Keyboard config problem
theaccolade
Hi, I've installed HyperSpin and Rocketlauncher and set a few system configuration, including keys (in both systems), as a matter of fact trying run games from RocketLauncherUI game scan page and HyperLaunch all seems to works.
But when I use HyperSpin for some system I can play normally, but in other when I press enter button nothing happens (no error message), and even if I can play, I can't use esc key to exit the game... what I'm doing wrong?
Thank you for replies ;)
Ok, this is the log file, with a nes game (when I'm on wheel menu and I press enter all freezes until i press alt+f4), could it helps?
12:17:28 AM |  HyperSpin Started
12:17:28 AM |  Going FullScreen
12:17:28 AM |  Checking for updates
12:17:29 AM |  Update Check Complete
12:17:29 AM |  Startup program unavailable
12:17:29 AM |  Playing intro video
12:17:30 AM |  Error intializing joysticks
12:17:30 AM |  Menu Mode is multi
12:17:30 AM |  Loading Main Menu.xml
12:17:30 AM |  Main Menu.xml successfully loaded
12:17:31 AM |  Main Menu wheel loaded successfully
12:17:34 AM |  Loading Nintendo Entertainment System.xml
12:17:34 AM |  Main Menu.xml successfully loaded
12:17:35 AM |  Nintendo Entertainment System wheel loaded successfully
12:17:42 AM |  Loading Main Menu.xml
12:17:42 AM |  Main Menu.xml successfully loaded
12:17:43 AM |  Main Menu wheel loaded successfully
12:17:44 AM |  Loading Nintendo Entertainment System.xml
12:17:44 AM |  Main Menu.xml successfully loaded
12:17:44 AM |  Nintendo Entertainment System wheel loaded successfully
12:17:50 AM |  Launching Game
12:17:50 AM |  Not using HyperLaunch
12:17:50 AM |  Running in normal rom mode
12:17:50 AM |  Excecutable is nestopia.exe
12:17:50 AM |  Command Line is: "C:\Hyperspin\Emulators\Nestopia\nestopia.exe" "C:\Hyperspin\Roms\Nintendo Entertainment System\Xexyz (USA).7z,zip,nes,fds"
12:17:55 AM |  Quiting Hyperspin
12:17:55 AM |  Bye!
Ok, I set settings.ini on RocketLauncher main root and the " 12:17:50 AM |  Not using HyperLaunch " seems fixed but the final result is the same... what I am doing wrong?
01:06:45 AM |  HyperSpin Started
01:06:45 AM |  Going FullScreen
01:06:45 AM |  Checking for updates
01:06:45 AM |  Update Check Complete
01:06:45 AM |  Startup program unavailable
01:06:45 AM |  Playing intro video
01:06:46 AM |  Error intializing joysticks
01:06:46 AM |  Menu Mode is multi
01:06:46 AM |  Loading Main Menu.xml
01:06:46 AM |  Main Menu.xml successfully loaded
01:06:47 AM |  Main Menu wheel loaded successfully
01:06:49 AM |  Loading Super Nintendo Entertainment System.xml
01:06:49 AM |  Main Menu.xml successfully loaded
01:06:50 AM |  Super Nintendo Entertainment System wheel loaded successfully
01:06:57 AM |  Launching Game
01:06:57 AM |  Using HyperLaunch
01:06:57 AM |  Getting Launcher path
01:06:57 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
01:06:57 AM |  Launcher located at C:\Hyperspin\HyperLaunch.exe
01:06:57 AM |  Running Launcher
01:06:58 AM |  Launcher Command Line is: C:\Hyperspin\HyperLaunch.exe "Super Nintendo Entertainment System" "Alien 3 (USA)"
01:07:10 AM |  Loading Main Menu.xml
01:07:10 AM |  Main Menu.xml successfully loaded
01:07:11 AM |  Main Menu wheel loaded successfully
01:07:16 AM |  Loading Nintendo Entertainment System.xml
01:07:16 AM |  Main Menu.xml successfully loaded
01:07:17 AM |  Nintendo Entertainment System wheel loaded successfully
01:07:25 AM |  Launching Game
01:07:25 AM |  Not using HyperLaunch
01:07:25 AM |  Running in normal rom mode
01:07:25 AM |  Excecutable is nestopia.exe
01:07:25 AM |  Command Line is: "C:\Hyperspin\Emulators\Nestopia\nestopia.exe" "C:\Hyperspin\Roms\Nintendo Entertainment System\Aladdin (Europe).7z,zip,nes,fds"
01:07:32 AM |  Quiting Hyperspin
01:07:32 AM |  Bye!
Everything set, all works fine, but when I use pause button with ps1 games (psxfin) the emulator automatically quit full screen mode and I must press alt+enter to have full screen again.
With other emulator I forced full screen mode, but this seems to be the only one who do not have this option, how can I fix it?
Thank you
