Visual Pinball losing focus when launching table
jevansoh
I'm having a terrible problem with Visual Pinball 9 tables.
Some of them work fine, but a lot of them load in the background instead of coming into focus.
If I do an alt-tab I can get to the game, but this just won't work in a cabinet.
I've searched and searched and just cannot come up with an answer.
I can't figure out why some work and some don't.
The game launches fine, but in the background.  It happens about 30 to 40% of the time.
I'd really appreciate any suggestions because I want to build a cabinet and not even hook up a keyboard.
Thanks,
--J
This happened to me with MAME and it turned out to be the fade in time in RocketLauncher. If you increase this for the emulator the problem should hopefully go away.
I'll try this.  Thanks for the tip.
I know I have it set to 3 seconds currently.  I honestly forget where to set that.  Do you know right off?
It's on the first of the three fade tabs on the right hand side. I don't have it in front of me, but I think the fade tabs are under the 'emulator' button.
EDIT: PROBLEM NOT FIXED - SPOKE TOO SOON.  SEE NEW POST BELOW THIS ONE:
I want to thank you again for your tip.  I got the problem fixed and it was being caused by fade (BTW, I have had more problems caused by fade/bezels than anything else with my setup and really think these two things need streamlined) but just so happened to be the exact opposite of what you said.
I never would've figured it out if not for your tip, though.  I increased fade (using hyperhq custom art tab) and it made the problem worse.
That proved it was caused by fade so I completely turned fade off and the problem went away.
I hope this helps someone else who has this problem, but for now, at least everything is working.
I wish I could use fade with Visual Pinball, though, because I'd like my entire system to function the same.  It just looks better and more professional, but I can't figure out how to use fade with this particular module and keep focus.
Thanks again,
--J
Well, unfortunately I spoke too soon.
The problem is not solved.  I thought it was and it may be a little bit better, but the problem still exists.
In Visual Pinball when I select a table, about half of them start in the background instead of coming into focus.
I've tried with fade off, fade on, minimum amount of fade and maximum amount of fade, with no changes.
I really need help with this one, badly because the tables aren't playable without a keyboard and there will be no keyboard in my cabinet.  I have to do an alt-tab to bring them into focus.
I'm pretty sure this problem is related to joytokey because when I turn my xbox 360 controller off, the problem all but disappears.
Here's my rocketlauncher log file with troubleshooting turned on.
The steps I took to generate this log file were simple.  I simply started RL, audited the games for Visual Pinball, and launched a table I know always starts in the background when my joytokey is running/xbox 360 controller plugged in, then exited RL and copied/pasted this log file here.
I hope this helps you help me.
I'm stumped.
Thanks,
--J
	05:32:46:362 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com)	05:32:46:446 | RL |   WARNING  | +78    | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.	05:32:47:014 | RL |     DEBUG  | +562   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32	05:32:47:014 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0	05:32:47:014 | RL |      INFO  | +0     | Main - System Specs:	                    RocketLauncher Dir: F:\RocketLauncher	                    RocketLauncher is: 32-bit	                    OS: Microsoft Windows 10 Pro Insider Preview	                    SKU: Professional	                    Total Memory: 20471.16 MB	                    Free Memory: 14201.66 MB	                    Used Memory: 6269.508 MB	                    SystemType: 64-bit	                    Physical Processors: 1	                    Logical Processors: 8	                    GPU 1 Name: NVIDIA GeForce GTX 560 Ti	                    GPU 1 RAM: 1280.00 MB	                    GPU 1 Driver Version: 21.21.13.7849	                    Sound 1 Device: NVIDIA High Definition Audio	                    Sound 1 Status: Enabled	                    Sound 2 Device: NVIDIA High Definition Audio	                    Sound 2 Status: Enabled	                    Sound 3 Device: NVIDIA High Definition Audio	                    Sound 3 Status: Enabled	                    Sound 4 Device: NVIDIA High Definition Audio	                    Sound 4 Status: Enabled	                    Sound 5 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)	                    Sound 5 Status: Enabled	                    OS Language: English_United_States	                    System Locale: en-US	                    Formats Locale: en-US	                    Windows UI Language: en-US	                    Text Encoding: Windows-1252	                    OS Admin Status: No	                    RL Compatibility Flags:  HIGHDPIAWARE	                    Latest .Net Version: v4.0.30319	                    Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1080 work) [32bit] [30hz] [Landscape]  (Primary)	                    Current AHK Desktop Width: 1920	                    Current AHK Desktop Height: 1080	                    Monitor #1 DPI: 150	                    ErrorMode: 0	                    AutoHotkey Path:	                    AHK Version: 1.1.13.00	                    Unicode: No	05:32:47:014 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\RocketLauncher.exe exists	05:32:47:015 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             RocketLauncher	                    FileVersion                 1.2.0.1	                    LegalCopyright              Â©2016 RocketLauncher	                    ProductName                 djvj's one swell guy!	                    