emulator moves behind hyperlaunch - can't figure out what causing it
pman77
So recently out of nowhere I got the weird problem i cant seem to figure out. When i launch any emulator from RocketLauncher.1.0.3 it launches the game with no issues however a random times it will move the game to the back behind hypersin. so the game is playing and i can hear it but it was automatically moved behind hyperspin. This happens at random times and while im not playing the game or pressing any buttons. alt tab will bring it to the front.
I have spent a lot of time looking around the hyperlaunch settings and everything is pretty much the default and there is nothing that sticks out at my. idle time is set to zero, i have things in full screen mode etc no bezels etc. I did enable log troubleshooting but again there was nothing there that indicates an issue. At this point im lost as to what the emulators hide behind hypersin.
Im hoping someone ha some suggestions on what i can try.
TIA, :(
p
  • 4 weeks later...
I have had similar issues. It only happens with my pc games and type x. I solved the type x problem by running the affected games windowed, with a bezel. The pc games i just changed the resolution in game, or run windowed. It was games starting in 1024x768 resolution that caused my particular problem. Good luck!
  • 1 month later...
I had this problem and I can't tell you the definite answer. I can tell you the things I remember reading and trying and 1 of them should be the answer.
Make sure your emulator is launching in a resolution that matches your screen outside of hyperspin. Make sure the emulator launches roms in fullscreen outside of hyperspin.
ended up upgrading to rocketlauncher and it fixed the issue. i suspect it was a bug in the previous hyperlaunch. thanks for replying.
