demonseed Posted January 19, 2017 Posted January 19, 2017 Hey Guys, I have this emulator setup via retroarch however when I try to load a game I get an error. Is there a tutorial on how to setup this emulator? I am not sure the issue I have. I have posted my log. 22:25:32:947 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com) 22:25:32:948 | RL | WARNING | +0 | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 22:25:32:950 | RL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 22:25:32:951 | RL | WARNING | +0 | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching. 22:25:33:347 | RL | INFO | +406 | Main - System Specs: RocketLauncher Dir: E:\Rocketlauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 8016.31 MB Free Memory: 1132.13 MB Used Memory: 6884.188 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel(R) HD Graphics GPU 1 RAM: -1924.00 MB GPU 1 Driver Version: 9.17.10.3347 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled Sound 3 Device: Bluetooth Hands-free Audio Sound 3 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1080 work) [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 22:25:33:349 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists 22:25:33:351 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.0.1.4 LegalCopyright ©2015 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2063360 bytes Created: 5/23/2015 - 10:53:13 PM Modified: 11/26/2015 - 12:43:10 AM 22:25:33:352 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Array.ahk exists 22:25:33:359 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:363 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 4924 bytes Created: 11/26/2015 - 12:43:11 AM Modified: 11/26/2015 - 12:43:11 AM 22:25:33:364 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists 22:25:33:382 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:384 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5077 bytes Created: 5/24/2015 - 8:27:48 AM Modified: 11/26/2015 - 12:42:57 AM 22:25:33:386 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists 22:25:33:389 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/24/2015 - 8:26:42 AM Modified: 1/2/2014 - 10:27:34 PM 22:25:33:390 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists 22:25:33:394 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:396 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5474 bytes Created: 9/6/2015 - 8:32:14 PM Modified: 9/6/2015 - 8:32:14 PM 22:25:33:398 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists 22:25:33:401 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:404 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 5/24/2015 - 8:26:30 AM Modified: 4/29/2013 - 1:56:02 PM 22:25:33:405 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists 22:25:33:409 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:411 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/24/2015 - 7:02:39 AM Modified: 1/13/2013 - 5:07:30 PM 22:25:33:413 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists 22:25:33:424 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:426 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5895 bytes Created: 5/24/2015 - 8:25:59 AM Modified: 6/28/2015 - 6:41:33 AM 22:25:33:428 | RL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.2 22:25:33:430 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists 22:25:33:431 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 13090816 bytes Created: 5/24/2015 - 8:25:19 AM Modified: 1/6/2015 - 9:20:42 PM 22:25:33:433 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists 22:25:33:435 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 5/24/2015 - 8:24:07 AM Modified: 6/14/2013 - 2:06:21 PM 22:25:33:437 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists 22:25:33:441 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:443 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 5/24/2015 - 8:27:37 AM Modified: 12/23/2014 - 11:02:37 PM 22:25:33:445 | RL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 22:25:33:446 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists 22:25:33:450 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:452 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 5/24/2015 - 8:26:08 AM Modified: 5/5/2013 - 2:22:25 PM 22:25:33:453 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists 22:25:33:457 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:458 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4904 bytes Created: 5/24/2015 - 8:26:27 AM Modified: 3/22/2015 - 2:51:41 PM 22:25:33:460 | RL | DEBUG1 | +0 | Origin.ahk Version: 1.0.2 22:25:33:462 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists 22:25:33:465 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:467 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 5/24/2015 - 8:28:09 AM Modified: 5/8/2014 - 3:06:39 AM 22:25:33:471 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists 22:25:33:475 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:477 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 5/24/2015 - 8:28:04 AM Modified: 6/5/2013 - 6:56:23 PM 22:25:33:478 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists 22:25:33:481 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 5/24/2015 - 8:27:30 AM Modified: 11/26/2015 - 12:43:04 AM 22:25:33:482 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists 22:25:33:497 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:499 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5347 bytes Created: 5/24/2015 - 8:28:20 AM Modified: 3/22/2015 - 2:52:25 PM 22:25:33:501 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2 22:25:33:502 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists 22:25:33:508 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:25:33:510 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 5/24/2015 - 8:26:53 AM Modified: 3/1/2013 - 9:05:47 PM 22:25:33:512 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists 22:25:33:519 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:522 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3833 bytes Created: 5/24/2015 - 8:28:38 AM Modified: 1/13/2015 - 8:16:56 PM 22:25:33:524 | RL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 22:25:33:525 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists 22:25:33:529 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:531 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29149 bytes Created: 5/29/2015 - 11:47:30 PM Modified: 11/26/2015 - 12:42:55 AM 22:25:33:532 | RL | DEBUG1 | +0 | 7z.ahk Version: 1.0.2 22:25:33:534 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists 22:25:33:539 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:541 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 104277 bytes Created: 5/24/2015 - 8:28:01 AM Modified: 11/26/2015 - 12:42:57 AM 22:25:33:543 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.7 22:25:33:544 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists 22:25:33:561 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:563 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 38251 bytes Created: 5/24/2015 - 8:26:50 AM Modified: 11/26/2015 - 12:43:06 AM 22:25:33:564 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.1.4 22:25:33:566 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists 22:25:33:581 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:583 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1065 bytes Created: 5/24/2015 - 8:27:38 AM Modified: 11/26/2015 - 12:43:12 AM 22:25:33:585 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.2 22:25:33:586 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists 22:25:33:592 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:594 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81174 bytes Created: 5/24/2015 - 8:27:41 AM Modified: 11/26/2015 - 12:43:12 AM 22:25:33:596 | RL | DEBUG1 | +16 | Fade Animations.ahk Version: 1.1.10 22:25:33:597 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists 22:25:33:602 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:604 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33453 bytes Created: 5/24/2015 - 8:28:11 AM Modified: 5/30/2015 - 9:18:27 PM 22:25:33:606 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.2 22:25:33:607 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists 22:25:33:611 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:613 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 3461 bytes Created: 5/24/2015 - 8:26:35 AM Modified: 5/30/2015 - 9:18:57 PM 22:25:33:614 | RL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.4 22:25:33:616 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists 22:25:33:621 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:622 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40753 bytes Created: 5/24/2015 - 8:24:03 AM Modified: 9/6/2015 - 8:32:13 PM 22:25:33:625 | RL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.8 22:25:33:626 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists 22:25:33:630 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:631 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 5/24/2015 - 8:28:32 AM Modified: 4/14/2013 - 1:33:19 PM 22:25:33:633 | RL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 22:25:33:634 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists 22:25:33:655 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:657 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 66452 bytes Created: 5/24/2015 - 8:23:41 AM Modified: 11/26/2015 - 12:42:52 AM 22:25:33:659 | RL | DEBUG1 | +16 | MultiPlayer.ahk Version: 1.0.7 22:25:33:660 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists 22:25:33:669 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:671 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 392193 bytes Created: 5/24/2015 - 8:26:19 AM Modified: 11/26/2015 - 12:43:03 AM 22:25:33:673 | RL | DEBUG1 | +0 | Pause.ahk Version: 1.1.5 22:25:33:674 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists 22:25:33:678 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:680 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 553 bytes Created: 5/24/2015 - 8:24:21 AM Modified: 9/6/2015 - 8:31:51 PM 22:25:33:681 | RL | DEBUG1 | +0 | Pause Init.ahk Version: 1.0.3 22:25:33:683 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists 22:25:33:696 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:698 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10025 bytes Created: 5/24/2015 - 8:24:18 AM Modified: 9/6/2015 - 8:31:55 PM 22:25:33:700 | RL | DEBUG1 | +0 | Password.ahk Version: 1.0.2 22:25:33:701 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists 22:25:33:708 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:710 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 74101 bytes Created: 5/24/2015 - 8:23:41 AM Modified: 11/26/2015 - 12:42:54 AM 22:25:33:712 | RL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.6 22:25:33:713 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists 22:25:33:719 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:721 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 