ProductVersion              1.2.0.1	                    CompanyName                 Your favorite Front End companion! Visit us @ www.rlauncher.com	                    File Size:            2195456 bytes	                    Created:            4/19/2016 - 8:56:43 PM	                    Modified:            1/31/2017 - 2:53:46 AM	05:32:47:016 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Visual Pinball -r Atlantis (Gottlieb) -f F:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1"	05:32:47:016 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "F:\RocketLauncher\Module Extensions\RocketLauncher.dll"	05:32:47:017 | RL |      INFO  | +0     | File.CheckFile - Checking if "F:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists	05:32:47:017 | RL |     TRACE  | +0     | File.Exist - This file exists: F:\RocketLauncher\Module Extensions\RocketLauncher.dll	05:32:47:018 | RL |     DEBUG  | +16    | File.CheckFile - Attributes:	                    FileDescription             RocketLauncher Utils	                    FileVersion                 1.1.0.0	                    InternalName                RocketLauncher.dll	                    LegalCopyright              Copyright © RocketLauncher 2013-2016	                    OriginalFilename            RocketLauncher.dll	                    ProductName                 RocketLauncher	                    ProductVersion              1.1.0.0	                    File Size:            81408 bytes	                    Created:            9/3/2016 - 11:23:49 PM	                    Modified:            1/31/2017 - 2:53:34 AM	05:32:47:023 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\Array.ahk	05:32:47:024 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4926 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            2/1/2017 - 5:08:18 AM	05:32:47:025 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\BinHexRW.ahk	05:32:47:026 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5112 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:25:10 AM	05:32:47:026 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\BlockInput.exe exists	05:32:47:027 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             	                    FileVersion                 1.1.09.04	                    InternalName                	                    OriginalFilename            	                    ProductName                 	                    ProductVersion              1.1.09.04	                    File Size:            657920 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:028 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop	05:32:47:028 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5503 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            1/31/2017 - 2:53:28 AM	05:32:47:029 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk	05:32:47:029 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5716 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:032 | RL |     ERROR  | +0     | CRC Check - No CRC defined on the header for: F:\RocketLauncher\Module Extensions\gdip.ahk	05:32:47:033 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            88789 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:034 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\gdip_alt.ahk	05:32:47:034 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5955 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:25:23 AM	05:32:47:034 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\gsdll32.dll exists	05:32:47:035 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            13090816 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:58 AM	05:32:47:035 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\itextsharp.dll exists	05:32:47:036 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             iTextSharp	                    FileVersion                 5.4.2.0	                    InternalName                itextsharp.dll	                    LegalCopyright              Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.	                    OriginalFilename            itextsharp.dll	                    ProductName                 iTextSharp	                    ProductVersion              5.4.2.0	                    CompanyName                 1T3XT BVBA	                    File Size:            3743744 bytes	                    Created:            3/5/2016 - 12:03:58 AM	                    Modified:            3/5/2016 - 12:03:58 AM	05:32:47:037 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Java.ahk	05:32:47:038 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            7859 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:25:36 AM	05:32:47:039 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\JSON.ahk	05:32:47:039 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            9227 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/9/2016 - 5:42:45 AM	05:32:47:040 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Origin.ahk	05:32:47:041 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4915 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:26:16 AM	05:32:47:042 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\RegRW64.ahk	05:32:47:042 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            6915 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:044 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\RIni.ahk | v1.7	05:32:47:045 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            67872 bytes	                    Created:            9/11/2016 - 1:40:14 PM	                    Modified:            9/11/2016 - 1:40:14 PM	05:32:47:045 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists	05:32:47:046 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             SevenZipSharp	                    FileVersion                 0.64.5717.6837	                    InternalName                SevenZipSharp.dll	                    LegalCopyright              Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3	                    OriginalFilename            SevenZipSharp.dll	                    ProductName                 SevenZipSharp	                    ProductVersion              0.64.5717.6837	                    CompanyName                 Markovtsev Vadim	                    File Size:            167424 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:047 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\Steam.ahk	05:32:47:047 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5517 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:26:25 AM	05:32:47:049 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: F:\RocketLauncher\Module Extensions\VA.ahk	05:32:47:049 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            34688 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:050 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Module Extensions\VA_Extension.ahk	05:32:47:050 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            3862 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:26:32 AM	05:32:47:052 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\7z.ahk	05:32:47:052 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            33916 bytes	                    Created:            10/6/2016 - 3:54:17 AM	                    Modified:            1/31/2017 - 2:53:53 AM	05:32:47:055 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Bezel.ahk	05:32:47:056 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            121257 bytes	                    Created:            9/22/2016 - 1:58:37 