Golden tee fore complete not finding IDE drive?
condor8
I am having an issue with Golden Tee Fore Complete. I can get it to launch just fine in Mameui64 but when I try to launch from RL or HS it will not get past the detecting Hard drive screen in the rom saying it cannot locate the IDE drive. In Mame it finds it right away. Does anyone know why this is happening?
Thank you
You need to have all the chd files.
gtfore06
gtfore05c
gtfore05b
gtfore05a
gtfore05
gtfore04a
gtfore04
gtfore03a
gtfore03
gtfore02
gtfore01
Then you need all the roms
gtfore01.zip
gtfore03a.zip
gtfore04.zip
gtfore04a.zip
gtfore05.zip
gtfore05a.zip
gtfore05b.zip
gtfore05c.zip
gtfore06.zip
gtfore03.zip
gtfore02.zip
If you can't find all the roms you can copy the iteagle.zip bios and rename it to what you need. It contents all the golden tee fore versions inside of it.
Thanks for the reply. I already have iteagle and the chd for gtfore06 chd. It works when I launch from Mameui64 but does not from RL or HS. Why will it not launch from RL or HS?
Only thing that comes to mind is that RL is reading a different ini file then mame is and trying to load those settings instead. I'm not really sure
Try looking through your RL log and see what paths its loading.
Has this been answered? I have the CHD for gtfore04,05 and 06complete and I'm having the same issue.
works fine in mameui but not thru rocket launcher, seemes to be the chd files only that arent working. and everything is setup to see chd
Are your roms showing up in green or red in rocketlauncher? If they are red you need copy iteagle.zip and rename the copy to what your missing. You also need the CHD file for that game.
Then rocketlauncher should pickup the right game for you and load that game for you in rocketlauncher
its showing up green now but when it launches, mameuix is saying not game found and the closest match is the same game I'm trying to launch then it will show a handful of other games after you keep clicking okay.
the games launch just fine in mame by itself with no problem
I have the chds for 2004,2005, 2006 complete
I got it working, apparently the golden tee games were renamed in the new database and was different than the previous.
Instead of full name golf_fore_2006_v06.00.01 or whatever is was simply gtfore06
once I backed up the chd files somewhere else I renamed then and it works fine now.....all except the sound is either really low or not at all
Yeah I have sound issues too I don't think there is a way around that.
If you would of read my first post you would of known the names of all the roms and CHD files.
I really won't just rename old MAME roms to work with new MAME emulator versions. You want to get the new set / update set each time.
I don't believe the mame rom set come's with all the golden tee fore roms so you have to rename iteagle to those roms.
Golden tee games are chds. You really shouldn't be renaming any MAME roms or chds.
Chds never show up in an RLUI audit, because of the way they are named. And they need to stay named as they are.
Even though they won't show in the rlui audit they will still launch.
How do you get them to launch if they don't show up in RL??? Do you add the chd to the database?
Tones is right, you shouldn't be renaming anything. If you have Skip Checks set to Rom Only in RLUI for MAME as the module suggests the chd games will be red but launch fine. I just ran gtfore06 from RLUI with no problems at all.
Good to know thank you!
If you set the 2nd dip switch in the game itself, it goes into an "operator mode"
All my Golden Tee Fore games were deflated at 10% sound
Once I cranked it up to 85% it sounds like the other Mame games
