zephyr1286 Posted August 23, 2016 Posted August 23, 2016 How's everyone, I just installed the new Hyperspin release with Rocketlauncher a couple of days ago. I have everything pretty much figured out following SimplyAustin's instructions which are pretty much dead on. When I installed Mame and loaded the roms on rocket launcher and launch after auditing everything works fine. I have Windows 8 on the computer I bought to build the system. I ran into some issues when it updated to 8.1 so I reverted back to Windows 8. I do know that the rom path has to be accurate in order for Hyperspin to detect Rocketlauncher and run the rom. On my computer all the files are not labeled as .ini or.exe, so all the files just have the names of the file without those at the end. If I do add the .ini or .exe everything does not work correctly. The launch path for me is A:\RocketLauncher\RocketLauncher, but when I used that at first it could not detect rom path. I deleted everything and replaced all of Hyperspin and now it does not do anything when I press enter to open the rom selected. I know the buttons are configured correctly since I can hit Enter and go into the different emulators on Hyperspin. When I do go into the Settings to change the launch path to A:\RocketLauncher\RocketLauncher.exe and try to open a Mame rom I get a message saying CAN NOT FIND A:\RocketLauncher\RocketLauncherUI\Databases\MAME\MAME.xml If I change the RocketLauncher file to RocketLauncher.exe then the RocketLauncherUI does not work. I appreciate all the help I can get. Before I decided to write this post I exhausted all efforts to get it to worked. I followed other forum post and still nothing. Thanks
zephyr1286 Posted August 23, 2016 Author Posted August 23, 2016 Wow, After all those hours of troubleshooting and doing different things it was that simple. I should of known also, makes perfect sense but you get side tracked and blind after a while of messing with it. It is working perfectly now. Thank You
griffin518 Posted September 2, 2016 Posted September 2, 2016 Ok so this is really weird... I'm now having the same issue, but the only thing I've done is copy my install from one machine to another. I've confirmed the path, plugin, etc. Still won't work. Everything launches fine from RocketLauncher, and it still works properly on the first machine. Does anyone have any ideas? My logs are below. 08:59:49 AM | HyperSpin Started 08:59:49 AM | Going FullScreen 08:59:49 AM | Checking for updates 08:59:49 AM | Update Check Complete 08:59:49 AM | Startup program unavailable 08:59:49 AM | Playing intro video 08:59:52 AM | Error intializing joysticks 08:59:52 AM | Menu Mode is multi 08:59:52 AM | Loading Main Menu.xml 08:59:52 AM | Main Menu.xml successfully loaded 08:59:52 AM | Main Menu wheel loaded successfully 08:59:54 AM | Loading MAME.xml 08:59:55 AM | Main Menu.xml successfully loaded 08:59:55 AM | MAME wheel loaded successfully 08:59:57 AM | Launching Game 08:59:57 AM | Using HyperLaunch 08:59:57 AM | Getting Launcher path 08:59:57 AM | Launcher located at C:\Arcade\RocketLauncher\RocketLauncher.exe 08:59:57 AM | Running Launcher 08:59:57 AM | Launcher Command Line is: C:\Arcade\RocketLauncher\RocketLauncher.exe "MAME" "1942" 09:00:09 AM | Loading Main Menu.xml 09:00:09 AM | Main Menu.xml successfully loaded 09:00:10 AM | Main Menu wheel loaded successfully 09:00:12 AM | Exit program unavailable 09:00:12 AM | Quiting Hyperspin 09:00:12 AM | Bye! [code] 08:59:57:932 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 08:59:58:077 | RL | INFO | +141 | Main - System Specs: RocketLauncher Dir: C:\Arcade\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 8126.48 MB Free Memory: 3873.43 MB Used Memory: 4253.059 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: AMD Mobility Radeon HD 5000 Series GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 