AM	                    Modified:            1/31/2017 - 2:53:41 AM	05:32:47:058 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade.ahk	05:32:47:058 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            39707 bytes	                    Created:            9/1/2016 - 9:31:38 PM	                    Modified:            1/31/2017 - 2:53:50 AM	05:32:47:059 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade Init.ahk	05:32:47:060 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            1140 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:27:47 AM	05:32:47:061 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Fade Animations.ahk	05:32:47:062 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            77961 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:27:37 AM	05:32:47:063 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Keymapper.ahk	05:32:47:064 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            33682 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:28:29 AM	05:32:47:065 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Keymapper Init.ahk	05:32:47:065 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            3966 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:28:17 AM	05:32:47:066 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiGame.ahk	05:32:47:067 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            41583 bytes	                    Created:            4/25/2016 - 5:19:13 PM	                    Modified:            10/10/2016 - 1:28:47 AM	05:32:47:067 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiGame Init.ahk	05:32:47:068 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            169 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:28:38 AM	05:32:47:070 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\MultiPlayer.ahk	05:32:47:070 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            67277 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:28:55 AM	05:32:47:077 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Pause.ahk	05:32:47:078 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            408415 bytes	                    Created:            10/4/2016 - 8:45:02 PM	                    Modified:            1/31/2017 - 2:53:30 AM	05:32:47:079 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Pause Init.ahk	05:32:47:079 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            563 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:29:15 AM	05:32:47:080 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Password.ahk	05:32:47:081 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            10131 bytes	                    Created:            4/25/2016 - 5:19:13 PM	                    Modified:            10/10/2016 - 1:29:07 AM	05:32:47:082 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk	05:32:47:082 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            31509 bytes	                    Created:            9/17/2016 - 11:10:05 PM	                    Modified:            1/31/2017 - 2:53:35 AM	05:32:47:083 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Log\Logger.ahk	05:32:47:083 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            3558 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:32:18 AM	05:32:47:084 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk	05:32:47:085 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            6709 bytes	                    Created:            6/27/2016 - 8:52:19 PM	                    Modified:            1/31/2017 - 2:53:36 AM	05:32:47:086 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk	05:32:47:086 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            2084 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            2/1/2017 - 5:08:15 AM	05:32:47:087 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\ArrayUtils.ahk	05:32:47:087 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            306 bytes	                    Created:            1/31/2017 - 2:53:27 AM	                    Modified:            1/31/2017 - 2:53:27 AM	05:32:47:088 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\LocaleUtils.ahk	05:32:47:089 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            2104 bytes	                    Created:            1/31/2017 - 2:53:48 AM	                    Modified:            1/31/2017 - 2:53:48 AM	05:32:47:089 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk	05:32:47:090 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            7754 bytes	                    Created:            7/5/2016 - 10:15:18 PM	                    Modified:            1/31/2017 - 2:53:31 AM	05:32:47:091 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk	05:32:47:091 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            2948 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:33:57 AM	05:32:47:092 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\ArchiveFile.ahk	05:32:47:092 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            346 bytes	                    Created:            1/31/2017 - 2:53:30 AM	                    Modified:            1/31/2017 - 2:53:30 AM	05:32:47:093 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\DemulShooter.ahk	05:32:47:094 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            786 bytes	                    Created:            7/17/2016 - 9:50:37 PM	                    Modified:            1/31/2017 - 2:53:46 AM	05:32:47:094 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk	05:32:47:095 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            1231 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:34:30 AM	05:32:47:096 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\File.ahk	05:32:47:096 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            9522 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            1/31/2017 - 2:53:29 AM	05:32:47:097 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\FileUtils.ahk	05:32:47:097 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            339 bytes	                    Created:            1/31/2017 - 2:53:33 AM	                    Modified:            1/31/2017 - 2:53:33 AM	05:32:47:098 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk	05:32:47:099 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            643 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:34:48 AM	05:32:47:100 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk	05:32:47:100 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4364 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:34:57 AM	05:32:47:101 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\Process.ahk	