Rocket Launcher ROM directory issue
NiteSite
So my rocketlauncher UI Global settings showing:
Base Rom Path: ..\Roms
Any roms for systems I change change it for ALL system
So I change Atari 2600 to:
Base Rom Path: ..\Roms\Atari 2600
now all my systems show:
Even the Global directory.
Any Idea as to what I am doing wrong?!?
If you want to set per system rom paths you do it on the Emulators tab in the Rom Path section.
The Base Rom Path is a global setting where you can set the root of your roms folder and if your system rom folders match the system name in RLUI you don't have to set the rom path for that system.
Ugh such a simple solution thank you!
