Help with startup script for gamepad support.
SupraKarma
Apologies in advance for what is probably an easy solution that I have overlooked. I've searched for over an hour and I'm still having problems.
I can't get the startup script to work properly. A little error message pops up that says:
HyperSpin Startup Script.exe
  Error: "C:\Users\(my name)\AppData\Local\Temp" is not a valid key name.
                Line#
--->          3438: Hotkey,*$%HS_Exit_hkey%Navigation_Controls_Nothing,Off
The current thread will exit.
Then an "OK" box to close it. It looks more or less just like I've typed it though. Any help would be greatly appreciated, I don't like having to use X-Padder!
Edit: Figured it out, had to revert back to default keyboard values in HyperHQ.
This script isn't all I was hoping it would be. It's slow loading the first time, and if  your controller configuration changes from a 2 player setup to a 1 player setup (e.g. two wireless PS3 controllers and one of them gets shut off), you're going to have to reboot to make it work right again.
I hate to gripe on my first post, but how could an interface as advanced as HyperSpin totally miss the mark on something as simple as controls?
X-Padder adds in a whole new layer of complexity and causes problems that nobody should have to deal with, if only the controllers actually worked. You should be able to plug and play multiple controllers, and it should switch over instantly like it does in RetroArch.
Just saying. Glad HyperSpin exists but the lack of working controls sucks hard.
