megatron99 Posted September 9, 2016 Posted September 9, 2016 Hello everybody I just set up MAME and is working perfectly but I want to play some SNES games and cant figure out how to map my buttons. I'm running Hyperspin 1.4 and Rocketlaucher. I'm using the Ipac2 and its configure as a keyboard. I'm running the Ipac2 as a keyboard because when I was using it as a gamepad the hyperspin frontend would not work properly. thanks
kylecp1979 Posted September 9, 2016 Posted September 9, 2016 Just go to your settings then inputs and set your buttons up there. If you don't have any cores loaded that should be your default settings. Retroarch will automatically set controls for each core after that. Just remember to turn on save when exiting. If you have settings per system save the setting then rename it to the system name rocketlauncher uses. Example you have custom setting for genesis you want to save it and have rocketlauncher load if for you. Rename the setting to Sega Genesis and keep it in the config folder.
