Main wheel now only uses controller 2?
tscottn
Hi Guys,
I have a question,
My hyperspin setup has been working fine for months with no issues at all, then all of a sudden controller 1 stopped working to move browse the main wheel.  for a few hours I couldn't get it to work at all after multiple reboots.  then I had the idea to turn on controller number 2 and see if that works.  Well, low and behold, controller 2 works only when the system sees it as the second controller - meaning controller 1 needs to be turned on as well.  Its weird because controller 1 was working as my main controller since I set it up and now all of a sudden the system will only use number 2 to browse the main wheel.
Once a game is selected however , all controllers function normally.  If anyone can shed some light on what might be the issue, I would greatly appreciate it.
A little info about my setup,
Windows 7,
xbox 360 wireless controller x2
hyperspin 1.4
xpadder for in game mapping
hyperspin startup script for main wheel browsing
thanks again
AFAIK HS only allows 2 controllers in it's interface along with a keyboard (mapper)
Though I don't know this bug, I do have 2 360 controllers and since win10 I sometimes have an issue that the 1st controller I connect goes to player 2 or 3 and the 2nd one I turn on to 3 or 4. There is a solution to get em back to 1 and 2 but I can't quite recall. Haven't had the issue in a while. This was outside of HS, just checking if this might be the issue even though you run win7.
