help with renaming files
chefishman
Oops... so  i used hyperspin checker to rename some  zipped files in mygames folder. I failed to realize i am supposed to only use this program on  unzipped files. So now my issue is the zipped file shows up in the xml database, but the file inside still needs to be renamed. My main question Is there a tool that can rename the contents of my zipped game file  to match and be the same as the name of the zip file its in. Or am I better off starting over with a fresh download, new folder of files to unzip , rename, and re zip each file 1 by
You can just unzip everything, rename, then zip everything all at once. There's an option when compressing to name the zips after the files. Also, for any emulator that can natively run compressed games, it will often work if the zip matches the database even if its contents do not so long as 7z is toggled off for the system in RLUI.