05:32:47:101 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            9711 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            1/31/2017 - 2:53:41 AM	05:32:47:102 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\PropertiesFile.ahk	05:32:47:103 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4218 bytes	                    Created:            1/31/2017 - 2:53:35 AM	                    Modified:            1/31/2017 - 2:53:35 AM	05:32:47:104 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk	05:32:47:104 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            3898 bytes	                    Created:            9/11/2016 - 1:40:14 PM	                    Modified:            10/10/2016 - 1:35:14 AM	05:32:47:105 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\File\XMLFile.ahk	05:32:47:105 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            331 bytes	                    Created:            1/31/2017 - 2:53:41 AM	                    Modified:            1/31/2017 - 2:53:41 AM	05:32:47:106 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk	05:32:47:107 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5426 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:35:23 AM	05:32:47:108 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk	05:32:47:108 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4603 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:35:32 AM	05:32:47:109 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk	05:32:47:110 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            24655 bytes	                    Created:            9/1/2016 - 9:31:38 PM	                    Modified:            2/1/2017 - 5:08:15 AM	05:32:47:110 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk	05:32:47:111 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            1171 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            10/10/2016 - 1:35:49 AM	05:32:47:113 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk	05:32:47:113 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            72279 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:29:33 AM	05:32:47:114 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shader.ahk	05:32:47:115 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            4183 bytes	                    Created:            9/11/2016 - 1:40:14 PM	                    Modified:            10/10/2016 - 1:29:51 AM	05:32:47:116 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shader Init.ahk	05:32:47:116 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            412 bytes	                    Created:            9/3/2016 - 11:23:49 PM	                    Modified:            10/10/2016 - 1:29:40 AM	05:32:47:120 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Shared.ahk	05:32:47:120 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            173248 bytes	                    Created:            6/25/2016 - 10:41:05 PM	                    Modified:            1/31/2017 - 2:53:47 AM	05:32:47:122 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Statistics.ahk	05:32:47:122 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            27008 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:30:22 AM	05:32:47:123 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Statistics Init.ahk	05:32:47:123 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            43 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:30:14 AM	05:32:47:125 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\Virtual Drive.ahk	05:32:47:125 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            20294 bytes	                    Created:            4/25/2016 - 5:19:13 PM	                    Modified:            10/10/2016 - 1:30:47 AM	05:32:47:126 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\XHotkey.ahk	05:32:47:127 | RL |     DEBUG  | +15    | CheckFile - Attributes:	                    File Size:            26615 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:31:04 AM	05:32:47:128 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Lib\XHotkey Init.ahk	05:32:47:128 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            1073 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            10/10/2016 - 1:30:56 AM	05:32:47:128 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "Atlantis (Gottlieb)"	05:32:47:128 | RL |     DEBUG  | +0     | Main - dbName: Atlantis (Gottlieb)	05:32:47:129 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"	05:32:47:130 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: F:\RocketLauncher\Plugins\HyperSpin.plugin	05:32:47:130 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            9590 bytes	                    Created:            9/17/2016 - 11:10:05 PM	                    Modified:            1/31/2017 - 2:53:47 AM	05:32:47:130 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "F:\HyperSpin\HyperSpin.exe"	05:32:47:131 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "F:\HyperSpin\HyperSpin.exe"	05:32:47:131 | RL |      INFO  | +0     | Main - RocketLauncher received "Visual Pinball" and "Atlantis (Gottlieb)"	05:32:47:139 | RL |      INFO  | +0     | Main - Did not find a "F:\RocketLauncher\Settings\Visual Pinball\Game Options.ini" file, skipping any game-specific options.	05:32:47:139 | RL |      INFO  | +0     | Main - Atlantis (Gottlieb) is using the default emulator: Visual Pinball 9	05:32:47:139 | RL |      INFO  | +0     | Main - Checking for a [Visual Pinball 9] section in F:\RocketLauncher\Settings\Visual Pinball\Emulators.ini	05:32:47:139 | RL |      INFO  | +0     | Main - Checking for a [Visual Pinball 9] section in F:\RocketLauncher\Settings\Global Emulators.ini	05:32:47:140 | RL |      INFO  | +0     | Main - Found [Visual Pinball 9] in F:\RocketLauncher\Settings\Global Emulators.ini	05:32:47:142 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball.ahk exists	05:32:47:142 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    File Size:            5941 bytes	                    Created:            3/5/2016 - 12:03:58 AM	                    Modified:            10/9/2016 - 2:19:23 PM	05:32:47:143 | RL |      INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.	05:32:47:143 | RL |      INFO  | +0     | Main - Atlantis (Gottlieb) will use module: F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball.ahk	05:32:47:163 | RL |      INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.	