Mame 64 NoNag + Hi-score v.180??
Visitor Q
Is there no newer compiled versions of Mame after .174 that support Hi-Score? I can't seem to find anything newer than .174 that supports hi-scores...
7 minutes ago, agent47 said:
MAME has supported hiscore natively for a little while now so you just need a nonag version.
Great! I have been away for a while and I guess I missed this. Thank you!
Now I just need to figure out why mine are not saving or load previous ones.
Any thoughts on that? Any chances that need to be made since they switched over?
In the mame.ini under the Core Misc Options section set the "plugin" value to hiscore.
I'm not sure I see that.
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
5 minutes ago, agent47 said:
What version of MAME are you using?
.180 but I just always copy and paste the old version over the new one, then update the .exe with the no nag. So I created a new .ini with the new version and now I see it. I guess I need to update my mame.ini.