139893 bytes Created: 5/24/2015 - 8:26:27 AM Modified: 11/26/2015 - 12:43:02 AM 22:25:33:723 | RL | DEBUG1 | +0 | Shared.ahk Version: 1.3.5 22:25:33:724 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists 22:25:33:728 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:730 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26143 bytes Created: 5/24/2015 - 8:26:45 AM Modified: 4/9/2015 - 4:16:56 AM 22:25:33:731 | RL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.3 22:25:33:733 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists 22:25:33:755 | RL | DEBUG1 | +32 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:758 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 5/24/2015 - 8:28:01 AM Modified: 12/23/2014 - 11:23:48 PM 22:25:33:759 | RL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 22:25:33:761 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists 22:25:33:766 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:768 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 18329 bytes Created: 5/29/2015 - 11:47:33 PM Modified: 11/26/2015 - 12:42:58 AM 22:25:33:770 | RL | DEBUG1 | +0 | Virtual Drive.ahk Version: 1.0.3 22:25:33:772 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists 22:25:33:777 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:779 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26540 bytes Created: 5/24/2015 - 8:28:26 AM Modified: 9/6/2015 - 8:32:04 PM 22:25:33:781 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.4 22:25:33:782 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists 22:25:33:786 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:25:33:788 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1063 bytes Created: 5/24/2015 - 8:26:46 AM Modified: 9/6/2015 - 8:31:50 PM 22:25:33:790 | RL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.2 22:25:33:792 | RL | DEBUG1 | +0 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: E:\Hyperspin\HyperSpin.exe 22:25:33:794 | RL | DEBUG1 | +0 | Main - Raw CLI received: "NEC PC-FX Blue Chicago Blues (Japan) (Disc 2)" 22:25:33:795 | RL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "Blue Chicago Blues (Japan) (Disc 2)" 22:25:33:798 | RL | DEBUG1 | +0 | Main - dbName: Blue Chicago Blues (Japan) (Disc 2) 22:25:33:799 | RL | INFO | +15 | Main - Loading Front End Plugin: "HyperSpin" 22:25:33:802 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 22:25:33:804 | RL | INFO | +0 | Main - RocketLauncher received "NEC PC-FX" and "Blue Chicago Blues (Japan) (Disc 2)" 22:25:33:811 | RL | INFO | +0 | Main - Did not find a "E:\Rocketlauncher\Settings\NEC PC-FX\Game Options.ini" file, skipping any game-specific options. 22:25:33:813 | RL | INFO | +0 | Main - Blue Chicago Blues (Japan) (Disc 2) is using the default emulator: RetroArch 22:25:33:814 | RL | INFO | +0 | Main - Checking for a [RetroArch] section in E:\Rocketlauncher\Settings\NEC PC-FX\Emulators.ini 22:25:33:816 | RL | INFO | +16 | Main - Checking for a [RetroArch] section in E:\Rocketlauncher\Settings\Global Emulators.ini 22:25:33:818 | RL | INFO | +0 | Main - Found [RetroArch] in E:\Rocketlauncher\Settings\Global Emulators.ini 22:25:33:821 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk exists 22:25:33:822 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 45403 bytes Created: 5/24/2015 - 8:28:10 AM Modified: 11/26/2015 - 12:43:12 AM 22:25:33:827 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 22:25:33:828 | RL | INFO | +0 | Main - Blue Chicago Blues (Japan) (Disc 2) will use module: E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk 22:25:33:842 | RL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 22:25:33:844 | RL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\retroarch.exe exists 22:25:33:846 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 1655808 bytes Created: 8/16/2015 - 9:32:24 AM Modified: 7/19/2015 - 12:21:23 AM 22:25:33:848 | RL | INFO | +0 | Main - INI Keys read 22:25:33:849 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists 22:25:33:852 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 5/24/2015 - 8:26:40 AM Modified: 11/26/2015 - 12:42:56 AM 22:25:33:854 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists 22:25:33:856 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 5/24/2015 - 8:28:28 AM Modified: 11/26/2015 - 12:43:05 AM 22:25:33:859 | RL | INFO | +0 | Main - "Blue Chicago Blues (Japan) (Disc 2)" qualifies for MultiGame. 22:25:33:861 | RL | INFO | +0 | CheckPaths - Started 22:25:33:862 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).bin 22:25:33:864 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).bin 22:25:33:865 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:868 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).smc 22:25:33:869 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).smc 22:25:33:871 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:872 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).7z 22:25:33:874 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).7z 22:25:33:876 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:877 | RL | DEBUG1 | +15 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).zip 22:25:33:879 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).zip 22:25:33:880 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:882 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).sfc 22:25:33:883 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).sfc 22:25:33:885 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:886 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).gba 22:25:33:888 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).gba 22:25:33:889 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:891 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).gb 22:25:33:892 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).gb 22:25:33:894 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:33:895 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).a78 22:25:33:897 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).a78 22:25:33:898 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:900 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).sv 22:25:33:901 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).sv 22:25:33:903 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:905 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).gbc 22:25:33:906 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).gbc 22:25:33:908 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:33:909 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rpk 22:25:33:911 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).rpk 22:25:33:913 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:916 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).gme 22:25:33:918 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).gme 22:25:33:925 | RL | DEBUG1 | +15 | CheckPaths - Rom not found 22:25:33:927 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).sc 22:25:33:928 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).sc 22:25:33:930 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:931 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).cdt 22:25:33:933 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).cdt 22:25:33:934 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:935 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ws 22:25:33:937 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).ws 22:25:33:938 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:940 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).wsc 22:25:33:941 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).wsc 22:25:33:943 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:944 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ngp 22:25:33:946 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).ngp 22:25:33:947 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:948 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ngc 22:25:33:950 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).ngc 22:25:33:951 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:953 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).vms 22:25:33:954 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).vms 22:25:33:956 | RL | DEBUG1 | +15 | CheckPaths - Rom not found 22:25:33:958 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ipf 22:25:33:959 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).ipf 22:25:33:962 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:963 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).n64 22:25:33:965 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).n64 22:25:33:966 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:968 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).z64 22:25:33:970 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).z64 22:25:33:971 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:33:973 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).sg 22:25:33:974 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).sg 22:25:33:976 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:977 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).fds 22:25:33:979 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).fds 22:25:33:980 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:982 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).caq 22:25:33:983 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).caq 22:25:33:985 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:987 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).vb 22:25:33:988 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).vb 22:25:33:990 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:991 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).vec 22:25:33:993 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).vec 22:25:33:994 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:996 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).wav 22:25:33:998 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).wav 22:25:33:999 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:33:000 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).cas 22:25:34:002 | RL | DEBUG1 | +15 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).cas 22:25:34:004 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:005 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).min 22:25:34:007 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).min 22:25:34:009 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:010 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).int 22:25:34:012 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).int 22:25:34:013 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:015 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rom 22:25:34:016 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).rom 22:25:34:018 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:34:019 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).tap 22:25:34:021 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).tap 22:25:34:023 