supergameco Posted August 3, 2016 Posted August 3, 2016 Hi all, Just having some issues using HyperSpin 1.4.16. Whenever I load a Fusion based ROM (SMS, Genesis, Game Gear), the screen goes black for 1 second and then returns to HyperSpin. The ROM loads but is minimised and I need to switch to it manually. If I hold down the Enter key for a second or two as opposed to just tapping it to load the ROM, it loads fine. It's the exact same issue this dude has: http://www.rlauncher.com/forum/showthread.php?1800-Problem-when-using-Hyperspin-with-RL&p=15931#post15931 I haven't tried 1.4.10 as I can't seem to find it. Thanks.
epayson85 Posted August 3, 2016 Posted August 3, 2016 I use fusion and don't have this issue at all. Is your rocketlauncher up to date? Also is it actually minimized or is hyperspin just on top of it? Try running hyperspin in windowed mode and see if you see the desktop or fusion behind hyperspin. If it is you might try telling rocket launcher to minimize or even suspend hyperspin at the launch of fusion. I don't have to do this so it really shouldn't be the issue but see if it fixes it.
supergameco Posted August 3, 2016 Author Posted August 3, 2016 I use fusion and don't have this issue at all. Is your rocketlauncher up to date? Also is it actually minimized or is hyperspin just on top of it? Try running hyperspin in windowed mode and see if you see the desktop or fusion behind hyperspin. If it is you might try telling rocket launcher to minimize or even suspend hyperspin at the launch of fusion. I don't have to do this so it really shouldn't be the issue but see if it fixes it. Thanks for the suggestions. I've tried it in windowed mode and and Fusion actually minimises. So weird.
