StayPuft Posted July 31, 2016 Posted July 31, 2016 So I'm using JoyToKey to control Hyperspin, but when I launch HyperXMLspin, it doesn't use Rocketlauncher and the JoyToKey profile for Hyperspin is still active. Is there anyway to get HyperXMLspin to launch with Rocketlauncher?
r0man0 Posted August 23, 2016 Posted August 23, 2016 Hi you can use the joy2key option "Associate profiles to target applications" JoyToKey can automatically switch an active profile based on the current focused application. (Menu: Settings -> Associate profiles with applications...) HyperXMLspin run as standalone app without launcher (hyperlaunch or rocketlauncher) You can also use the options from hyperxmlspin : onstart & onexit : select exe to launch : joy2key.exe type your parameters on fields onexit & onstart params :"your_joy2key_profile.cfg" --> don't forget the "" ;-)
ninja2bceen Posted August 23, 2016 Posted August 23, 2016 Yes it should work, mine is at least. I'm hammering out the bugs of the updated version for Windows 10 specifically with Romano in regards to a few other things. It's a very good app Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