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:024 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).tzx 22:25:34:026 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).tzx 22:25:34:027 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:029 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).nes 22:25:34:030 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).nes 22:25:34:032 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:034 | RL | DEBUG1 | +15 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).col 22:25:34:035 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).col 22:25:34:037 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:038 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).nds 22:25:34:040 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).nds 22:25:34:041 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:042 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).cpr 22:25:34:044 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).cpr 22:25:34:046 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:047 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).gg 22:25:34:048 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).gg 22:25:34:050 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:34:051 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).pce 22:25:34:053 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).pce 22:25:34:055 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:057 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).st2 22:25:34:058 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).st2 22:25:34:059 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:061 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).sms 22:25:34:063 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).sms 22:25:34:064 | RL | DEBUG1 | +16 | CheckPaths - Rom not found 22:25:34:066 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).smc 22:25:34:067 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).smc 22:25:34:069 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:070 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).lnx 22:25:34:072 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).lnx 22:25:34:073 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:076 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).md 22:25:34:077 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).md 22:25:34:079 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:080 | RL | DEBUG1 | +15 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).32x 22:25:34:082 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).32x 22:25:34:083 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:085 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).n64 22:25:34:086 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).n64 22:25:34:089 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:091 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).a52 22:25:34:093 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).a52 22:25:34:094 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:096 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).j64 22:25:34:098 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).j64 22:25:34:099 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:101 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).cso 22:25:34:102 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).cso 22:25:34:104 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:108 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).cue 22:25:34:110 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).cue 22:25:34:111 | RL | DEBUG1 | +15 | CheckPaths - Rom not found 22:25:34:113 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).iso 22:25:34:115 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).iso 22:25:34:117 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:118 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ccd 22:25:34:120 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).ccd 22:25:34:121 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:123 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).chd 22:25:34:128 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).chd 22:25:34:130 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:132 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).bin 22:25:34:133 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2)\Blue Chicago Blues (Japan) (Disc 2).bin 22:25:34:135 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:25:34:136 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar 22:25:34:141 | RL | INFO | +0 | CheckPaths - Found rom: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar 22:25:34:142 | RL | DEBUG1 | +16 | CheckPaths - Current romName: Blue Chicago Blues (Japan) (Disc 2) 22:25:34:144 | RL | DEBUG1 | +0 | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX 22:25:34:146 | RL | DEBUG1 | +0 | CheckPaths - Current romExtension: .rar 22:25:34:147 | RL | INFO | +0 | CheckPaths - Ended 22:25:34:150 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 pluginPath = E:\Rocketlauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.0.1.4 rlAuthor = djvj rlURL = www.rlauncher.com langFile = E:\Rocketlauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 5384 frontendPath = E:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E: exitEmulatorKey = ~Esc|H3:1joy6 restoreFE = Restore and Click exitScriptKey = ~q & ~s toggleCursorKey = Esc emuFullPath = E:\Hyperspin\Emulators\Retroarch\retroarch.exe emuPath = E:\Hyperspin\Emulators\Retroarch emuName = RetroArch emuExt = exe romPath = E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX romPathFromIni = E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX romExtension = .rar romExtensionOrig = .rar romExtensions = bin|smc|7z|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin|rar|iso|cue|cso|img executable = retroarch.exe systemDbName = NEC PC-FX systemName = NEC PC-FX dbPath = dbName = Blue Chicago Blues (Japan) (Disc 2) dbExt = romName = Blue Chicago Blues (Japan) (Disc 2) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = E:\Rocketlauncher\RocketLauncher.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = true logCommandWindow = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = 1 navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdAddDrive = true servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = true hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 5 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = true fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = false fadeImgPath = E:\Rocketlauncher\Media\Fade RLDataPath = E:\Rocketlauncher\Data RLMediaPath = E:\Rocketlauncher\Media RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error modulesPath = E:\Rocketlauncher\Modules moduleFullName = E:\Rocketlauncher\Modules\RetroArch\RetroArch.ahk moduleName = RetroArch modulePath = E:\Rocketlauncher\Modules\RetroArch moduleExtension = ahk moduleExtensionsPath = E:\Rocketlauncher\Module Extensions libPath = E:\Rocketlauncher\Lib 7zEnabled = true 7zPath = E:\Rocketlauncher\Module Extensions\7z.exe 7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll 7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = 1 mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false pauseEnabled = false pauseKey = m pauseBackToMenuBarKey = n pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keymapperEnabled = true keymapperAHKMethod = External keymapper = xpadder xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows) joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default systemProfile = E:\Rocketlauncher\Profiles\xpadder\NEC PC-FX xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\NEC PC-FX\_Default emuProfile = E:\Rocketlauncher\Profiles\xpadder\NEC PC-FX\RetroArch romProfile = E:\Rocketlauncher\Profiles\xpadder\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2) RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\NEC PC-FX ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\NEC PC-FX\RetroArch ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2) ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe mon1O = pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini 22:25:34:153 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 22:25:34:156 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 22:25:34:158 | RL | INFO | +15 | BuildScript - Loaded Statistics Init.ahk scripts 22:25:34:159 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found 22:25:34:161 | RL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 22:25:34:162 | RL | INFO | +0 | BuildScript - Validating module 22:25:34:168 | RL | INFO | +0 | BuildScript - Validation complete 22:25:34:176 | RL | INFO | +16 | BuildScript - Module: MEmu = RetroArch MEmuV = v05-11-2015 Nightly MURL = http://themaister.net/retroarch.html MAuthor = djvj,zerojay MVersion = 2.3.3 MCRC = A2F3BE90 iCRC = 42C3B552 MID = 635038268922229162 MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" ;---------------------------------------------------------------------------- ; Notes: ; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working! ; Devs stated they will never add support for mounted images (like via DT) ; Fullscreen is controlled via the module setting in RocketLauncherUI ; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe). ; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect ; Enable 7z support for archived roms ; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1 ; ; LibRetro DLLs: ; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/ ; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system. ; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores ; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270 ; ; SRM files: ; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm ; ; Save states: ; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save ; ; Config files: ; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI. ; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg). ; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg ; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg. ; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config. ; ; MultiGame: ; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch. ; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind. ; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12. ; ; MESS: ; MESS BIOS roms should be placed in the system\mess folder ; ; System Specific Notes: ; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine. ; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg. ; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg. ; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these. ; NEC TurboGrafx-CD - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg. ; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode. ; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files. ; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory. ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() ; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt. ; 1 - Official System Name in RocketLauncher ; 2 - Short name used only for easy referencing within module ; 3 - Default core ; 4 - The system ID MESS core recognizes Log("Module - Started building the " . MEmu . " object",4) mTypeVar= ( LTrim AAE|LibRetro_AAE|mame_libretro Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464 Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000 APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic Atari 2600|LibRetro_2600|stella_libretro|a2600 Atari 5200|LibRetro_5200|mess_libretro|a5200 Atari 7800|LibRetro_7800|prosystem_libretro|a7800 Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800 Atari Classics|LibRetro_ACLS|mame_libretro Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar Atari Lynx|LibRetro_LYNX|handy_libretro|lynx Atari ST|LibRetro_ST|hatari_libretro Atari XEGS|LibRetro_XEGS|mess_libretro|xegs Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78 Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000 Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor Canon X07|LibRetro_CX07|mess_libretro|x07 Capcom Classics|LibRetro_CAPC|mame_libretro Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro Capcom Play System 2|LibRetro_CPS2|fba_cores_cps2_libretro Capcom Play System 3|LibRetro_CPS3|mame_libretro Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000 Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000 Cave|LibRetro_CAVE|mame_libretro Coleco ADAM|LibRetro_ADAM|mess_libretro|adam ColecoVision|LibRetro_COLEC|mess_libretro|coleco Commodore Amiga|LibRetro_PUAE|puae_libretro Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10 Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck Data East Classics|LibRetro_DATA|mame_libretro Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64 Elektronika BK|LibRetro_EBK|mess_libretro|bk0010 Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64 Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan GamePark 32|LibRetro_GP32|mess_libretro|gp32 GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000 Irem Classics|LibRetro_IREM|mame_libretro JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii Konami Classics|LibRetro_KONC|mame_libretro Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2 MAME|LibRetro_MAME|mame_libretro Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32 Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius Mattel Intellivision|LibRetro_INTV|mess_libretro|intv MGT Sam Coupe|LibRetro_SAMCP|mess_libretro| Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro Microsoft MSX|LibRetro_MSX|bluemsx_libretro Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro Midway Classics|LibRetro_MIDC|mame_libretro Namco Classics|LibRetro_NAMC|mame_libretro Namco System 22|LibRetro_NAM2|mame_libretro NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16 NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16 Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64 Nintendo 64DD|LibRetro_N64|mupen64plus_libretro Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro Nintendo Classics|LibRetro_NINC|mame_libretro Nintendo DS|LibRetro_DS|desmume_libretro Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes Nintendo Famicom|LibRetro_NFAM|nestopia_libretro Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy Nintendo Game & Watch|LibRetro_GW|gw_libretro Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro Panasonic 3DO|LibRetro_3DO|4do_libretro Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1 Philips Videopac|LibRetro_PVID|mess_libretro|videopac RCA Studio II|LibRetro_STUD2|mess_libretro|studio2 SCUMMVM|LibRetro_SCUMM|scummvm_libretro Sega 32X|LibRetro_32X|picodrive_libretro|32x Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd Sega Classics|LibRetro_SEGC|mame_libretro Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro Sega Pico|LibRetro_PICO|picodrive_libretro Sega Saturn|LibRetro_SAT|yabause_libretro Sega Saturn Japan|LibRetro_SAT|yabause_libretro Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000 Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro Sega ST-V|LibRetro_STV|mame_libretro Sega VMU|LibRetro_SVMU|mess_libretro|svmu Sharp X1|LibRetro_SX1|mess_libretro|x1 Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum SNK Classics|LibRetro_SNKC|mame_libretro SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psx Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat Sony PSP|LibRetro_PSP|ppsspp_libretro Sord M5|LibRetro_SORD|mess_libretro|m5 Spectravideo|LibRetro_SV328|mess_libretro|svi328n Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes Taito Classics|LibRetro_TAIC|mame_libretro Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3 Technos|LibRetro_TECHN|mame_libretro Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a Thomson MO5|LibRetro_MO5|mess_libretro|mo5 Thomson TO7|LibRetro_TO7|mess_libretro|to7 Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom Tiki-100|LibRetro_TIKI|mess_libretro|kontiki Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision Watara Supervision|LibRetro_SUPRV|mess_libretro|svision Williams Classics|LibRetro_WILLS|mame_libretro ) mType := Object() Loop, Parse, mTypeVar, `n, `r { obj := {} Loop, Parse, A_LoopField, | If A_Index = 1 obj.System := A_LoopField Else If A_Index = 2 obj.ID := A_LoopField Else If A_Index = 3 obj.Core := A_LoopField Else ; 4 obj.MessID := A_LoopField mType.Insert(obj["System"], obj) } Log("Module - Finished building the " . MEmu . " object",4) ; For easier use throughout the module retroSystem := mType[systemName].System retroID := mType[systemName].ID retroCore := mType[systemName].Core retroMessID := mType[systemName].MessID If !retroSystem ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName) If !retroCore ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.") settingsFile := modulePath . "\" . moduleName . ".ini" core := IniReadCheck(settingsFile, systemName, "LibRetro_Core",retroCore,,1) Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) configFolder := IniReadCheck(settingsFile, "Settings", "ConfigFolder",emuPath . "\config",,1) messRomPath := IniReadCheck(settingsFile, "Settings", "MESS_BIOS_Roms_Folder",,,1) hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1) ejectToggleKey := IniReadCheck(settingsFile, "Settings", "Eject_Toggle_Key",,,1) nextDiskKey := IniReadCheck(settingsFile, "Settings", "Next_Disk_Key",,,1) prevDiskKey := IniReadCheck(settingsFile, "Settings", "Previous_Disk_Key",,,1) superGB := IniReadCheck(settingsFile, systemName . "|" . romName, "SuperGameBoy","false",,1) enableNetworkPlay := IniReadCheck(settingsFile, "Network|" . romName, "Enable_Network_Play","false",,1) overlay := IniReadCheck(settingsFile, systemName . "|" . romName, "Overlay",,,1) videoShader := IniReadCheck(settingsFile, systemName . "|" . romName, "VideoShader",,,1) aspectRatioIndex := IniReadCheck(settingsFile, systemName . "|" . romName, "AspectRatioIndex",,,1) customViewportWidth := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportWidth",,,1) customViewportHeight := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportHeight",,,1) customViewportX := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportX",,,1) customViewportY := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportY",,,1) stretchToFillBezel := IniReadCheck(settingsFile, systemName . "|" . romName, "StretchToFillBezel","false",,1) rotation := IniReadCheck(settingsFile, systemName . "|" . romName, "Rotation",0,,1) cropOverscan := IniReadCheck(settingsFile, systemName . "|" . romName, "CropOverscan",,,1) threadedVideo := IniReadCheck(settingsFile, systemName . "|" . romName, "ThreadedVideo",,,1) vSync := IniReadCheck(settingsFile, systemName . "|" . romName, "VSync",,,1) integerScale := IniReadCheck(settingsFile, systemName . "|" . romName, "IntegerScale",,,1) configurationPerCore := IniReadCheck(settingsFile, systemName . "|" . romName, "ConfigurationPerCore","false",,1) configFolder := GetFullName(configFolder) messRomPath := GetFullName(messRomPath) overlay := GetFullName(overlay) videoShader := GetFullName(videoShader) rotateBezel := false If (retroID = "LibRetro_SGB" || superGB = "true") ; if system or rom is set to use Super Game Boy { superGB = true ; setting this just in case it's false and the system is Nintendo Super Game Boy sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system") CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system") retroID := "LibRetro_SGB" ; switching to Super Game Boy mode retroSystem := "Nintendo Super Game Boy" } ; Find the dll for this system libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll") ; Find the cfg file to use If !FileExist(configFolder) ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder . """") globalRetroCfg := emuPath . "\retroarch.cfg" systemRetroCfg := configFolder . "\" . retroSystem . ".cfg" coreRetroCfg := configFolder . "\" . core . ".dll.cfg" Log("Module - Global cfg should be: " . globalRetroCfg,4) Log("Module - System cfg should be: " . systemRetroCfg,4) Log("Module - Core cfg should be: " . coreRetroCfg,4) foundCfg := If FileExist(systemRetroCfg) { ; check for system cfg first retroCFGFile := systemRetroCfg foundCfg := 1 Log("Module - Found a System cfg!",4) } Else If FileExist(coreRetroCfg) { ; 2nd option is a core config retroCFGFile := coreRetroCfg foundCfg := 1 Log("Module - Found a Core cfg!",4) } Else If FileExist(globalRetroCfg) { ; 3rd is global cfg retroCFGFile := globalRetroCfg foundCfg := 1 Log("Module - Found a Global cfg!",4) } If !foundCfg Log("Module - Could not find a cfg file to update settings. RetroArch will make one for you.",2) Else { Log("Module - " . MEmu . " is using " . retroCFGFile . " as its config file.") retroCFG := LoadProperties(retroCFGFile) } If rotation In 1,3 ; use vertical bezel if RA rotation is set to 90 or 270 degrees rotateBezel := true If RegExMatch(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") { ; these systems require the retroarch settings to be read retroSysDir := ReadProperty(retroCFG,"system_directory") ; read value retroSysDir := ConvertRetroCFGKey(retroSysDir) ; remove dbl quotes StringLeft, retroSysDirLeft, retroSysDir, 2 If (retroSysDirLeft = ":\") { ; if retroarch is set to use a default folder StringTrimLeft, retroSysDir, retroSysDir, 1 Log("Module - RetroArch is using a relative system path: """ . retroSysDir . """") retroSysDir := emuPath . retroSysDir } If !retroSysDir ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.") StringRight, checkForSlash, retroSysDir, 1 If (checkForSlash = "\") ; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders StringTrimRight, retroSysDir, retroSysDir, 1 } If (RegExMatch(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX") || RegExMatch(retroID, "LibRetro_NES") && (InStr(core, "nestopia_libretro"))) { ; these systems will use an ini to store game specific settings sysSettingsFile := CheckSysFile(modulePath . "\" . systemName . ".ini") ; create the ini if it does not exist coreOptionsCFGFile := CheckFile((If configurationPerCore = "true" ? configFolder . "\retroarch-core-options.cfg" : emuPath . "\retroarch-core-options.cfg"), "Could not find retroarch-core-options.cfg