ticmike Posted December 3, 2016 Posted December 3, 2016 Ive downloaded 2 different full rom sets for Snes but when I audit its not finding any. So I then downloaded single games then it found those ones, all zipped just like the others, any ideas whats up??
ticmike Posted December 3, 2016 Author Posted December 3, 2016 Hmmm strange as the set said Hyperspin ready (from Pleasuredome and the other set was from Emuparadise) the single games that worked are from EmuPa to? I'll have to try different ones till one works lol, im just starting out here ;-) can u tell. Thanks for the reply
ticmike Posted December 3, 2016 Author Posted December 3, 2016 This might help with the problem im having. All the zipped ones dont show up in the audit. The Mario game does and you can see the file settings as I hover over in the pictures. The Mega Man game has the exact same settings as the Mario game but does not appear in the audit??? Im having a similar issue with Master System. Im baffled!!! Please heeeelp.
ticmike Posted December 3, 2016 Author Posted December 3, 2016 On 12/3/2016 at 8:33 PM, agent47 said: Unless you're using a custom database most of those roms will not show because they don't match the database names. None of them have region tags and "Megaman X (USA)" should be "Mega Man X (USA)". You'll also want to check to see what those files marked as "WinZip" files actually are. If they're rar files they won't show even if they're named correctly because rar isn't listed as a valid extension in RL. If I were you I would use the Rename ROMs app in Don's Tools from the Downloads section to rename your roms to match the database. Expand Ar right, i'll check that out, thanks for the info and help im new to this to its all a learning curve. On the plus side I have managed to set up MAME and Genesis
ticmike Posted December 3, 2016 Author Posted December 3, 2016 The ones on the winzip files are .smc files once opened