05:32:47:168 | RL |      INFO  | +0     | CheckFile - Checking if F:\Visual Pinball NEW\VPinball993.exe exists	05:32:47:170 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             Visual Pinball 9.9.3	                    FileVersion                 9, 9, 3, 0	                    InternalName                Visual Pinball	                    LegalCopyright              Copyright 2000-2016	                    OriginalFilename            VPinball.exe	                    ProductName                 Visual Pinball	                    ProductVersion              9, 9, 3, 0	                    File Size:            1893376 bytes	                    Created:            12/22/2016 - 5:22:06 PM	                    Modified:            12/22/2016 - 5:22:06 PM	05:32:47:170 | RL |      INFO  | +0     | Main - INI Keys read	05:32:47:171 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.exe exists	05:32:47:172 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             7-Zip Console	                    FileVersion                 15.06 beta	                    InternalName                7z	                    LegalCopyright              Copyright (c) 1999-2015 Igor Pavlov	                    OriginalFilename            7z.exe	                    ProductName                 7-Zip	                    ProductVersion              15.06 beta	                    CompanyName                 Igor Pavlov	                    File Size:            262144 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:172 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.dll exists	05:32:47:173 | RL |     DEBUG  | +0     | CheckFile - Attributes:	                    FileDescription             7z Plugin	                    FileVersion                 15.06 beta	                    InternalName                7z	                    LegalCopyright              Copyright (c) 1999-2015 Igor Pavlov	                    OriginalFilename            7z.dll	                    ProductName                 7-Zip	                    ProductVersion              15.06 beta	                    CompanyName                 Igor Pavlov	                    File Size:            1012224 bytes	                    Created:            3/5/2016 - 12:03:57 AM	                    Modified:            3/5/2016 - 12:03:57 AM	05:32:47:178 | RL |      INFO  | +15    | Main - "Atlantis (Gottlieb)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side	05:32:47:179 | RL |      INFO  | +0     | CheckPaths - Started	05:32:47:179 | RL |      INFO  | +0     | CheckPaths - Looking for rom: F:\Visual Pinball NEW\Tables\Atlantis (Gottlieb).vpt	05:32:47:179 | RL |      INFO  | +0     | CheckPaths - Found rom: F:\Visual Pinball NEW\Tables\Atlantis (Gottlieb).vpt	05:32:47:179 | RL |     DEBUG  | +0     | CheckPaths - Current romName: Atlantis (Gottlieb)	05:32:47:180 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: F:\Visual Pinball NEW\Tables	05:32:47:180 | RL |     DEBUG  | +0     | CheckPaths - Current romExtension: .vpt	05:32:47:180 | RL |      INFO  | +0     | CheckPaths - Ended	05:32:47:181 | RL |      INFO  | +0     | BuildScript - User Variables:	                    ;----------------------------------------------------------------------------	                    ; INJECTED VARIABLES	                    ;----------------------------------------------------------------------------	                    	                    #NoTrayIcon	                    #InstallKeybdHook	                    MiscUtils.DetectHiddenWindows("On")	                    SetTitleMatchMode, 2	                    SendMode, Event	                    Global RLLog	                    Global RLObject	                    0 := "12"	                    rlPath := "F:\RocketLauncher"	                    pluginPath := "F:\RocketLauncher\Plugins"	                    pluginName := "HyperSpin"	                    pluginExt := ".plugin"	                    contextOnExit := "1"	                    rlMode := ""	                    rlTitle := "RocketLauncher"	                    rlVersion := "1.2.0.1"	                    rlAuthor := "djvj"	                    rlURL := "www.rlauncher.com"	                    langFile := "F:\RocketLauncher\Data\Language\Localization.ini"	                    primMonitor := "1"	                    frontendPID := ""	                    frontendPath := "F:\HyperSpin"	                    frontendExe := "HyperSpin.exe"	                    frontendExt := "exe"	                    frontendName := "HyperSpin"	                    frontendDrive := "F"	                    exitEmulatorKey := "~Esc"	                    restoreFE := "Restore and Click"	                    exitScriptKey := "~q & ~s"	                    toggleCursorKey := "~e & ~t"	                    emuFullPath := "F:\Visual Pinball NEW\VPinball993.exe"	                    emuPath := "F:\Visual Pinball NEW"	                    emuName := "Visual Pinball 9"	                    emuExt := "exe"	                    baseRomPath := ""	                    romPath := "F:\Visual Pinball NEW\Tables"	                    romPathFromIni := "F:\Visual Pinball NEW\Tables"	                    romExtension := ".vpt"	                    romExtensionOrig := ".vpt"	                    romExtensions := "vpt"	                    executable := "VPinball993.exe"	                    systemDbName := "Visual Pinball"	                    systemName := "Visual Pinball"	                    dbPath := ""	                    dbName := "Atlantis (Gottlieb)"	                    dbExt := ""	                    romFoundByExt := ""	                    romName := "Atlantis (Gottlieb)"	                    romMapPath := ""	                    romMappingEnabled := "false"	                    romMappingLaunchMenuEnabled := "false"	                    romMappingFirstMatchingExt := "false"	                    romMappingShowAllRomsInArchive := "true"	                    romMappingNumberOfGamesByScreen := "7"	                    romMappingHideParent := "false"	                    romMappingMenuWidth := "400"	                    romMappingMenuMargin := "65"	                    romMappingTextFont := "Bebas Neue"	                    romMappingTextOptions := "cFFFFFFFF r4 s60 Bold"	                    romMappingDisabledTextColor := "ff888888"	                    romMappingTextSizeDifference := "7"	                    romMappingTextMargin := "15"	                    romMappingTitleTextFont := "Bebas Neue"	                    romMappingTitleTextOptions := "cFFFFFFFF r4 s90 Bold"	                    romMappingTitle2TextFont := "Bebas Neue"	                    romMappingTitle2TextOptions := "cFFFFFFFF r4 s22 Bold"	                    romMappingGameInfoTextFont := "Bebas Neue"	                    romMappingGameInfoTextOptions := "cFFFFFFFF r4 s22 Regular"	                    romMappingGameNameTextFont := "Bebas Neue"	                    romMappingGameNameTextOptions := "cFFFFFFFF r4 s40 Regular"	                    