Mame lightgun games xpadder mouse to joystick?
rastan
Is there any way to actually play lightgun games using mouse to joystick?
I mean obviously I have already setup my xpadder to control the mouse movements with my analog stick and have changed my mame.ini to use the mouse for lightgun games. the issue is using the joystick to control the mouse... makes the movement way too fast and even setting the mame game settings for sensitivity and speed, etc. does nothing when using the joystick to control the mouse as the movement is still too fast to actually play the game (operation wolf in this case) I should note that using my mouse pad on the the keyboard works perfectly and smooth... I just wish the analog stick in my controller or even d-pad was as smooth when playing lighgun games using xpadder to map the mouse.
Any help or suggestions?
Best I could do is play with some of the settings within Xpadder... there are settings for dead zone/less responsive and you can even change it from 4 way to 8 way, etc.. some of those settings helped but it's still way too fast. there probably is a 3rd party app to make the joystick - mouse less sensitive but it's probably not worth it.
