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.exe exists 21:46:02:129 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.dll exists 21:46:02:140 | RL | INFO | +15 | Main - "Super Jeopardy! (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 21:46:02:140 | RL | INFO | +0 | CheckPaths - Started 21:46:02:140 | RL | INFO | +0 | CheckPaths - Looking for rom: D:\hyperspin\Emulators\Nintendo Entertainment System\roms\Super Jeopardy! (USA).ZIP 21:46:02:140 | RL | INFO | +0 | CheckPaths - Found rom: D:\hyperspin\Emulators\Nintendo Entertainment System\roms\Super Jeopardy! (USA).ZIP 21:46:02:140 | RL | INFO | +0 | CheckPaths - Ended 21:46:02:141 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 2 rlPath = D:\RocketLauncher pluginPath = D:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.1.1.1 rlAuthor = djvj rlURL = www.rlauncher.com langFile = D:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 5676 frontendPath = D:\hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = D exitEmulatorKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = D:\hyperspin\Emulators\Nintendo Entertainment System\nestopia.exe emuPath = D:\hyperspin\Emulators\Nintendo Entertainment System emuName = Nestopia - NES emuExt = exe baseRomPath = romPath = D:\hyperspin\Emulators\Nintendo Entertainment System\roms romPathFromIni = D:\hyperspin\Emulators\Nintendo Entertainment System\roms romExtension = .ZIP romExtensionOrig = .ZIP romExtensions = ZIP executable = nestopia.exe systemDbName = Nintendo Entertainment System systemName = Nintendo Entertainment System dbPath = dbName = Super Jeopardy! (USA) dbExt = romName = Super Jeopardy! (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = D:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel = 3 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = true errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true demulShooterPath = servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = D:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = D:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text with label fadeRomInfoPublisher = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = D:\RocketLauncher\Media\Fade RLDataPath = D:\RocketLauncher\Data RLMediaPath = D:\RocketLauncher\Media RLErrSoundPath = D:\RocketLauncher\Media\Sounds\Error modulesPath = D:\RocketLauncher\Modules moduleFullName = D:\RocketLauncher\Modules\Nestopia\Nestopia.ahk moduleName = Nestopia modulePath = D:\RocketLauncher\Modules\Nestopia moduleExtension = ahk moduleExtensionsPath = D:\RocketLauncher\Module Extensions libPath = D:\RocketLauncher\Lib sevenZEnabled = false sevenZPath = D:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = D:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = C:\Users\Alex\AppData\Local\Temp\HS sevenZExtractPathOrig = sevenZAttachSystemName = false sevenZDelTemp = true sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = C:\Users\Alex\AppData\Local\Temp\HS mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = false pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = D:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keyboardEncoder = keyboardEncoderEnabled = true keymapperEnabled = true keymapperAHKMethod = External keymapper = xpadder xpadderFullPath = D:\hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = D:\Utilities\JoyToKey\JoyToKey.exe profilePath = D:\RocketLauncher\Profiles keymapperProfilePath = D:\RocketLauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Controller (XBOX 360 For Windows) joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = Controller (XBOX 360 For Windows) CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = D:\RocketLauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = D:\RocketLauncher\Profiles\xpadder\_Default systemProfile = D:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System xPadderSystemProfile = D:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\_Default emuProfile = D:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\Nestopia - NES romProfile = D:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\Super Jeopardy! (USA) RocketLauncherProfile = D:\RocketLauncher\Profiles\xpadder\RocketLauncher blankProfile = D:\RocketLauncher\Profiles\xpadder\_Default\blank ahkFEProfile = D:\RocketLauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = D:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = D:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System ahkEmuProfile = D:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\Nestopia - NES ahkRomProfile = D:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\Super Jeopardy! (USA) ahkRocketLauncherProfile = D:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = D:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = D:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = D:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = initialErrorMode = 0 21:46:02:144 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 21:46:02:144 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 21:46:02:144 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 21:46:02:144 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions Init.ahk" not found 21:46:02:144 | RL | INFO | +0 | BuildScript - Validating module 21:46:02:145 | RL | INFO | +0 | BuildScript - Validation complete 21:46:02:145 | RL | INFO | +0 | BuildScript - Module: MEmu = Nestopia MEmuV = v1.42 MURL = http://www.emucr.com/2011/09/nestopia-unofficial-v1420.html MAuthor = djvj MVersion = 2.0.4 MCRC = 6F80AA06 iCRC = F9662CA1 MID = 635038268908287546 MSystem = "Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System" ;---------------------------------------------------------------------------- ; Notes: ; If using this for Nintendo Famicom Disk System, make sure you place an FDS bios in your bios subfolder for your emu. You will have to select it on first launch of any FDS game. ; Set your fullscreen key to Alt+Enter if it is not already for Pause support ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1) ExitKey := IniReadCheck(settingsFile, "settings", "ExitKey","Esc",,1) ToggleMenuKey := IniReadCheck(settingsFile, "settings", "ToggleMenuKey","Alt+M",,1) bezelTopOffset := IniReadCheck(settingsFile, "Settings", "bezelTopOffset",16,,1) bezelBottomOffset := IniReadCheck(settingsFile, "Settings", "bezelBottomOffset",26,,1) bezelLeftOffset := IniReadCheck(settingsFile, "Settings", "bezelLeftOffset",7,,1) bezelRightOffset := IniReadCheck(settingsFile, "Settings", "bezelRightOffset",7,,1) force4players := IniReadCheck(settingsFile, romName, "force4players","False",,1) BezelStart() emuSettingsFile := emuPath . "\" . "nestopia.xml" FileRead, nesXML, %emuSettingsFile% IfInString, nesXML, % "<confirm-exit>yes</confirm-exit>" ; find if this setting is not the desired value StringReplace, nesXML, nesXML, % "<confirm-exit>yes</confirm-exit>", % "<confirm-exit>no</confirm-exit>" ; turning off confirmation on exit IfNotInString, nesXML, % "<exit>" . ExitKey . "</exit>" ; find if this setting is not the desired value { currentExitKey := StrX(nesXML,"<exit>" ,0,0,"</exit>",0,0) ; trim confirm-exit to what it's current setting is StringReplace, nesXML, nesXML, % currentExitKey, % "<exit>" . ExitKey . "</exit>" ; replacing the current exit key to the desired one from above } IfNotInString, nesXML, % "<toggle-menu>" . ToggleMenuKey . "</toggle-menu>" ; find if this setting is not the desired value { currentMenuKey := StrX(nesXML,"<toggle-menu>" ,0,0,"</toggle-menu>",0,0) ; trim toggle-menu to what it's current setting is StringReplace, nesXML, nesXML, % currentMenuKey, % "<toggle-menu>" . ToggleMenuKey . "</toggle-menu>" ; replacing the current toggle-menu key to the desired one from above } If force4players = true { IfInString, nesXML, % "<auto-select-controllers>yes</auto-select-controllers>" ; find if this setting is not the desired value StringReplace, nesXML, nesXML, % "<auto-select-controllers>yes</auto-select-controllers>", % "<auto-select-controllers>no</auto-select-controllers>" ; replacing