romMappingBackgroundBrush := "aa000000"	                    romMappingColumnBrush := "33000000"	                    romMappingButtonBrush1 := "6f000000"	                    romMappingButtonBrush2 := "33000000"	                    romMappingBackgroundAlign := "Stretch and Lose Aspect"	                    romMappingMenuFlagWidth := "55"	                    romMappingMenuFlagSeparation := "7"	                    romMappingDefaultMenuList := "FullList"	                    romMappingSingleFilteredRomAutomaticLaunch := "false"	                    altArchiveNameOnly := ""	                    altRomNameOnly := ""	                    altArchiveAndRomName := ""	                    altArchiveAndManyRomNames := ""	                    altRomNamesOnly := ""	                    romMapScenario := ""	                    skipchecks := "false"	                    romMatchExt := "false"	                    blockInputTime := "0"	                    blockInputFile := "F:\RocketLauncher\Module Extensions\BlockInput.exe"	                    errorLevelReporting := "false"	                    lockLaunch := "false"	                    lockLaunchGame := ""	                    screenRotationAngle := "0"	                    screenRotationAngleGame := ""	                    setResolution := ""	                    logFile := ""	                    logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]	                    logLevel := "10"	                    logShowDebugConsole := "false"	                    logShowCommandWindow := "false"	                    logCommandWindow := "false"	                    logIncludeModule := "true"	                    logIncludeFileProperties := "true"	                    logIncludeDLLLogs := "false"	                    errorSounds := "true"	                    rlDebugConsoleStdout := ""	                    sysLang := "English_United_States"	                    sysType := "64-bit"	                    broadcastWindowTitle := ""	                    navUpKey := "Up"	                    navDownKey := "Down"	                    navLeftKey := "Left"	                    navRightKey := "Right"	                    navSelectKey := "Enter"	                    navP2UpKey := "Numpad8"	                    navP2DownKey := "Numpad2"	                    navP2LeftKey := "Numpad4"	                    navP2RightKey := "Numpad6"	                    navP2SelectKey := "NumpadEnter"	                    originalWidth := "1920"	                    originalHeight := "1080"	                    vdEnabled := "false"	                    vdFullPath := ""	                    vdUseSCSI := "true"	                    vdDriveLetter := ""	                    vdDriveLetterScsi := ""	                    vdAddDrive := "true"	                    demulShooterPath := ""	                    servoStikEnabled := "false"	                    servoStikExitMode := "false"	                    ledblinkyEnabled := "false"	                    ledblinkySystemName := ""	                    ledblinkyFullPath := ""	                    ledblinkyProfilePath := "F:\RocketLauncher\Profiles\LEDBlinky"	                    ledblinkyRLProfile := "F:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher"	                    winIPACFullPath := ""	                    ultraMapEnabled := "false"	                    ultraMapFullPath := ""	                    emuIdleShutdown := "0"	                    launchPasswordHash := "UpUpDownDownLeftRightLeftRight"	                    cursorSize := ""	                    hideCursor := "false"	                    hideEmu := "false"	                    hideFE := "true"	                    suspendFE := "false"	                    fadeIn := "false"	                    fadeInDuration := "500"	                    fadeInTransitionAnimation := "LegacyFadeInTransition"	                    fadeInDelay := "5000"	                    fadeInExitDelay := "0"	                    fadeOutExitDelay := "0"	                    fadeOut := "true"	                    fadeOutExtraScreen := "false"	                    fadeOutDuration := "500"	                    fadeOutTransitionAnimation := "DefaultAnimateFadeOut"	                    fadeOutDelay := "5000"	                    fadeLyrInterpolation := "7"	                    fadeMuteEmulator := "false"	                    fadeUseBackgrounds := "true"	                    fadeClickThrough := "false"	                    fadeSounds := "true"	                    fade7zProgressMode := "extraction"	                    fadeWidthBaseRes := "1920"	                    fadeHeightBaseRes := "1080"	                    fadeLyr1Color := "FF000000"	                    fadeLyr1AlignImage := "Stretch and Lose Aspect"	                    fadeLyr2Pos := "Stretch and Lose Aspect"	                    fadeLyr2X := "0"	                    fadeLyr2Y := "0"	                    fadeLyr2W := ""	                    fadeLyr2H := ""	                    fadeLyr2Adjust := "1"	                    fadeLyr2PicPad := "0"	                    fadeLyr2Prefix := "Extra Layer 1 - Console"	                    fadeLyr3Pos := "Center"	                    fadeLyr3X := "450"	                    fadeLyr3Y := "450"	                    fadeLyr3W := ""	                    fadeLyr3H := ""	                    fadeLyr3Adjust := "1"	                    fadeLyr3PicPad := "0"	                    fadeLyr3Speed := "750"	                    fadeLyr3Animation := "DefaultFadeAnimation"	                    fadeLyr37zAnimation := "DefaultFadeAnimation"	                    fadeLyr3Type := "imageandbar"	                    fadeLyr3ImgFollow7zProgress := "false"	                    fadeLyr3Repeat := "1"	                    fadeLyr3BackImageTransparency := "30"	                    fadeLyr3StaticPos := "No Alignment"	                    fadeLyr3StaticX := "0"	                    fadeLyr3StaticY := "870|1575"	                    fadeLyr3StaticW := ""	                    fadeLyr3StaticH := ""	                    fadeLyr3StaticAdjust := "1"	                    fadeLyr3StaticPicPad := "0"	                    fadeLyr3StaticPrefix := "Info Bar"	                    fadeLyr4Adjust := "1"	                    fadeLyr4X := "1792|952"	                    fadeLyr4Y := "891|1596"	                    fadeLyr4W := "128"	                    fadeLyr4H := ""	                    fadeLyr4Pos := "No Alignment"	                    fadeLyr4FPS := "50"	                    fadeLyr4PicPad := "0"	                    fadeTranspGifColor := "FFFFFF"	                    fadeBarWindow := "Image"	                    fadeBarWindowX := ""	                    fadeBarWindowY := ""	                    fadeBarWindowW := "900"	                    fadeBarWindowH := ""	                    fadeBarWindowR := "30"	                    fadeBarWindowM := "30"	                    