MameUI64 .176 - Input layout
dedos
Hello everyone,
I'm using MameUI64 for my .176 mame rom set.
The issue is that I have an X-arcade tank stick and I'm trying select the x-arcade.cfg file under Controllers > default input layout, but I only have the "default" option available.
All the cfg files are under the ctrlr folder and all parameters are pointing correctly in the ini file.
I even tried to change it in the .ini file manually but no luck.
I was going to send an email to mameui but they don't have any contact info
Any ideas?
if it's a bug, can I just use a an earlier version of mameui64?  like .175 or 174?  I know .146 does not have this issue.
Thanks in advanced.
-Dedos
"We were all newbies once...."
i noticed same thing.  in Mame64 i also could not change the controller settings from within the games. When i hit Tab an go to controller settings the options are all the way at the bottom of the screen.
i ended up going back to Mameuifx 175 and thins work normally.
Thanks for the reply.  I'll give mameuifx175 a try.
Which version of mameui64 did you try?  175? or 176?
Thank you.
-Dedos
exactly waht i needed, thank you!  I will download and report back.
Thanks again.
-Dedos
Has anyone else experienced the same controller issues with their X-Arcade Tankstick after upgrading to .176?    Even with the proper XML files, that issue is still on going.
Thanks Newbie, good to know.
Just an update:
Until they fix it in Mame, i went back to MameUI64 version .175 and it allowed me to select the xarcade config.  It's working now.
Now if I could only get hyperspin to work with the xarcade properly.
I started a new thread here:
http://www.hyperspin-fe.com/topic/27629-hyperspin-and-xarcade-tank-stick/
Thanks everyone!
