megananthony Posted July 22, 2016 Posted July 22, 2016 Hello, Retroarch loads fade in , bezel and configured controller settings options when using; but when loading game in hs, it boots straight to game( no fade in) and no bezel, and controller will does not work for certain buttons..but game does load. Using for nes. Any suggestions are appreciated Thanks in advance Really diggin this program.. .lots of work though, damn
megananthony Posted July 22, 2016 Author Posted July 22, 2016 Here it is 10:31:36 PM | HyperSpin Started10:31:37 PM | Going FullScreen10:31:37 PM | Checking for updates10:31:37 PM | Update Check Complete10:31:37 PM | Startup program unavailable10:31:37 PM | Playing intro video10:31:38 PM | Menu Mode is multi10:31:38 PM | Loading Main Menu.xml10:31:38 PM | Main Menu.xml successfully loaded10:31:39 PM | Main Menu wheel loaded successfully10:31:39 PM | Loading Nintendo Entertainment System.xml10:31:40 PM | Main Menu.xml successfully loaded10:31:41 PM | Nintendo Entertainment System wheel loaded successfully10:31:42 PM | Launching Game10:31:42 PM | Using HyperLaunch10:31:42 PM | Getting HyperLaunch path10:31:42 PM | HyperLaunch located at J:\Hyperspin\HyperLaunch.exe10:31:42 PM | Running HyperLaunch.exe10:31:42 PM | HyperLaunch Command Line is: J:\Hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"10:31:46 PM | Launching Game10:31:46 PM | Using HyperLaunch10:31:46 PM | Getting HyperLaunch path10:31:46 PM | HyperLaunch located at J:\Hyperspin\HyperLaunch.exe10:31:46 PM | Running HyperLaunch.exe10:31:46 PM | HyperLaunch Command Line is: J:\Hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"10:32:13 PM | Loading Main Menu.xml10:32:13 PM | Main Menu.xml successfully loaded10:32:13 PM | Main Menu wheel loaded successfully10:32:15 PM | Exit program unavailable10:32:15 PM | Quiting Hyperspin10:32:15 PM | Bye!
ghostboo Posted July 22, 2016 Posted July 22, 2016 hey can you help look https://www.youtube.com/watch?v=VYX7HU2xJeU&feature=youtu.be
megananthony Posted July 22, 2016 Author Posted July 22, 2016 I'll check that tomorrow and give you an update. Thank you
megananthony Posted July 23, 2016 Author Posted July 23, 2016 so, i checked it ,,and doublechecked it, and copy and pasted the exe location, with and with out the exe, then just to the folder itself and then back again..no luck IT launched properly in RL but no in HL. Any other suggesions? i took a screenshot of the ini [Main] Menu_Mode=multi Single_Mode_Name=Nintendo Entertainment System Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Nintendo Entertainment System Hyperlaunch_Path=J:\RocketLauncher\RocketLauncher.exe Use_Last_Game=false [Resolution] FullScreen=true Width=800 Height=600 Scanlines_Active=false Scanlines_Image= Scanlines_Scale=2 Scanlines_Alpha=0.1 [Optimizer] CPU_Priority=normal Quality=HIGH Image_Smoothing=true Animated_Backgrounds=true Inter_Backgrounds=false Level1_Backgrounds=true Level2_Backgrounds=true Level3_Backgrounds=false Level4_Backgrounds=false Special_Backgrounds=true Wait_For_Special=false Animated_Artworks=true Level1_Artworks=true Level2_Artworks=true [IntroVideo] Use_Intro=true Stop_On_Keypress=true [Sound] Master_Volume=100 Video_Volume=100 Wheel_Volume=20 Interface_Volume=100 [AttractMode] Active=true Time=60 MaxSpinTime=10 HyperSpin=true Wait_For_Video=false [Keyboard] Key_Delay=true [P1 Controls] Start=13 Exit=27 Up=38 Down=40 SkipUp=37 SkipDown=39 SkipUpNumber=70 SkipDownNumber=86 HyperSpin=32 Genre=71 Favorites=76 [P2 Controls] Start=69 Exit=81 Up=87 Down=83 SkipUp=65 SkipDown=68 SkipUpNumber=74 SkipDownNumber=77 HyperSpin=88 Genre=72 Favorites=90 [P1 Joystick] Enabled=true Joy=0 Threshold=40 Start=Button_2 Exit=Button_3 Up=POV_Up Down=POV_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_5 SkipDownNumber=Button_6 HyperSpin=Button_4 Genre=Button_8 Favorites=Button_7 [P2 Joystick] Enabled=true Joy=1 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [Trackball] Enabled=false Sensitivity=90 [Spinner] Enabled=false Sensitivity=90 [Startup Program] Executable= Paramaters= Working_Directory= WinState= [Exit Program] Executable= Paramaters= Working_Directory= WinState=NORMAL [LEDBlinky] Active=false Path= [HiScore] Active=false Y=550 Delay=2 [HyperLaunch] Last_System=Nintendo Entertainment System Last_Rom=10-Yard Fight (USA, Europe) Exit_Script_Key=~q & ~s Exit_Emulator_Key=Esc Toggle_Cursor_Key=t MultiGame_Key=NumpadSub MultiGame_Select_Key=Enter MultiGame_Exit_Key=Esc Path_To_Daemontools= Path_To_CPWizard= Fade_In_Interrupt_Keys=anykey Keymapper_Path= Keymapper_Profiles_Path=C:\Hyperspin\Keymapper Profiles\
megananthony Posted July 27, 2016 Author Posted July 27, 2016 Got it workn, i reinstalled HS and it just clicked, now if there was only an easy way to match my roms up with the HS list so i can see what's what with what i have. Follow up tips? Thankx uu for the assistance
thcdgaf Posted July 27, 2016 Posted July 27, 2016 Got it workn, i reinstalled HS and it just clicked, now if there was only an easy way to match my roms up with the HS list so i can see what's what with what i have. Follow up tips? Thankx uu for the assistance dons tools
megananthony Posted July 28, 2016 Author Posted July 28, 2016 I dl'd dons tool from the dl section but it gave me a compression error when trying to unzip it (using 7zip). I'll fiddle with it over the next few days and see if I can figure it out
