SOLVED: Games chugging / slow fps sound etc when launching from HS
nlen83
Hey guys I've been working for a good 2-3 hundred hours on my bartop arcade at this point and I'm losing my mind now.
Curious to know if my build is strong enough to run HS with dolphin / pcsx2 / PPSSPP in particular. As it stands I have settings well above native res but I don't see why this isn't running smoothly as it runs SMOOTH outside of HS directly from the emulator or launched from rocket launcher. Anyways, this is what I've got going :
Windows 7 pro
G3258 at 4.1ghz
8gb ddr3 1600
GTX 750TI
I'm hoping I'm not capping out my two cores with the emulators and throwing HS in the mix is taking it past its limits...
Anything you guys got would be truly appreciated. Just a heads up, I have disabled aero and adjusted all optimization options to bare minimum etc with next to no difference in performance.
I just wanted to take a quick moment to try and help anyone who is having an issue similar to what I had...
This may be common knowledge but I happened to find out that by setting an NVIDIA PROFILE FOR EACH EMULATOR in question FIXED my problem.
MAKE SURE YOU SET THE OPTION IN THE PROFILE TO "PREFER MAXIMUM PERFORMANCE" INSTEAD OF SOMETHING LIKE "OPTIMAL"
I saved myself $350 by doing this as I was about to purchase a 4790k thinking it was the processor bottlenecking...
If anyone sees this and this isnt mentioned in a slow down/poor performance thread, I would recommend adding this information as this has probably created a lot of unnecessary headaches.
