Aimtrak Guns and PCSX2
sreisig1
I currently have both Aimtrak guns working fine in MAME. I'm wanting to start setting up PCSX2 with the aimtraks. From reading online I see you need the Nuvee plugin and to have your aimtraks in Guncon mode (by holding the A and B buttons while plugging usb into pc) and then the Topgun drivers installed and running.
A guide on how to do all this would be awesome. Also, since booting the guns into Guncon mode essentially changes the way the Aimtrak's work, they wont work anymore in MAME correct, since MAME needs them to work as mouse? Is there a way to have them work automatically depending on which system I happen to launch from Hyperspin? Or will I need to unplug and re-plug them into Guncon mode all the time? Also, unplugging them resets their usb inputs too which would suck having to reconfigure all the time. Any help or points in the right direction would be awesome. Thanks.
Edit: Just a note, I currently have them set up as mouse in MAME. Also reading I don't need the topgun drivers and just the nuvee plugin. Any settings within the nuvee plugin would be great.