the current toggle-menu key to the desired one from above StringReplace, nesXML, nesXML, % "<port-3>unconnected</port-3>", % "<port-3>pad3</port-3>" StringReplace, nesXML, nesXML, % "<port-4>unconnected</port-4", % "<port-4>pad4</port-4>" } Else IfInString, nesXML, % "<auto-select-controllers>no</auto-select-controllers>" ; find if this setting is not the desired value StringReplace, nesXML, nesXML, % "<auto-select-controllers>no</auto-select-controllers>", % "<auto-select-controllers>yes</auto-select-controllers>" ; replacing the current toggle-menu key to the desired one from above ; Enable Fullscreen currentFS := StrX(nesXML,"<start-fullscreen>" ,0,0,"</start-fullscreen>",0,0) ; trim start-fullscreen to what it's current setting is StringReplace, nesXML, nesXML, % currentFS, % "<start-fullscreen>" . ((If Fullscreen = "true")?"yes":"no") . "</start-fullscreen>" ; setting start-fullscreen to the desired setting from above SaveFile() hideEmuObj := Object("Nestopia ahk_class Nestopia",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("Nestopia ahk_class Nestopia") WinWaitActive("Nestopia ahk_class Nestopia") BezelDraw() HideEmuEnd() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() SaveFile() { Global emuSettingsFile Global nesXML FileDelete, %emuSettingsFile% FileAppend, %nesXML%, %emuSettingsFile%, UTF-8 } HaltEmu: ; Send, !{Enter} Sleep, 200 Return RestoreEmu: WinActivate, ahk_id %emulatorID% ; Send, !{Enter} Return CloseProcess: FadeOutStart() WinClose("Nestopia ahk_class Nestopia") Return 21:46:02:167 | RL | INFO | +16 | BuildScript - Loaded Multi-Player scripts 21:46:02:169 | RL | INFO | +16 | BuildScript - Loaded Statistics.ahk script 21:46:02:169 | RL | WARNING | +0 | BuildScript - "D:\RocketLauncher\Lib\User Functions.ahk" not found 21:46:02:169 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 21:46:02:172 | RL | INFO | +0 | Main - Module is built 21:46:02:172 | RL | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\AutoHotkey.dll exists 21:46:02:178 | RL | INFO | +0 | Main - Running module 21:46:02:400 | MD | INFO | +N/A | Module initialized 21:46:02:402 | MD | INFO | +0 | LoadPreferredControllers - Started 21:46:02:402 | MD | INFO | +0 | GetJoystickArray - Started 21:46:02:420 | MD | INFO | +32 | GetJoystickArray - Ended 21:46:02:420 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 21:46:02:420 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 21:46:02:421 | MD | INFO | +0 | LoadPreferredControllers - Ended 21:46:02:421 | MD | INFO | +0 | CheckFile - Checking if D:\hyperspin\Utilities\Xpadder\Xpadder.exe exists 21:46:02:422 | MD | INFO | +0 | Keymapper - Loading xpadder 21:46:02:422 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 21:46:02:422 | MD | INFO | +0 | GetJoystickArray - Started 21:46:02:423 | MD | INFO | +0 | GetJoystickArray - Ended 21:46:02:423 | MD | INFO | +0 | RunXpadder - Started 21:46:02:423 | MD | INFO | +0 | Process - Exist JoyToKey.exe 21:46:02:426 | MD | INFO | +0 | Run - Running: D:\hyperspin\Utilities\Xpadder\Xpadder.exe /C 21:46:02:487 | MD | INFO | +62 | Process - WaitClose Xpadder.exe 2 21:46:02:593 | MD | WARNING | +110 | RunXpadder - No profiles found and nothing to tell Xpadder to load 21:46:02:593 | MD | INFO | +0 | RunXpadder - Ended 21:46:02:593 | MD | INFO | +0 | RunKeymapper - Ended 21:46:02:593 | MD | INFO | +0 | Keymapper - Loading External AHK Keymapping 21:46:02:593 | MD | INFO | +0 | CheckFile - Checking if D:\RocketLauncher\Module Extensions\AhkLauncher.exe exists 21:46:02:594 | MD | INFO | +0 | RunAHKKeymapper - Started 21:46:02:594 | MD | INFO | +0 | GetAHKProfile - Started 21:46:02:594 | MD | INFO | +0 | GetAHKProfile - Ended and no profile found 21:46:02:594 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 21:46:02:597 | MD | INFO | +0 | RunAHKKeymapper - Ended 21:46:02:597 | MD | INFO | +0 | StartModule - Started 21:46:02:597 | MD | INFO | +0 | StartModule - MEmu: Nestopia MEmuV: v1.42 MURL: http://www.emucr.com/2011/09/nestopia-unofficial-v1420.html MAuthor: djvj MVersion: 2.0.4 MCRC: 6F80AA06 iCRC: F9662CA1 MID: MSystem: "Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System" 21:46:02:597 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Nintendo Entertainment System" 21:46:02:598 | MD | INFO | +0 | PluginInit - Started 21:46:02:598 | MD | INFO | +0 | CheckFile - Checking if D:\hyperspin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml exists 21:46:02:602 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 21:46:02:603 | MD | INFO | +0 | BuildAssetsTable - Ended 21:46:02:603 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 21:46:02:658 | MD | INFO | +62 | BuildAssetsTable - Ended 21:46:02:658 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 21:46:02:659 | MD | INFO | +0 | BuildAssetsTable - Ended 21:46:02:659 | MD | INFO | +0 | PluginInit - Ended 21:46:02:659 | MD | INFO | +0 | - Started with mode: START 21:46:02:659 | MD | WARNING | +0 | - You have your path set to defined, but it could not be found here: 21:46:02:662 | MD | INFO | +0 | StartModule - Ended 21:46:02:667 | MD | INFO | +0 | Run - Running: D:\hyperspin\Emulators\Nintendo Entertainment System\nestopia.exe "D:\hyperspin\Emulators\Nintendo Entertainment System\roms\Super Jeopardy! (USA).ZIP" 21:46:02:702 | MD | INFO | +47 | WinWait - Waiting for "Nestopia ahk_class Nestopia" 21:46:02:856 | MD | INFO | +156 | WinWaitActive - Waiting for "Nestopia ahk_class Nestopia" 21:46:03:415 | MD | INFO | +547 | Process - WaitClose nestopia.exe 21:46:12:365 | MD | INFO | +8953 | CloseProcess - Started, user requested to end launched application 21:46:12:365 | MD | INFO | +0 | WinClose - Closing: Nestopia ahk_class Nestopia 21:46:12:737 | MD | INFO | +375 | CloseProcess - Ended 21:46:12:848 | MD | INFO | +110 | ExitModule - Started 21:46:12:848 | MD | INFO | +0 | Starting Updating Statistics: 21:46:13:002 | MD | INFO | +156 | Game section statistics updated. 21:46:13:002 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 21:46:13:002 | MD | INFO | +0 | GetJoystickArray - Started 21:46:13:003 | MD | INFO | +0 | GetJoystickArray - Ended 21:46:13:003 | MD | INFO | +0 | RunXpadder - Started 21:46:13:003 | MD | INFO | +0 | Process - Exist JoyToKey.exe 21:46:13:006 | MD | INFO | +0 | Run - Running: D:\hyperspin\Utilities\Xpadder\Xpadder.exe /C 21:46:13:033 | MD | INFO | +31 | Process - WaitClose Xpadder.exe 2 21:46:13:140 | MD | WARNING | +109 | RunXpadder - No profiles found and nothing to tell Xpadder to load 21:46:13:140 | MD | INFO | +0 | RunXpadder - Ended 21:46:13:140 | MD | INFO | +0 | RunKeymapper - Ended 21:46:13:140 | MD | INFO | +0 | RunAHKKeymapper - Started 21:46:13:140 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 21:46:13:143 | MD | INFO | +0 | RunAHKKeymapper - Ended 21:46:13:143 | MD | INFO | +0 | LoadPreferredControllers - Started 21:46:13:143 | MD | INFO | +0 | GetJoystickArray - Started 21:46:13:144 | MD | INFO | +0 | GetJoystickArray - Ended 21:46:13:144 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 21:46:13:144 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 21:46:13:144 | MD | INFO | +0 | LoadPreferredControllers - Ended 21:46:13:144 | MD | INFO | +0 | - Started with mode: END 21:46:13:144 | MD | WARNING | +0 | - You have your path set to defined, but it could not be found here: 21:46:13:149 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 21:46:13:199 | RL | INFO | +11031 | Main - Module ended, exiting RocketLauncher normally 21:46:13:199 | RL | INFO | +0 | ExitScript - Started 21:46:13:205 | RL | INFO | +0 | ExitScript - Checking what application is currently in focus. 21:46:13:205 | RL | INFO | +0 | ExitScript - HyperSpin is currently active. Proceeding with exit 21:46:13:219 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 21:46:13:234 | RL | INFO | +15 | ExitScript - Restored cursor
ci2own Posted July 21, 2016 Posted July 21, 2016 Do you have xpadder as Frontend profile in RL > GLOBAL > General Settings> Third Party Tab?
