hyperspin info
viper360
Latest hyperspin and rocket launcher using an older version of mame?
So i got mame,md,and nes working but when i came to adding my neo geo i got a dll error non existing function error. Now none of the systems work at all. I belive that this is due to outdated files its reading.
This is my third time setting hs up in the last month so before i start again i could do with some info on what may be the problem, im following austins guide from a year ago and iv also read comments that he sets it up differently in his vids he dosent delete the moduels or hyperlaunch is this the problem or is it the mame im using thanks
Neo Geo, unless you're doing a true AES build, is ultimately just a different MAME wheel using the exact same roms and the same emulator as your MAME does. As such, unless you've changed something else in between setting up systems, it should just work as long as your MAME works.
Here's a clean walkthrough. It's still in progress but it covers exactly what you need in as short a time as possible to get everything working.
Thanks mate i will follow this guide tonight and let you know. Should i save my media,emulators, and utilities folders from hyperspin and media folder from rocketlauncher thanks
