Controllers Failing to Initialize
abodetti
Hi Guys,
I'm having an issue with my controllers working. Everything was up and running perfectly, then I temporarily moved my HyerSpin folder and even though it is back where it belongs my controllers aren't working with HS.
When I check the log text file it says the controllers failed to initialize.
Any advice? I'm running 1.4.16
I did them through HyperHQ. Everything worked normally for months, then I moved my folder and now that I moved it back, the controllers work in game, but not in hyperspin.
The settings are correct for the controller mapping and ID.
Here is the log:
"08:19:17 AM |  HyperSpin Started
08:19:17 AM |  Going FullScreen
08:19:17 AM |  Checking for updates
08:19:17 AM |  Update Check Complete
08:19:17 AM |  Startup program unavailable
08:19:17 AM |  Playing intro video
08:19:20 AM |  Error intializing joysticks
08:19:20 AM |  Menu Mode is multi
08:19:20 AM |  Loading Main Menu.xml
08:19:20 AM |  Main Menu.xml successfully loaded
08:19:20 AM |  Main Menu wheel loaded successfully
08:19:34 AM |  Loading Namco Classics.xml
08:19:34 AM |  roms_only is true, checking files
08:19:34 AM |  Main Menu.xml successfully loaded
08:19:35 AM |  Namco Classics wheel loaded successfully
08:19:41 AM |  Loading Main Menu.xml
08:19:41 AM |  Main Menu.xml successfully loaded
08:19:42 AM |  Main Menu wheel loaded successfully
08:19:44 AM |  Exit program unavailable
08:19:44 AM |  Quiting Hyperspin
08:19:44 AM |  Bye! "
  • 2 years later...
Did you manage to solve this? I’m getting the same error, error initialising joysticks. My log reads the same as yours.
Any advice would be appreciated.
thanks in advance.