in retroarch directory: """ . (If configurationPerCore = "true" ? configFolder : emuPath) . """") coreOptionsCFG := LoadProperties(coreOptionsCFGFile) If InStr(retroID, "LibRetro_N64") { ; Nintendo 64 mupenGfx := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Plugin", "auto",,1) mupenRsp := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_RSP_Plugin", "auto",,1) mupenCpu := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_CPU_Core", "dynamic_recompiler",,1) mupenPak1 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_1", "memory",,1) mupenPak2 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_2", "memory",,1) mupenPak3 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_3", "memory",,1) mupenPak4 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_4", "memory",,1) mupenGfxAccur := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Accuracy", "high",,1) mupenExpMem := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Disable_Exp_Memory", "no",,1) mupenTexturFilt := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Texture_Filtering", "nearest",,1) mupenViRefresh := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Refresh", "2200",,1) mupenFramerate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Framerate", "fullspeed",,1) mupenResolution := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Resolution", "640x480",,1) mupenPolyOffstFctr := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Factor", "-3.0",,1) mupenPolyOffstUnts := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Units", "-3.0",,1) mupenViOverlay := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Overlay", "disabled",,1) mupenAnalogDzone := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Analog_Deadzone", "15",,1) WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1) WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1) WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1) WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1) WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1) WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1) WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1) WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1) WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1) WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1) WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1) WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1) WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1) WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1) WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1) } Else If InStr(retroID, "LibRetro_NES") { ; these systems will use an ini to store game specific settings If InStr(core, "nestopia_libretro") { ; Nestopia nestopiaBlargg := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Blargg_NTSC_Filter", "disabled",,1) nestopiaPalette := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Palette", "canonical",,1) nestopiaNoSprteLimit := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Remove_Sprites_Limit", "disabled",,1) WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1) WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1) WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1) } } Else If InStr(retroID, "LibRetro_LYNX") { ; Atari Lynx If InStr(core, "handy_libretro") { ; Handy handyRotate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Handy_Rotation", "None",,1) If InStr(handyRotate, "240") or InStr(handyRotate, "90") rotateBezel := true WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1) } } Else If InStr(retroID, "LibRetro_PSX") { ; Sony PlayStation psxCdImageCache := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_CD_Image_Cache", """enabled""",,1) psxMemcardHandling := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Memcard_Handling", """libretro""",,1) psxDualshockAnalogToggle := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Dualshock_Analog_Toggle", """enabled""",,1) WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1) WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1) WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1) } SaveProperties(coreOptionsCFGFile, coreOptionsCFG) } hideEmuObj := Object("ahk_class ConsoleWindowClass",0,"RetroArch ahk_class RetroArch",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) mgM3UPath:= romPath . "\" . romTable[1,4] . ".m3u" mgRomExtensions := "cue|iso|ccd" mgValidExtension := false Loop, parse, mgRomExtensions, | If (romExtension = "." . A_LoopField) mgValidExtension := true If (InStr(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated m3uRomIndex := Object() mgType := romTable[1,6] . " " mgMaxIndex := romTable.MaxIndex() mgRomIndex := 0 If FileExist(mgM3UPath) FileDelete, %mgM3UPath% Loop %mgMaxIndex% { If (romTable[A_Index, 3] = romName) { tempType := romTable[A_Index, 5] StringTrimLeft, mgRomIndex, tempType, StrLen(mgType) Log ("Found rom index in rom set in romTable: " . mgRomIndex) break } } If (mgRomIndex > 0) { tempRomIndex := mgRomIndex Loop %mgMaxIndex% { mgTypeIndex := mgType . tempRomIndex m3uRomIndex.Insert(tempRomIndex) Loop %mgMaxIndex% { If (romTable[A_Index, 5] = mgTypeIndex) { tempRomPath := romTable[A_Index, 1] FileAppend, %tempRomPath%`n, %mgM3UPath% Log("Appending rom path to m3u: " . tempRomPath) break } } If (tempRomIndex < mgMaxIndex) tempRomIndex++ Else tempRomIndex := 1 } } } ; MESS core options messParam1 := messParam2 := messParam3 := If InStr(core, "mess") { ; if a mess core is used Log("Module - Retroarch MESS mode enabled") If !retroMessID ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MESS LibRetro core") Else Log("Module - MESS mode using a known ident: " . retroMessID) If !messRomPath ScriptError("Please set the RetroArch module setting ""MESS_BIOS_Roms_Folder"" to the folder that contains your MESS BIOS roms to use MESS with RetroArch.") messParam1 := messParam2 := " -rompath \" . """" . messRomPath . "\" . """" ; Build a key/value object containing the different messParam3 choices messP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","svi328n","cass","pecom64","cass","svmu","quik","gamecom","cart1","mbeeic","quik1") messParam3 := messP3[retroMessID] ; search object for the retroMessID pair messParam3 := " -" . (If messParam3 ? messParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" If retroMessID = mbeeic ; Applied Technology MicroBee { microbeeModel := IniReadCheck(messSysINI, romName, "MicroBee_Model","mbeeic",,1) If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56 ScriptError("This is not a known MicroBee model value: " . microbeeModel) Else If (microbeeModel != "mbeeic") retroMessID := microbeeModel If romExtension in .mwb,.com,.bee mediaDeviceType := "quik1" Else If romExtension in .wav,.tap mediaDeviceType := "cass" Else If romExtension in .rom mediaDeviceType := "cart" Else If romExtension in .dsk mediaDeviceType := "flop1" Else ; .bin format mediaDeviceType := "quik2" messParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" } fullRomPath := messParam1 . messParam2 . messParam3 } Else If (superGB = "true") { Log("Module - Retroarch Super Game Boy mode enabled") fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """" } Else { Log("Module - Retroarch standard mode enabled") fullRomPath := " """ . romPath . "\" . romName . romExtension . """" } If retroID = LibRetro_NFDS ; Nintendo Famicom Disk System { IfNotExist, %retroSysDir%\disksys.rom ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If retroID = LibRetro_SCD ; Sega CD { If romExtension Not In .bin,.cue,.iso ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension) IfNotExist, %retroSysDir%\bios_CD_E.bin ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") IfNotExist, %retroSysDir%\bios_CD_U.bin ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") IfNotExist, %retroSysDir%\bios_CD_J.bin ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If retroID in LibRetro_PCECD,LibRetro_TGCD ; NEC PC Engine-CD and NEC TurboGrafx-CD { If romExtension Not In .ccd,.cue ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) IfNotExist, %retroSysDir%\syscard3.pce ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If retroID = LibRetro_PCFX { If romExtension Not In .ccd,.cue ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) IfNotExist, %retroSysDir%\pcfx.bios ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } networkSession := If (enableNetworkPlay = "true") { Log("Module - Network Multi-Player is an available option for " . dbName,4) netplayNickname := IniReadCheck(settingsFile, "Network", "NetPlay_Nickname","Player",,1) getWANIP := IniReadCheck(settingsFile, "Network", "Get_WAN_IP","false",,1) If (getWANIP = "true") myPublicIP := GetPublicIP() Log("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE",2) defaultServerIP := IniReadCheck(settingsFile, "Network", "Default_Server_IP", myPublicIP,,1) defaultServerPort := IniReadCheck(settingsFile, "Network", "Default_Server_Port",,,1) lastIP := IniReadCheck(settingsFile, "Network", "Last_IP", defaultServerIP,,1) ; does not need to be on the ISD lastPort := IniReadCheck(settingsFile, "Network", "Last_Port", defaultServerPort,,1) ; does not need to be on the ISD mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,,0) If (mpMenuStatus = -1) { ; if user exited menu early Log("Module - Cancelled MultiPlayer Menu. Exiting module.",2) ExitModule() } If networkSession { Log("Module - Using a Network for " . dbName,4) IniWrite, %networkPort%, %settingsFile%, Network, Last_Port ; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort% If (networkType = "client") { IniWrite, %networkIP%, %settingsFile%, Network, Last_IP ; Save last used IP and Port for quicker launching next time netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """" ; -C = connect as client } Else { ; server netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """" ; -H = host as server } Log("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE",2) Log("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """",4) } Else Log("Module - User chose Single Player mode for this session",4) } BezelStart(,,(If rotateBezel ? 