15.201.1151.1008 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: USB Audio Device Sound 2 Status: Enabled Sound 3 Device: AMD High Definition Audio Device Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [58hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 08:59:58:077 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\RocketLauncher.exe exists 08:59:58:078 | RL | INFO | +0 | Main - Raw CLI received: "MAME 1942" 08:59:58:078 | RL | INFO | +0 | Main - Loading Front End Plugin: "RocketLauncherUI" 08:59:58:078 | RL | INFO | +0 | Process.Process - "Exist" "RocketLauncherUI.exe" 08:59:58:078 | RL | INFO | +0 | Main - RocketLauncherUI.exe is not currently running 08:59:58:078 | RL | INFO | +0 | Main - RocketLauncher received "MAME" and "1942" 08:59:58:101 | RL | INFO | +31 | Main - Found a "Games Options.ini" file, loading it into memory. 08:59:58:102 | RL | INFO | +0 | Main - 1942 is using the default emulator: MAMEUIFX 08:59:58:102 | RL | INFO | +0 | Main - Checking for a [MAMEUIFX] section in C:\Arcade\RocketLauncher\Settings\MAME\Emulators.ini 08:59:58:102 | RL | INFO | +0 | Main - Checking for a [MAMEUIFX] section in C:\Arcade\RocketLauncher\Settings\Global Emulators.ini 08:59:58:102 | RL | INFO | +0 | Main - Found [MAMEUIFX] in C:\Arcade\RocketLauncher\Settings\Global Emulators.ini 08:59:58:103 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\Modules\MAME\MAME.ahk exists 08:59:58:109 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 08:59:58:109 | RL | INFO | +0 | Main - 1942 will use module: C:\Arcade\RocketLauncher\Modules\MAME\MAME.ahk 08:59:58:124 | RL | WARNING | +16 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\Arcade\RocketLauncher\Settings\Global RocketLauncher.ini" 08:59:58:125 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\Arcade\RocketLauncher\Settings\MAME\RocketLauncher.ini" 08:59:58:180 | RL | INFO | +62 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 08:59:58:180 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\Emulators\MAMEUIFX\MAMEUIFX64.exe exists 08:59:58:180 | RL | INFO | +0 | Main - INI Keys read 08:59:58:180 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\Module Extensions\7z.exe exists 08:59:58:180 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\Module Extensions\7z.dll exists 08:59:58:203 | RL | INFO | +16 | Main - "1942" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 08:59:58:203 | RL | INFO | +0 | CheckPaths - Started 08:59:58:204 | RL | INFO | +0 | CheckPaths - Looking for rom: C:\Arcade\ROMs\MAME\1942.zip 08:59:58:204 | RL | INFO | +0 | CheckPaths - Found rom: C:\Arcade\ROMs\MAME\1942.zip 08:59:58:204 | RL | INFO | +0 | CheckPaths - Ended 08:59:58:206 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 08:59:58:206 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 08:59:58:206 | RL | WARNING | +0 | BuildScript - "C:\Arcade\RocketLauncher\Lib\User Functions Init.ahk" not found 08:59:58:206 | RL | INFO | +0 | BuildScript - Validating module 08:59:58:220 | RL | INFO | +16 | BuildScript - Validation complete 08:59:58:241 | RL | INFO | +31 | BuildScript - Loaded Multi-Player scripts 08:59:58:241 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 08:59:58:241 | RL | WARNING | +0 | BuildScript - "C:\Arcade\RocketLauncher\Lib\User Functions.ahk" not found 08:59:58:241 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 08:59:58:257 | RL | INFO | +16 | Main - Module is built 08:59:58:257 | RL | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\AutoHotkey.dll exists 08:59:58:258 | RL | INFO | +0 | Main - Running module 08:59:58:565 | MD | INFO | +N/A | Module initialized 08:59:58:566 | MD | INFO | +0 | StartModule - Started 08:59:58:566 | MD | INFO | +0 | StartModule - MEmu: MAME MEmuV: v0.166 MURL: http://www.mame.net/ MAuthor: djvj,faahrev,brolly,Tomkun MVersion: 