DonaldMacdonald Posted December 23, 2016 Posted December 23, 2016 Hi I'm a bit new but basically I'm up and running but I'm suddenly getting CTDs quite frequently. I used an install of hyperspin, rocket launcher and mame that I had on an external hard drive and then just changed the file locations where needed. I am now getting an issue where HS crashed hard to desktop and I dont have a taskbar either. I have followed a guide to prevent Windows 10 accidentaly going into tablet mode but the crashing persists. Also some module errors. Any help would be greatly appreciated and here some warnings from the RL logs. RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\Global RocketLauncher.ini" RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "D:\RocketLauncher\Settings\MAME\RocketLauncher.ini" BuildScript - "D:\RocketLauncher\Lib\User Functions\Global.ahk" not found BuildScript - "D:\RocketLauncher\Lib\User Functions\MAME.ahk" not found BuildScript - "D:\RocketLauncher\Lib\User Functions\Emulators\MAME.ahk" not found BuildScript - "D:\RocketLauncher\Lib\User Functions\MAME\Emulators\MAME.ahk" not found BuildScript - "D:\RocketLauncher\Lib\User Functions\MAME\hsf2.ahk" not found StartModule - You have an unsupported System Name for this module: "MAME". Only the following System Names are suppported: " Module - "MAME" is not a known console or computer system. Defaulting to MAME's Arcade mode for the remainder of this MAME module.
DonaldMacdonald Posted December 23, 2016 Author Posted December 23, 2016 6 minutes ago, agent47 said: The BuildScript warnings are nothing to worry about, those are just checking to see if you added any custom code to be executed. The last 2 warnings are the intended operations of the MAME module. The module checks if the system name matches one that needs special parameters and if it doesn't it defaults to the standard MAME arcade game parameters. When you say HyperSpin is crashing is it actually HyperSpin crashing or is it RocketLauncher? Once you select a game RL takes over. If you could be more specific which program is crashing and when the crashes occur that would be helpful. If you could post a full RL Troubleshooting log to pastebin and link to it here that would help as well. Also make sure you're able to run games through MAME directly outside of RL and HS. It's possible that you don't have some of the required runtimes on your pc or there's some sort of video issue. Knowing if it runs normally through the emu directly will help to narrow down the potential causes. Thanks Agent47 I believe it to be HS that is crashing as I can force it by flicking between games in my MAME list, being in the game hasn't seemed to cause an issue. I also am using a version of mame64 so it will run a game from RL, HS but not directly from the MAME.exe itself as I haven't set up rom directories in the emulator as it seems to want me to put all my roms in the emulator's ROMS folder and I dont want to do that. Here is the pastebin: http://pastebin.com/HXk7041f
DonaldMacdonald Posted December 23, 2016 Author Posted December 23, 2016 Yeah like you said it doesn't show much and yeah the crashes seem to be quite random. 01:12:33 AM | HyperSpin Started 01:12:33 AM | Going FullScreen 01:12:33 AM | Checking for updates 01:12:33 AM | Update Check Complete 01:12:33 AM | Startup program unavailable 01:12:33 AM | Playing intro video 01:12:35 AM | Error intializing joysticks 01:12:35 AM | Menu Mode is single 01:12:35 AM | Loading MAME.xml 01:12:35 AM | roms_only is true, checking files 01:12:36 AM | MAME.xml successfully loaded 01:12:36 AM | MAME wheel loaded successfully 01:12:45 AM | MAME wheel loaded successfully 01:12:45 AM | MAME wheel loaded successfully 01:12:46 AM | MAME wheel loaded successfully 01:12:46 AM | MAME wheel loaded successfully 01:13:04 AM | Launching Game 01:13:04 AM | Using HyperLaunch 01:13:04 AM | Getting Launcher path 01:13:04 AM | Launcher located at D:\RocketLauncher\RocketLauncher.exe 01:13:04 AM | Running Launcher 01:13:04 AM | Launcher Command Line is: D:\RocketLauncher\RocketLauncher.exe "MAME" "eswat" 01:14:05 AM | MAME wheel loaded successfully 01:14:05 AM | MAME wheel loaded successfully 01:14:06 AM | MAME wheel loaded successfully 01:14:06 AM | MAME wheel loaded successfully 01:14:06 AM | MAME wheel loaded successfully 01:14:06 AM | MAME wheel loaded successfully 01:14:07 AM | MAME wheel loaded successfully 01:14:07 AM | MAME wheel loaded successfully 01:14:08 AM | MAME wheel loaded successfully 01:14:08 AM | MAME wheel loaded successfully 01:16:30 AM | MAME wheel loaded successfully 01:16:30 AM | MAME wheel loaded successfully 01:16:30 AM | MAME wheel loaded successfully 01:16:30 AM | MAME wheel loaded successfully 01:16:31 AM | MAME wheel loaded successfully 01:16:31 AM | MAME wheel loaded successfully 01:16:31 AM | MAME wheel loaded successfully 01:16:31 AM | MAME wheel loaded successfully 01:16:32 AM | MAME wheel loaded successfully 01:16:32 AM | MAME wheel loaded successfully 01:16:32 AM | MAME wheel loaded successfully 01:16:32 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:33 AM | MAME wheel loaded successfully 01:16:34 AM | MAME wheel loaded successfully 01:16:34 AM | MAME wheel loaded successfully 01:16:34 AM | MAME wheel loaded successfully 01:16:34 AM | MAME wheel loaded successfully 01:16:35 AM | MAME wheel loaded successfully 01:16:35 AM | MAME wheel loaded successfully 01:17:21 AM | MAME wheel loaded successfully 01:17:22 AM | MAME wheel loaded successfully
DonaldMacdonald Posted December 28, 2016 Author Posted December 28, 2016 So after a clean install of everything then coming across this problem I realised I didn't have .net4.0 installed! New issue.. When playing metal slug 5 the front end took over the screen and mame got minimised even though I was in game. Any reason this might happen?