1:"")) If foundCfg { If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath) { customViewportWidth := bezelScreenWidth customViewportHeight := bezelScreenHeight customViewportX := 0 customViewportY := 0 aspectRatioIndex := 22 Log("Stretching viewport to fit bezel") } retroCFG := LoadProperties(retroCFGFile) ; load the config into memory raCfgHasChanges := WriteRetroProperty("input_overlay", overlay) WriteRetroProperty("video_shader", videoShader) WriteRetroProperty("aspect_ratio_index", aspectRatioIndex) WriteRetroProperty("custom_viewport_width", customViewportWidth) WriteRetroProperty("custom_viewport_height", customViewportHeight) WriteRetroProperty("custom_viewport_x", customViewportX) WriteRetroProperty("custom_viewport_y", customViewportY) WriteRetroProperty("video_rotation", rotation) WriteRetroProperty("video_crop_overscan", cropOverscan) WriteRetroProperty("video_threaded", threadedVideo) WriteRetroProperty("video_vsync", vSync) WriteRetroProperty("video_scale_integer", integerScale) WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey) WriteRetroProperty("input_disk_next", nextDiskKey) WriteRetroProperty("input_disk_prev", prevDiskKey) If InStr(retroID, "LibRetro_PSX") { Loop, 8 ; Loop 8 times for 8 controllers { p%A_Index%ControllerType := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "P" . A_Index . "_Controller_Type", 517,,1) WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType) } } If raCfgHasChanges { Log("Module - Saving changed settings to: """ . retroCFGFile . """") SaveProperties(retroCFGFile, retroCFG) } } fullscreen := If fullscreen = "true" ? " -f" : "" srmPath := emuPath . "\srm\" . retroSystem ; path for this system's srm files saveStatePath := emuPath . "\save\" . retroSystem ; path for this system's save state files retroCFGFile := If foundCfg ? " -c """ . retroCFGFile . """" : "" IfNotExist, %srmPath% FileCreateDir, %srmPath% ; creating srm dir if it doesn't exist IfNotExist, %saveStatePath% FileCreateDir, %saveStatePath% ; creating save dir if it doesn't exist HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait If InStr(core, "mess") { ; if a mess core is used Run(executable . " """ . (retroMessID ? retroMessID : "") . fullRomPath . """ " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide") } Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case. Run(executable . " " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . fullRomPath . netCommand, emuPath, "Hide") } Else If FileExist(mgM3UPath) { Run(executable . " " . """" . mgM3UPath . """" . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide") } Else { Run(executable . " " . fullRomPath . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide") } mpMenuStatus := If networkSession { canceledServerWait := false multiplayerMenuExit := false SetTimer, NetworkConnectedCheck, 500 If (networkType = "server") { Log("Module - Waiting for a client to connect to your server") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.") } Else { ; client Log("Module - Trying to contact the server to establish a connection.") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...") } If (mpMenuStatus = -1) { ; if user exited menu early before a client connected Log("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.",2) If Process("Exist", executable) Process("Close", executable) ; must close process as the exe is waiting for a client to connect and no window was drawn yet ExitModule() } Else { ; blank response from MultiPlayerMenu, exited properly Log("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server") WinWait("RetroArch ahk_class RetroArch") WinWaitActive("RetroArch ahk_class RetroArch") } SetTimer, NetworkConnectedCheck, Off } Else { ; single player WinWait("RetroArch ahk_class RetroArch") WinWaitActive("RetroArch ahk_class RetroArch") } If hideConsole = true WinSet, Transparent, On, ahk_class ConsoleWindowClass ; makes the console window transparent so you don't see it on exit BezelDraw() HideEmuEnd() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() ; Writes new properties into the retroCFG if defined by user WriteRetroProperty(key,value="") { If (value != "") { Global retroCFG,raCfgHasChanges WriteProperty(retroCFG, key, value,1,1) raCfgHasChanges := 1 } } ; Used to convert between RetroArch keys and usable data ConvertRetroCFGKey(txt,direction="read"){ Global emuPath If direction = read { StringTrimLeft,newtxt,txt,1 ; removes the " from the left of the txt StringTrimRight,newtxt,newtxt,1 ; removes the " from the right of the txt relativeCheck := SubStr(newtxt, 1, 1) If InStr(relativeCheck,":") { ; if the path contains a ":" then it is a relative path Log("ConvertRetroCFGKey - " . newtxt . " is a relative path",4) StringTrimLeft,newtxt,newtxt,1 ; removes the : from the left of the txt newtxt := AbsoluteFromRelative(emuPath, "." . newtxt) ; convert relative to absolute } If InStr(newtxt,"/") StringReplace,newtxt,newtxt,/,\,1 ; replaces all forward slashes with backslashes } Else If direction = write { newtxt = "%txt%" ; wraps the txt with "" If InStr(newtxt,"\") StringReplace,newtxt,newtxt,\,/,1 ; replaces all backslashes with forward slashes } Else ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.") Log("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt,4) Return newtxt } ; This will simply create a new blank ini if one does not exist CheckSysFile(file){ IfNotExist, %file% FileAppend,, %file% Return file } MultiGame: SetKeyDelay(100) WinActivate, ahk_class RetroArch Send, {%ejectToggleKey% down}{%ejectToggleKey% up} ; eject disc in Retroarch If (!mgLastRomIndex) { mgLastRomIndex := mgRomIndex } selectedRomIndex := 0 StringTrimLeft, selectedRomIndex, selectedRomNum, StrLen(mgType) Loop %mgMaxIndex% { If (m3uRomIndex[A_index] = mgLastRomIndex) { tempLastRomIndex := A_index Log("Temp last index: " . tempLastRomIndex) } If (m3uRomIndex[A_index] = selectedRomIndex) { tempSelectedRomIndex := A_index Log("temp selected index: " . tempSelectedRomIndex) } } mgNewIndex := tempLastRomIndex - tempSelectedRomIndex If (mgNewIndex < 0) { mgNewIndex := mgNewIndex * -1 Loop %mgNewIndex% { Log("Sending the next disk key: " . nextDiskKey) Send, {%nextDiskKey% down}{%nextDiskKey% up} } } Else If (mgNewIndex > 0) { Loop %mgNewIndex% { Log("Sending the previous disk key: " . mgNewIndex) Send, {%prevDiskKey% down}{%prevDiskKey% up} } } Send, {%ejectToggleKey% down}{%ejectToggleKey% up} ; close disc in Retroarch mgLastRomIndex := selectedRomIndex Return NetworkConnectedCheck: If clientConnected multiplayerMenuExit := true Else If WinExist("RetroArch ahk_class RetroArch") { Log("Module - RetroArch session started, closing the MultiPlayer menu",4) multiplayerMenuExit := true } Return CloseProcess: FadeOutStart() WinClose("RetroArch ahk_class RetroArch") Return 22:25:34:191 | RL | INFO | +15 | BuildScript - Loaded Multi-Player scripts 22:25:34:194 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 22:25:34:196 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found 22:25:34:197 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 22:25:34:199 | RL | INFO | +0 | Main - Module is built 22:25:34:201 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists 22:25:34:204 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 5/24/2015 - 8:28:11 AM Modified: 4/19/2013 - 6:16:32 PM 22:25:34:207 | RL | INFO | +16 | Main - Hiding taskbar 22:25:34:429 | RL | INFO | +218 | Main - Running module 22:25:34:430 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 22:25:34:568 | MD | INFO | +N/A | Module initialized 22:25:34:570 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:34:572 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 22:25:34:574 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:25:34:575 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:25:34:577 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:25:34:599 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Ended 22:25:34:605 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:34:607 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc, 22:25:34:608 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:25:34:626 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Post loop 2 check 22:25:34:627 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label 22:25:34:629 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:34:634 | MD | DEBUG2 | +0 | Keymapper - Checking for the JoyIDs_Preferred_Controllers key in E:\Rocketlauncher\Settings\NEC PC-FX\Games JoyIDs.ini under section [Blue Chicago Blues (Japan) (Disc 2)] 22:25:34:636 | MD | INFO | +0 | LoadPreferredControllers - Started 22:25:34:637 | MD | DEBUG2 | +0 | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows) 22:25:34:639 | MD | DEBUG2 | +0 | LoadPreferredControllers - Creating a list of currently connected joysticks 22:25:34:640 | MD | INFO | +0 | GetJoystickArray - Started 22:25:34:659 | MD | DEBUG2 | +31 | GetJoystickArray - Joysticks Detected: 0000000000000000 22:25:34:661 | MD | INFO | +0 | GetJoystickArray - Ended 22:25:34:662 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 22:25:34:664 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 22:25:34:665 | MD | INFO | +0 | LoadPreferredControllers - Ended 22:25:34:667 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists 22:25:34:668 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1178624 bytes Created: 6/16/2015 - 11:46:34 AM Modified: 2/2/2014 - 3:10:38 PM 22:25:34:670 | MD | INFO | +0 | Keymapper - Loading xpadder 22:25:34:672 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 22:25:34:691 | MD | INFO | +32 | GetJoystickArray - Started 22:25:34:721 | MD | DEBUG2 | +31 | GetJoystickArray - Joysticks Detected: 0000000000000000 22:25:34:722 | MD | INFO | +0 | GetJoystickArray - Ended 22:25:34:724 | MD | DEBUG2 | +0 | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe" 22:25:34:725 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:25:34:727 | MD | INFO | +0 | RunXpadder - Started 22:25:34:728 | MD | INFO | +0 | Process - Exist JoyToKey.exe 22:25:34:731 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:25:34:732 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:25:34:785 | MD | DEBUG1 | +62 | Run - "Xpadder.exe /C" Process ID: 5312 22:25:34:787 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:25:34:788 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 22:25:34:892 | MD | DEBUG2 | +109 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:25:34:893 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:25:34:895 | MD | WARNING | +0 | RunXpadder - No profiles found and nothing to tell Xpadder to load 22:25:34:896 | MD | INFO | +0 | RunXpadder - Ended 22:25:34:898 | MD | INFO | +0 | RunKeymapper - Ended 22:25:34:900 | MD | INFO | +0 | Keymapper - Loading External AHK Keymapping 22:25:34:901 | MD | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists 22:25:34:903 | MD | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AhkLauncher FileVersion 1.0.0.0 InternalName AhkLauncher.exe LegalCopyright Copyright © 2013 OriginalFilename AhkLauncher.exe ProductName AhkLauncher ProductVersion 1.0.0.0 File Size: 11264 bytes Created: 5/24/2015 - 8:28:06 AM Modified: 9/4/2013 - 6:30:52 PM 22:25:34:905 | MD | INFO | +0 | RunAHKKeymapper - Started 22:25:34:906 | MD | DEBUG1 | +0 | RunAHKKeymapper - Loading Blue Chicago Blues (Japan) (Disc 2), RetroArch, NEC PC-FX, or _Default AHK Keymapper profile 22:25:34:927 | MD | INFO | +32 | GetAHKProfile - Started 22:25:34:929 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).ahk 22:25:34:930 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\NEC PC-FX\RetroArch.ahk 22:25:34:931 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\NEC PC-FX.ahk 22:25:34:933 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk 22:25:34:934 | MD | INFO | +0 | GetAHKProfile - Ended and no profile found 22:25:34:936 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:25:34:937 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 22:25:34:960 | MD | INFO | +31 | RunAHKKeymapper - Ended 22:25:34:001 | MD | INFO | +47 | StartModule - Started 22:25:35:002 | MD | INFO | +0 | StartModule - MEmu: RetroArch MEmuV: v05-11-2015 Nightly MURL: http://themaister.net/retroarch.html MAuthor: djvj,zerojay MVersion: 2.3.3 MCRC: A2F3BE90 iCRC: 42C3B552 MID: MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" 22:25:35:005 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "NEC PC-FX" 22:25:35:007 | MD | INFO | +0 | PluginInit - Started 22:25:35:008 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 22:25:35:009 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Databases\NEC PC-FX\NEC PC-FX.xml exists 22:25:35:012 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 21896 bytes Created: 1/18/2017 - 8:48:51 PM Modified: 1/18/2017 - 8:42:43 PM 22:25:35:013 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 22:25:35:015 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 22:25:35:036 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Name 22:25:35:040 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "Blue Chicago Blues (Japan) (Disc 2)" 22:25:35:041 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Cloneof 22:25:35:043 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 22:25:35:045 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 22:25:35:046 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Manufacturer" with a value: "Riverhill Soft" 22:25:35:066 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Year 22:25:35:067 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Year" with a value: "1996" 22:25:35:069 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Genre 22:25:35:070 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Genre" with a value: "Adventure" 22:25:35:072 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 22:25:35:073 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)" 22:25:35:075 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Adventure GameInfo Label: Manufacturer | GameInfo Value: Riverhill Soft GameInfo Label: Name | GameInfo Value: Blue Chicago Blues (Japan) (Disc 2) GameInfo Label: Rating | GameInfo Value: HSRS - GA (General Audience) GameInfo Label: Year | GameInfo Value: 1996 22:25:35:076 | MD | DEBUG1 | +0 | BuildDatabaseTable - Ended 22:25:35:094 | MD | DEBUG1 | +31 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 22:25:35:096 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Logo: E:\Hyperspin\Media\NEC PC-FX\Images\Wheel\Blue Chicago Blues (Japan) (Disc 2).png 22:25:35:098 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Logo: E:\Hyperspin\Media\Main Menu\Images\Wheel\NEC PC-FX.png 22:25:35:099 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:25:35:101 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 22:25:35:102 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: E:\Hyperspin\Media\NEC PC-FX\Images\Artwork1\Blue Chicago Blues (Japan) (Disc 2).png 22:25:35:104 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: E:\Hyperspin\Media\NEC PC-FX\Images\Artwork2\Blue Chicago Blues (Japan) (Disc 2).png 22:25:35:105 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Cartridge: E:\Hyperspin\Media\NEC PC-FX\Images\Artwork3\Blue Chicago Blues (Japan) (Disc 2).png 22:25:35:107 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Flyers: E:\Hyperspin\Media\NEC PC-FX\Images\Artwork4\Blue Chicago Blues (Japan) (Disc 2).png 22:25:35:109 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Letters: E:\Hyperspin\Media\NEC PC-FX\Images\Letters 22:25:35:137 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Other: E:\Hyperspin\Media\NEC PC-FX\Images\Other 22:25:35:174 | MD | DEBUG2 | +47 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: E:\Hyperspin\Media\NEC PC-FX\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: E:\Hyperspin\Media\NEC PC-FX\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 22:25:35:175 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:25:35:177 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 22:25:35:178 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Video: E:\Hyperspin\Media\NEC PC-FX\Video\Blue Chicago Blues (Japan) (Disc 2).* 22:25:35:180 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Video: E:\Hyperspin\Media\Main Menu\Video\NEC PC-FX.* 22:25:35:182 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: System Video | Asset Path1: E:\Hyperspin\Media\Main Menu\Video\NEC PC-FX.mp4 | Asset Extension1: mp4 | Asset Type1: system 22:25:35:183 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:25:35:184 | MD | INFO | +0 | PluginInit - Ended 22:25:35:186 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: Blue Chicago Blues (Japan) (Disc 2) 22:25:35:206 | MD | INFO | +31 | Hiding mouse cursor 22:25:35:263 | MD | DEBUG2 | +47 | XHotkeyTableCreation - Started 22:25:35:265 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy6, 22:25:35:281 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Post loop 10 check 22:25:35:290 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:25:35:291 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:35:293 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "ToggleCursor" 22:25:35:294 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:35:296 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:35:314 | MD | INFO | +32 | StartModule - Ended 22:25:35:366 | MD | DEBUG1 | +46 | Module - Started building the RetroArch object 22:25:35:368 | MD | DEBUG1 | +0 | Module - Finished building the RetroArch object 22:25:35:368 | MD | DEBUG1 | +0 | Module - Finished building the RetroArch object 22:25:35:396 | MD | INFO | +32 | CreateMGRomTable - Started 22:25:35:404 | MD | DEBUG1 | +0 | CreateMGRomTable - romTable does not exist, creating one for "Blue Chicago Blues (Japan) (Disc 2)" 22:25:35:422 | MD | INFO | +31 | CreateRomTable - Started 22:25:35:423 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Blue Chicago Blues (Japan) (Disc 2)" and "(Disc" 22:25:35:436 | MD | DEBUG1 | +0 | CreateRomTable - "Blue Chicago Blues (Japan) (Disc 2)" contains "(Disc" 22:25:35:458 | MD | DEBUG1 | +31 | CreateRomTable - Checking New Rom path: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX 22:25:35:459 | MD | DEBUG1 | +0 | CreateRomTable - Now looping in: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc* 22:25:35:461 | MD | DEBUG1 | +0 | E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 1).rar 22:25:35:462 | MD | DEBUG1 | +0 | CreateRomTable - Looking for: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc*.rar 22:25:35:464 | MD | DEBUG1 | +0 | CreateRomTable - Adding found game to Rom Table: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 1).rar 22:25:35:465 | MD | DEBUG1 | +0 | E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar 22:25:35:467 | MD | DEBUG1 | +0 | CreateRomTable - Looking for: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc*.rar 22:25:35:490 | MD | DEBUG1 | +31 | CreateRomTable - Adding found game to Rom Table: E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar 22:25:35:515 | MD | INFO | +31 | CreateRomTable - Ended, 4 Loops to create table. 22:25:35:521 | MD | INFO | +0 | CreateMGRomTable - Ended 22:25:35:523 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - LibRetro_Core: mednafen_pce_fast_libretro 22:25:35:525 | MD | INFO | +0 | Module Setting - [Settings] - Fullscreen: true 22:25:35:527 | MD | INFO | +0 | Module Setting - [Settings] - ConfigFolder: E:\Hyperspin\Emulators\Retroarch\config 22:25:35:529 | MD | INFO | +0 | Module Setting - [Settings] - MESS_BIOS_Roms_Folder: E:\Hyperspin\Emulators\Retroarch\system\mess 22:25:35:530 | MD | INFO | +0 | Module Setting - [Settings] - HideConsole: true 22:25:35:555 | MD | INFO | +32 | Module Setting - [Settings] - Eject_Toggle_Key: 22:25:35:561 | MD | INFO | +0 | Module Setting - [Settings] - Next_Disk_Key: 22:25:35:583 | MD | INFO | +31 | Module Setting - [Settings] - Previous_Disk_Key: 22:25:35:592 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - SuperGameBoy: false 22:25:35:613 | MD | INFO | +31 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - SuperGameBoy: false 22:25:35:615 | MD | INFO | +0 | Module Setting - [Network] - Enable_Network_Play: false 22:25:35:623 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - Enable_Network_Play: false 22:25:35:643 | MD | INFO | +31 | Module Setting - [NEC PC-FX] - Overlay: 22:25:35:645 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - Overlay: 22:25:35:654 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - VideoShader: 22:25:35:678 | MD | INFO | +31 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - VideoShader: 22:25:35:680 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - AspectRatioIndex: 22:25:35:686 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - AspectRatioIndex: 22:25:35:708 | MD | INFO | +32 | Module Setting - [NEC PC-FX] - CustomViewportWidth: 22:25:35:710 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - CustomViewportWidth: 22:25:35:711 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - CustomViewportHeight: 22:25:35:713 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - CustomViewportHeight: 22:25:35:714 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - CustomViewportX: 22:25:35:716 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - CustomViewportX: 22:25:35:740 | MD | INFO | +31 | Module Setting - [NEC PC-FX] - CustomViewportY: 22:25:35:741 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - CustomViewportY: 22:25:35:743 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - StretchToFillBezel: false 22:25:35:744 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - StretchToFillBezel: false 22:25:35:746 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - Rotation: 0 22:25:35:748 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - Rotation: 0 22:25:35:772 | MD | INFO | +31 | Module Setting - [NEC PC-FX] - CropOverscan: 22:25:35:773 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - CropOverscan: 22:25:35:775 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - ThreadedVideo: 22:25:35:777 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - ThreadedVideo: 22:25:35:778 | MD | INFO | +0 | Module Setting - [NEC PC-FX] - VSync: 22:25:35:800 | MD | INFO | +31 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - VSync: 22:25:35:835 | MD | INFO | +32 | Module Setting - [NEC PC-FX] - IntegerScale: 22:25:35:842 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - IntegerScale: 22:25:35:861 | MD | INFO | +31 | Module Setting - [NEC PC-FX] - ConfigurationPerCore: false 22:25:35:863 | MD | INFO | +0 | Module Setting - [Blue Chicago Blues (Japan) (Disc 2)] - ConfigurationPerCore: false 22:25:35:865 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\cores\mednafen_pce_fast_libretro.dll exists 22:25:35:866 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4233152 bytes Created: 8/16/2015 - 10:45:50 AM Modified: 8/16/2015 - 10:45:50 AM 22:25:35:868 | MD | DEBUG1 | +0 | Module - Global cfg should be: E:\Hyperspin\Emulators\Retroarch\retroarch.cfg 22:25:35:869 | MD | DEBUG1 | +0 | Module - System cfg should be: E:\Hyperspin\Emulators\Retroarch\config\NEC PC-FX.cfg 22:25:35:871 | MD | DEBUG1 | +0 | Module - Core cfg should be: E:\Hyperspin\Emulators\Retroarch\config\mednafen_pce_fast_libretro.dll.cfg 