2.3.7 MCRC: 5C737136 iCRC: 25E2CCF MID: MSystem: "AAE","Aamber Pegasus","Acorn Electron","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Apple II","Apple IIGS","Applied Technology MicroBee","Atari 8-Bit","Atari 2600","Atari 5200","Atari 7800","Atari Classics","Atari Jaguar","Atari Lynx","Bally Astrocade","Bandai Super Vision 8000","Bandai WonderSwan","Bandai WonderSwan Color","Bit Corporation Gamate","Camputers Lynx","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore 64","Commodore MAX Machine","Creatronic Mega Duck","Data East Classics","EACA EG2000 Colour Genie","Emerson Arcadia 2001","Entex Adventure Vision","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Fujitsu FM-7","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","HBMAME","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Jupiter Ace","Konami Classics","LaserDisc","Magnavox Odyssey 2","MAME","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","MGT Sam Coupe","Midway Classics","Milton Bradley MicroVision","Namco Classics","Namco System 22","NEC PC-8801","NEC PC Engine","NEC PC Engine-CD","NEC SuperGrafx","NEC TurboGrafx-16","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Advance","Nintendo Game Boy Color","Nintendo Pokemon Mini","Nintendo Satellaview","Nintendo Super Famicom","Nintendo Super Game Boy","Nintendo Virtual Boy","Othello Multivision","PacMAME","Philips CD-i","Philips VG 5000","Philips Videopac Plus G7400","RCA Studio II","Sega 32X","Sega CD","Sega Classics","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Model 1","Sega Pico","Sega Saturn","Sega SC-3000","Sega SG-1000","Sega ST-V","Sega VMU","Sharp X1","Sinclair ZX81","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo AES","SNK Neo Geo CD","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo Pocket Color","Sony PlayStation","Sony PocketStation","Sord M5","Soundic Victory MPT-02","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Texas Instruments TI 99-4A","Tiger Game.com","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" 08:59:58:566 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "MAME" 08:59:58:566 | MD | INFO | +0 | PluginInit - Started 08:59:58:566 | MD | INFO | +0 | CheckFile - Checking if C:\Arcade\RocketLauncher\RocketLauncherUI\Databases\MAME\MAME.xml exists 09:00:08:670 | MD | ERROR | +10110 | ScriptError - Cannot find C:\Arcade\RocketLauncher\RocketLauncherUI\Databases\MAME\MAME.xml 09:00:08:670 | MD | INFO | +0 | ExitModule - Started 09:00:08:670 | MD | INFO | +0 | Starting Updating Statistics: 09:00:08:826 | MD | INFO | +156 | Game section statistics updated. 09:00:08:826 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 09:00:08:873 | RL | INFO | +10609 | Main - Module ended, exiting RocketLauncher normally 09:00:08:873 | RL | INFO | +0 | ExitScript - Started 09:00:08:889 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 09:00:08:916 | RL | INFO | +31 | ExitScript - Restored cursor [/code] Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
griffin518 Posted September 2, 2016 Posted September 2, 2016 nevermind... I solved it. For some reason my gobal settings front-end path got reset. This is really weird. Thanks anyway! Edit: ok, so here's the scoop. I've copied everything across my home network (vs using a USB drive) and for some reason Windows 10's homegroup sharing prevents me from seeing/copying the Global Bezel.ini, Global RocketLauncher.ini, and RocketLauncher.ini files. So everything was getting reset as RLUI was recreating them at "first execution". What a huge pain! I dug my USB drive out and am re-copying everything now. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
