drewbo81 Posted September 17, 2016 Posted September 17, 2016 I have been setting up hyperspin and hyper marquee and everything is working fantastic except I cannot seem to get system images to change. I only have static image when i am on main menu wheel in HS. All games in every other wheel change as programmed to do so. Any help is appreciated. thank you in advance, Drew
danwelsh Posted September 17, 2016 Posted September 17, 2016 Double check your settings in HM.....and make sure you are using the [system] wildcard I'm lovin my arcade
drewbo81 Posted September 17, 2016 Author Posted September 17, 2016 wildcard is being used...it seems to me that it doesnt recognize main menu as system because every other wheel works. Any other thoughts? It is driving me insane.
drewbo81 Posted September 17, 2016 Author Posted September 17, 2016 2:23:03 PM | HyperMarquee Initiating 2:23:06 PM | Paramters Loaded. 2:23:06 PM | P1 - Debug Mode: True 2:23:06 PM | P2 - Marquee Style: Marquee_Artwork 2:23:06 PM | P3 - System: MAME 2:23:06 PM | P4 - Game: HyperMarquee 2:23:06 PM | Window POS (TOP-Left): 0-1920 2:23:06 PM | Theme Initialisation Error: Value cannot be null. Parameter name: libVlcDllsDirectory 2:23:06 PM | HyperMarquee Loaded. 2:23:06 PM | HyperList Data Table not found:R:\Arcade\Databases\[system]\[system].xml 2:23:07 PM | Can't find game artwork (R:\Arcade\Mame\marquees\HyperMarquee.png) from parameter - Will try to display Game Theme if required. System.NullReferenceException: Object reference not set to an instance of an object. at Hyper_Marquee.ApplicationConfig.RefreshText() at Hyper_Marquee.ApplicationConfig.FontOutlineThicknessTB_TextChanged(Object sender, TextChangedEventArgs e) Exception caught. Object reference not set to an instance of an object. Object reference not set to an instance of an object. Object reference not set to an instance of an object. Parameter is not valid. Object reference not set to an instance of an object. Parameter is not valid. Object reference not set to an instance of an object. Parameter is not valid. Object reference not set to an instance of an object. 2:23:24 PM | HyperMarquee Initiating 2:23:24 PM | Paramters Loaded. 2:23:24 PM | P1 - Debug Mode: True 2:23:24 PM | P2 - Marquee Style: Marquee_Artwork 2:23:24 PM | P3 - System: MAME 2:23:24 PM | P4 - Game: HyperMarquee 2:23:24 PM | Window POS (TOP-Left): 0-1920 2:23:24 PM | Can't find game artwork (R:\Arcade\Mame\marquees\HyperMarquee.png) from parameter - Will try to display Game Theme if required.
danwelsh Posted September 17, 2016 Posted September 17, 2016 When you set up a new HM and went to edit then to the artwork tab. What does your path say there. For example mine says D:/hyperspin/media/[system]/images/wheel/[filename].png I'm lovin my arcade
drewbo81 Posted September 17, 2016 Author Posted September 17, 2016 my path is similar except arcade in place of hyperspin
danwelsh Posted September 17, 2016 Posted September 17, 2016 my path is similar except arcade in place of hyperspin Post your question here http://www.hyperspin-fe.com/topic/9012-hypermarquee/ and sevenseal or antos will help you I'm lovin my arcade
