dante Posted February 11, 2014 Posted February 11, 2014 So back in November I decided that I wanted to upgrade my cabinet. So I swapped out the PC, added more contactors and added LEDs, etc. Now when I fire up HyperPin, the tables load fine....but there's not activity from the LEDwiz. No flashing lights, no contactors, nothing. I have everything wired up and fused as per DeeGor's diagrams, but am unsure on how to do a secondary test of the board/functionality. I did download the utility from the LEDWiz site, but wasn't sure if I was using it correctly. I loaded the sample files that it had and created my own and still nothing. Anyways, if anyone has any good advice on how to troubleshoot this, I would appreciate the advice. Dante
boogies2 Posted February 11, 2014 Posted February 11, 2014 When you swapped PC's, did you register your ledwiz ocx file?
dante Posted February 12, 2014 Author Posted February 12, 2014 yes, It's the same hard drive image that was on the old PC, so I just updated the drivers for the motherbord and added a new Ledwiz ini file for the added output. Other than that, no other changes were made. But when I get home this weekend, I will double check to make sure.