pspencer801 Posted September 4, 2016 Posted September 4, 2016 Help my problem is this I have followed Austin video everythin seems in order, rocketlauncer works, hyperspin says cant find launcer,when I load a rom. rRocket pointed to frontend / active for hyperspin , Games are green ,settin.ini changed (gensis test subject, using fusion (retroarch doesnt like my computer) everything works in rocket)
pspencer801 Posted September 4, 2016 Posted September 4, 2016 On 9/4/2016 at 3:33 PM, agent47 said: Can you post your HyperSpin log? It's the log.txt file inside your HyperSpin folder. 08:48:30 AM | HyperSpin Started 08:48:30 AM | Going FullScreen 08:48:31 AM | Checking for updates 08:48:31 AM | Update Check Complete 08:48:31 AM | Startup program unavailable 08:48:31 AM | Playing intro video 08:48:50 AM | Menu Mode is multi 08:48:50 AM | Loading Main Menu.xml 08:48:50 AM | Main Menu.xml successfully loaded 08:48:50 AM | Main Menu wheel loaded successfully 08:49:00 AM | Loading Sega Genesis.xml 08:49:00 AM | Main Menu.xml successfully loaded 08:49:01 AM | Sega Genesis wheel loaded successfully 08:49:12 AM | Launching Game 08:49:12 AM | Using HyperLaunch 08:49:12 AM | Getting Launcher path 08:49:12 AM | Launcher located at C:\Users\pspencer801\Desktop\RocketLauncher\RocketLauncher.exe 08:49:12 AM | Running Launcher 08:49:12 AM | Launcher Command Line is: C:\Users\pspencer801\Desktop\RocketLauncher\RocketLauncher.exe "Sega Genesis" "Addams Family Values (Europe)" 08:49:53 AM | Quiting Hyperspin 08:49:53 AM | Bye! This time it said something about no gensis database in rocket sega.xml I think never loaded the rom
pspencer801 Posted September 4, 2016 Posted September 4, 2016 On 9/4/2016 at 4:04 PM, agent47 said: RocketLauncher is properly connected, although you should really have it installed on the root of a drive instead of your desktop to avoid those really long file paths. For the database error follow the instructions in post #2. Think you very much all good
Tite379 Posted October 3, 2016 Posted October 3, 2016 Hi, First and foremost I am a newbie and I have been researching building a cabinet for some time now, more so the programs behind the build. So I started on getting the programs installed (HS/RLUI) and all new updates. Everything works fine on RL but when I load up HS and find the game and hit enter nothing happpens. On RL general settings I do have the default front end set to the path of Hyperspin.exe and have the default plugin set to HS. I've watched countless hrs of videos read forums and I'm not the type to ask for help but I've tried everything and I'm sure it's something simple. Any help would be greatly appreciated. Here is my log of HS and I know I should have HS in the root of the drive 07:23:18 PM | HyperSpin Started 07:23:18 PM | Going FullScreen 07:23:19 PM | Checking for updates 07:23:19 PM | Update Check Complete 07:23:19 PM | Startup program unavailable 07:23:19 PM | Playing intro video 07:23:22 PM | Menu Mode is multi 07:23:22 PM | Loading Main Menu.xml 07:23:22 PM | Main Menu.xml successfully loaded 07:23:23 PM | Main Menu wheel loaded successfully 07:23:25 PM | Loading MAME.xml 07:23:25 PM | Main Menu.xml successfully loaded 07:23:26 PM | MAME wheel loaded successfully 07:23:32 PM | Launching Game 07:23:32 PM | Using HyperLaunch 07:23:32 PM | Getting Launcher path 07:23:32 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 07:23:32 PM | Launcher located at C:\Users\Home\Documents\Hyperspin\HyperLaunch.exe 07:23:32 PM | Running Launcher 07:23:32 PM | Launcher Command Line is: C:\Users\Home\Documents\Hyperspin\HyperLaunch.exe "MAME" "tekken3" 07:23:36 PM | Loading Main Menu.xml 07:23:36 PM | Main Menu.xml successfully loaded 07:23:36 PM | Main Menu wheel loaded successfully 07:23:37 PM | Exit program unavailable 07:23:37 PM | Quiting Hyperspin 07:23:37 PM | Bye!
Tite379 Posted October 3, 2016 Posted October 3, 2016 Hi, Yes I figured it out right after I posted that I knew something was wrong with it, it just took me awhile to see it. I appreciate your help.