22:25:35:872 | MD | DEBUG1 | +0 | Module - Found a Core cfg! 22:25:35:894 | MD | INFO | +31 | Module - RetroArch is using E:\Hyperspin\Emulators\Retroarch\config\mednafen_pce_fast_libretro.dll.cfg as its config file. 22:25:35:921 | MD | DEBUG1 | +31 | LoadProperties - Started and loading this cfg into memory: E:\Hyperspin\Emulators\Retroarch\config\mednafen_pce_fast_libretro.dll.cfg 22:25:35:957 | MD | DEBUG1 | +31 | LoadProperties - Ended 22:25:35:959 | MD | DEBUG1 | +0 | ReadProperty - Started 22:25:35:960 | MD | DEBUG1 | +0 | ConvertRetroCFGKey - :\system is a relative path 22:25:35:962 | MD | DEBUG1 | +0 | ConvertRetroCFGKey - Converted ":\system" to E:\Hyperspin\Emulators\Retroarch\system 22:25:35:963 | MD | INFO | +0 | 7z - Started, received E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS 22:25:35:965 | MD | DEBUG1 | +0 | 7z - Using Standard method to extract this rom 22:25:35:966 | MD | DEBUG1 | +0 | 7z - ".rar" found in .zip,.rar,.7z,.lzh,.gzip,.tar 22:25:35:991 | MD | INFO | +32 | CheckFile - Checking if E:\Hyperspin\Emulators\Retroarch\roms\NEC PC-FX\Blue Chicago Blues (Japan) (Disc 2).rar exists 22:25:36:081 | MD | DEBUG1 | +93 | CheckFile - Attributes: File Size: 568731165 bytes Created: 1/18/2017 - 9:28:11 PM Modified: 1/15/2017 - 7:50:34 AM 22:25:36:186 | MD | DEBUG2 | +109 | XHotkeyTableCreation - Started 22:25:36:187 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy6, 22:25:36:189 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 10 check 22:25:36:191 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:25:36:192 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:36:193 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 22:25:36:195 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:36:197 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:36:198 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:36:200 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~1joy6 is in TableKeyGroups ~Esc,~1joy6, 22:25:36:218 | MD | DEBUG2 | +32 | XHotkeyTableCreation - Post loop 10 check 22:25:36:248 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Post loop 11 check 22:25:36:249 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy6" 22:25:36:251 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:36:252 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:36:254 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:36:256 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy6, 22:25:36:257 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 10 check 22:25:36:259 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:25:36:260 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:36:261 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError" 22:25:36:263 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:36:283 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Ended 22:25:36:293 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:36:311 | MD | DEBUG2 | +31 | XHotkeyTableCreation - KeyGroup ~1joy6 is in TableKeyGroups ~Esc,~1joy6, 22:25:36:313 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 10 check 22:25:36:314 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:36:316 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label 22:25:36:317 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:36:319 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:36:676 | MD | DEBUG1 | +359 | ScriptError - Playing error sound: error13.mp3 22:25:38:527 | MD | INFO | +1856 | 7zCleanUp - Started 22:25:38:529 | MD | DEBUG1 | +0 | 7zCleanUp - Deleted 22:25:38:530 | MD | INFO | +0 | 7zCleanUp - Ended 22:25:41:959 | MD | DEBUG2 | +3432 | XHotkeyTableCreation - Started 22:25:41:960 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy6, 22:25:41:962 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 10 check 22:25:41:964 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:25:41:965 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:41:966 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc" 22:25:41:968 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:41:970 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:41:971 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:41:989 | MD | DEBUG2 | +32 | XHotkeyTableCreation - KeyGroup ~1joy6 is in TableKeyGroups ~Esc,~1joy6, 22:25:41:044 | MD | DEBUG2 | +46 | XHotkeyTableCreation - Post loop 10 check 22:25:42:045 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:42:047 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy6" 22:25:42:048 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:42:050 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:42:073 | MD | DEBUG2 | +32 | XHotkeyTableCreation - Started 22:25:42:105 | MD | DEBUG2 | +31 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy6, 22:25:42:107 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 10 check 22:25:42:108 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 22:25:42:109 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:42:111 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:25:42:112 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:42:134 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Ended 22:25:42:144 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:25:42:166 | MD | DEBUG2 | +31 | XHotkeyTableCreation - KeyGroup ~1joy6 is in TableKeyGroups ~Esc,~1joy6, 22:25:42:194 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Post loop 10 check 22:25:42:200 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 11 check 22:25:42:201 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label 22:25:42:203 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 12 check 22:25:42:204 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:25:42:206 | MD | ERROR | +0 | ScriptError - Could not find "Blue Chicago Blues (Japan) (Disc 2)" inside the archive with any defined Rom Extensions. Check if you are missing the correct Rom Extension for this rom for RetroArch's Extensions, enable Rom_Match_Extension, or correct the file name inside the archive. 22:25:42:229 | MD | INFO | +32 | ExitModule - Started 22:25:42:231 | MD | INFO | +0 | Starting Updating Statistics: 22:25:42:232 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 22:25:42:234 | MD | DEBUG2 | +0 | gameSectionStartTime:262381139 22:25:42:235 | MD | DEBUG2 | +0 | ElapsedTime:6 22:25:42:237 | MD | DEBUG2 | +0 | Statistics game name without disc info: Blue Chicago Blues (Japan) 22:25:42:257 | MD | DEBUG2 | +31 | Statistics cleared game name: Blue Chicago Blues 22:25:42:298 | MD | DEBUG2 | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 0 Last_Time_Played: 0 Average_Time_Played: 0 Total_Time_Played: 0 System_Total_Played_Time: 265 Total_Global_Played_Time: 66408 22:25:42:300 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 1 Last_Time_Played: Wednesday January 18, 2017 10:25:35 PM Average_Time_Played: 6 Total_Time_Played: 6 System_Total_Played_Time: 271 Total_Global_Played_Time: 66414 22:25:42:321 | MD | DEBUG2 | +31 | Aggregated Final Statistics to multidisc games: Number_of_Times_Played: 1 Last_Time_Played: Wednesday January 18, 2017 10:25:35 PM Average_Time_Played: 6 Total_Time_Played: 6 System_Total_Played_Time: 271 Total_Global_Played_Time: 66414 22:25:42:447 | MD | INFO | +125 | Game section statistics updated. 22:25:42:448 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 22:25:42:450 | MD | INFO | +0 | GetJoystickArray - Started 22:25:42:452 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 0000000000000000 22:25:42:454 | MD | INFO | +0 | GetJoystickArray - Ended 22:25:42:456 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:25:42:479 | MD | INFO | +31 | RunXpadder - Started 22:25:42:519 | MD | INFO | +47 | Process - Exist JoyToKey.exe 22:25:42:523 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:25:42:524 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:25:42:551 | MD | DEBUG1 | +31 | Run - "Xpadder.exe /C" Process ID: 4176 22:25:42:552 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:25:42:554 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 22:25:42:668 | MD | DEBUG2 | +109 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:25:42:670 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:25:42:671 | MD | WARNING | +0 | RunXpadder - No profiles found and nothing to tell Xpadder to load 22:25:42:673 | MD | INFO | +0 | RunXpadder - Ended 22:25:42:674 | MD | INFO | +0 | RunKeymapper - Ended 22:25:42:697 | MD | INFO | +32 | RunAHKKeymapper - Started 22:25:42:698 | MD | DEBUG1 | +0 | RunAHKKeymapper - Unloading AhkLauncher 22:25:42:729 | MD | DEBUG1 | +31 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:25:42:753 | MD | INFO | +31 | Process - Exist AhkLauncher.exe 22:25:42:790 | MD | INFO | +31 | RunAHKKeymapper - Ended 22:25:42:827 | MD | INFO | +31 | Restoring mouse cursor 22:25:42:829 | MD | INFO | +0 | ExitModule - Ended 22:25:42:830 | MD | INFO | +0 | End of Module Logs 22:25:42:948 | RL | INFO | +8518 | Main - Module ended, exiting RocketLauncher normally 22:25:42:949 | RL | INFO | +0 | ExitScript - Started 22:25:42:956 | RL | DEBUG1 | +16 | ExitScript - Unhiding taskbar 22:25:43:174 | RL | DEBUG1 | +218 | ExitScript - Restoring HyperSpin.exe to x0 y0 w1920 h1080 22:25:43:363 | RL | DEBUG1 | +187 | ExitScript - Restoring and Clicking HyperSpin.exe to attempt to put it into focus 22:25:43:364 | RL | DEBUG1 | +0 | ExitScript - Checking what application is currently in focus. 22:25:43:369 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 22:25:43:397 | RL | INFO | +32 | ExitScript - Ended
demonseed Posted January 19, 2017 Author Posted January 19, 2017 Hey\Thanks for the idea. So I tried Unrarring a game Aa! Megami Sama (Japan) (Disc 1).. and noticed the bin, cue files were not named right. I renamed them both to match the database. I also opened the cue and edited the file name there too. When I run the game It says retroarch only supports ccd and cue files not bin and gives me an error. I tried match ext on and off but it makes no difference. How can retro arch run a cue but not a bin they work together? Any ideas?
demonseed Posted January 19, 2017 Author Posted January 19, 2017 I know forsure the bin is before cue. I have changed it and tried again. Now when I run any game I get the system "PC Engine Supersystem" screen.if I hit load it says unable to load..?? wrong bios maybe? I checked under the module settings and the core I have set is mednafen_pce_fast_libretro.. is that wrong>? I tried NEC-PCFX core.. but now it freezes and loads nothing.. here is my config if anyone has any suggestions. I quickly set up mednafen and it worked, not how I want it but pretty good. I always see the Commmand prompt window flash up before the emulator starts and on exit. I have played with the fade in and out with some luck. The fade in seems to have the command box gone however fade out refuses to work. I also tried Hide emulator, but it still pops up. I can not remember how to hide the CMD box... I prefer retro arch if it will work.. that being said I opened retroarch loaded the NEC-PCFX core but it does not see any of my games? wondering if maybe its retroarch settings?