fadeBarWindowHatchStyle := "8"	                    fadeBar := "true"	                    fadeProgressDuration := "0"	                    fadeBarBack := "true"	                    fadeBarBackColor := "FF555555"	                    fadeBarH := "30"	                    fadeBarR := "10"	                    fadeBarColor := "DD00BFFF"	                    fadeBarHatchStyle := "8"	                    fadeBarPercentageText := "true"	                    fadeBarInfoText := "true"	                    fadeBarXOffset := "0"	                    fadeBarYOffset := "150"	                    fadeRomInfoDescription := "filtered text"	                    fadeRomInfoSystemName := "image"	                    fadeRomInfoYear := "text with label"	                    fadeRomInfoDeveloper := "disabled"	                    fadeRomInfoPublisher := "disabled"	                    fadeRomInfoGenre := "disabled"	                    fadeRomInfoRating := "image"	                    fadeRomInfoOrder := "Description|SystemName|Year|Developer|Genre|Rating|Publisher"	                    fadeRomInfoTextPlacement := "User Defined"	                    fadeRomInfoTextMargin := "7"	                    fadeRomInfoText1Options := "w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular"	                    fadeRomInfoText2Options := "w400 x8 y15 cFF555555 r4 s60 Bold"	                    fadeRomInfoText3Options := "w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular"	                    fadeRomInfoText4Options := "w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular"	                    fadeRomInfoText5Options := "cFF555555 r4 s42 Bold"	                    fadeRomInfoText6Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular"	                    fadeRomInfoText7Options := "h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular"	                    fadeStats_Number_of_Times_Played := "text with label"	                    fadeStats_Last_Time_Played := "text with label"	                    fadeStats_Average_Time_Played := "text with label"	                    fadeStats_Total_Time_Played := "text with label"	                    fadeStats_System_Total_Played_Time := "text with label"	                    fadeStats_Total_Global_Played_Time := "text with label"	                    fadeStatsInfoOrder := "Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time"	                    fadeStatsInfoTextPlacement := "topRight"	                    fadeStatsInfoTextMargin := "7"	                    fadeStatsInfoText1Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeStatsInfoText2Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeStatsInfoText3Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeStatsInfoText4Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeStatsInfoText5Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeStatsInfoText6Options := "cFFB4B4B4 r4 s22 Bold"	                    fadeText1X := "0"	                    fadeText1Y := "0"	                    fadeText1Options := "cFFB4B4B4 r4 s30 Right Bold"	                    fadeText1 := "Loading Game"	                    fadeText2X := "0"	                    fadeText2Y := "0"	                    fadeText2Options := "cFFB4B4B4 r4 s30 Right Bold"	                    fadeText2 := "Extraction Complete, Ready"	                    fadeText3 := "Loading Game"	                    fadeText4 := "Loading Complete"	                    fadeFont := "Bebas Neue"	                    fadeSystemAndRomLayersOnly := "false"	                    fadeExtractionTime := "disabled"	                    fadeExtractionTimeTextX := "0"	                    fadeExtractionTimeTextY := "0"	                    fadeExtractionTimeTextOptions := "cFF555555 r4 s20 Bold"	                    fadeInterruptKey := ""	                    detectFadeErrorEnabled := "true"	                    fadeImgPath := "F:\RocketLauncher\Media\Fade"	                    RLDataPath := "F:\RocketLauncher\Data"	                    RLMediaPath := "F:\RocketLauncher\Media"	                    RLErrSoundPath := "F:\RocketLauncher\Media\Sounds\Error"	                    modulesPath := "F:\RocketLauncher\Modules"	                    moduleFullName := "F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball.ahk"	                    moduleName := "Visual Pinball"	                    modulePath := "F:\RocketLauncher\Modules\Visual Pinball"	                    moduleExtension := "ahk"	                    moduleExtensionsPath := "F:\RocketLauncher\Module Extensions"	                    libPath := "F:\RocketLauncher\Lib"	                    sevenZEnabled := "false"	                    sevenZPath := "F:\RocketLauncher\Module Extensions\7z.exe"	                    sevenZDllPath := "F:\RocketLauncher\Module Extensions\7z.dll"	                    sevenZExtractPath := "C:\TEMP GAME HS"	                    sevenZExtractPathOrig := ""	                    sevenZAttachSystemName := "false"	                    sevenZDelTemp := "true"	                    sevenZFormats := ".zip|.rar|.7z|.lha|.lzh|.gzip|.tar"	                    sevenZFormatsNoP := "zip|rar|7z|lha|lzh|gzip|tar"	                    sevenZFormatsRegEx := "\.zip|\.rar|\.7z|\.lha|\.lzh|\.gzip|\.tar"	                    sevenZGamesToKeep := ""	                    sevenZDeletePerSystem := "false"	                    sevenZExtensions := "zip|rar|7z|lha|lzh|gzip|tar"	                    7zExtractPath := "C:\TEMP GAME HS"	                    mgEnabled := "false"	                    mgKey := "~NumpadSub"	                    mgBackgroundColor := "FF000000"	                    mgSidePadding := "0.2"	                    mgWidthBaseRes := "1920"	                    mgHeightBaseRes := "1080"	                    mgYOffset := "500|800"	                    mgFont := "Arial"	                    mgText1Options := "x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic"	                    mgText1Text := "Please select a game"	                    mgText2Options := "w96p cFFFFFFFF r4 s50 Center BoldItalic"	                    mgText2Offset := "100"	                    mgUseSound := "true"	                    mgSoundfreq := "300"	                    mgExitEffect := "none"	                    mgSelectedEffect := "rotate"	                    mgUseGameArt := "false"	                    mgCandidate := ""	                    mgValidTypes := "\(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side"	                    mgOnLaunch := "false"	                    pauseEnabled := "false"	                    pauseKey := "~NumpadAdd"	                    pauseBackToMenuBarKey := "X"	                    pauseZoomInKey := "C"	                    pauseZoomOutKey := "V"	                    pauseScreenshotKey := "~PrintScreen"	                    pauseHiToTextPath := "F:\RocketLauncher\Module Extensions\HiToText.exe"	                    pauseSaveStateKeyCodes := ""	                    pauseLoadStateKeyCodes := ""	                    keyboardEncoder := ""	                    keyboardEncoderEnabled := "false"	                    keymapperEnabled := "true"	                    keymapperAHKMethod := "false"	                    keymapper := "joytokey"	                    xpadderFullPath := "F:\Utilities\Xpadder\xpadder.exe"	                    joyToKeyFullPath := "F:\JoyToKey_en\JoyToKey.exe"	                    profilePath := "F:\RocketLauncher\Profiles"	                    keymapperProfilePath := "F:\RocketLauncher\Profiles\joytokey"	                    keymapperFrontEndProfileName := "HyperSpin"	                    keymapperFrontEndProfile := "joytokey"	                    keymapperRocketLauncherProfileEnabled := "false"	                    joyIDsEnabled := "true"	                    joyIDsPreferredControllersGlobal := "Controller (XBOX 360 For Windows)"	                    joyIDsPreferredControllersSystem := "use_global"	                    joyIDsPreferredControllersOnExit := "Controller (XBOX 360 For Windows)"	                    CustomJoyNamesEnabled := "false"	                    CustomJoyNames := ""	                    rotateMethod := "false"	                    FEProfile := "F:\RocketLauncher\Profiles\joytokey\HyperSpin"	                    defaultProfile := "F:\RocketLauncher\Profiles\joytokey\_Default"	                    systemProfile := "F:\RocketLauncher\Profiles\joytokey\Visual Pinball"	                    xPadderSystemProfile := "F:\RocketLauncher\Profiles\joytokey\Visual Pinball\_Default"	                    emuProfile := "F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Visual Pinball 9"	                    romProfile := "F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Atlantis (Gottlieb)"	                    RocketLauncherProfile := "F:\RocketLauncher\Profiles\joytokey\RocketLauncher"	                    blankProfile := "F:\RocketLauncher\Profiles\joytokey\blank"	                    ahkFEProfile := "F:\RocketLauncher\Profiles\AHK\HyperSpin"	                    ahkDefaultProfile := "F:\RocketLauncher\Profiles\AHK\_Default"	                    ahkSystemProfile := "F:\RocketLauncher\Profiles\AHK\Visual Pinball"	                    ahkEmuProfile := "F:\RocketLauncher\Profiles\AHK\Visual Pinball\Visual Pinball 9"	                    ahkRomProfile := "F:\RocketLauncher\Profiles\AHK\Visual Pinball\Atlantis (Gottlieb)"	                    ahkRocketLauncherProfile := "F:\RocketLauncher\Profiles\AHK\RocketLauncher"	                    bezelEnabled := "false"	                    bezelICEnabled := "false"	                    shaderName := "false"	                    shaderColor := ""	                    shaderTransparency := ""	                    statisticsEnabled := "true"	                    pressDuration := "-1"	                    emuVolume := "1"	                    dxwndIni := "F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini"	                    dxwndFullPath := "F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"	                    qResFullPath := "F:\RocketLauncher\Module Extensions\QRes.exe"	                    mon1O := ""	                    pacDrivedllFile := "F:\RocketLauncher\Module Extensions\PacDrive32.dll"	                    userFadeAnimIniFile := "F:\RocketLauncher\Lib\User Fade Animations.ini"	                    testFile := ""	                    testDuration := ""	                    initialErrorMode := "0"
	05:32:47:182 | RL |      INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
05:32:47:182 | RL |      INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
05:32:47:182 | RL |      INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
05:32:47:183 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
05:32:47:183 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
05:32:47:183 | RL |      INFO  | +0     | BuildScript - Validating module
05:32:47:184 | RL |      INFO  | +0     | BuildScript - Validation complete
05:32:47:185 | RL |      INFO  | +0     | BuildScript - Module:
                    MEmu := "Visual Pinball"
                    MEmuV := "v8.1.1 & v9.12"
                    MURL := ["http://sourceforge.net/projects/vpinball/"]
                    MAuthor := ["djvj"]
                    MVersion := "2.0.1"
                    MCRC := "86821212"
                    iCRC := "5089D1EC"
                    MID := "635038268932497719"
                    MSystem := ["Visual Pinball"]
                    ; Notes:
                    ; Requires VPinMame v2.4
                    ; If you want to use a picture while the table is loading, place it on the dir with this module and define the width & height and its filename in the variables below.
                    ; You can also set the color of the background
                    ; If you use Esc as your exit_emulator_key, set EscClose to true. The emu closes faster if you don't use Esc, and this value doesn't seem to matter if you use Win7
                    ; VPinMame uses the registry to store configs @ HKEY_CURRENT_USER\Software\Freeware\Visual PinMame
                    ; Each time a new table is ran, it pulls the default configs into a new folder in the registry
                    ; Visual Pinball stores settings in the registry @ HKEY_USERS\S-1-5-21-440413192-1003725550-97281542-1001\Software\Visual Pinball
                    StartModule()
                    FadeInStart()
                    EscClose := IniReadCheck(settingsFile, "Settings", "EscClose","false",,1) ; This fixes VP from crashing (in WinXP) on exit when using Esc as your exit key.
                    showDMD := IniReadCheck(settingsFile, "Settings", "ShowDMD","true",,1)
                    updateDefaultDMD := IniReadCheck(settingsFile, "Settings", "UpdateDefaultDMD","true",,1) ; Set this to true if you want the script to set the default position of the DMD on next run.
                    dmdX := IniReadCheck(settingsFile, "Settings", "DMDX","45",,1) ; Your new default X position of the DMD
                    dmdY := IniReadCheck(settingsFile, "Settings", "DMDY","35",,1) ; Your new default Y position of the DMD
                    dmdWidth := IniReadCheck(settingsFile, "Settings", "DMDWidth","300",,1) ; Your new default DMD Width
                    dmdHeight := IniReadCheck(settingsFile, "Settings", "DMDHeight","75",,1) ; Your new default DMD Height
                    validateDMDLaunch := IniReadCheck(settingsFile, "Settings|" . romName, "ValidateDMDLaunch", "false",,1)
                    ; Update default DMD position & size so when new tables are ran, they use the new defaults
                    If ( updateDefaultDMD  = "true" ) {
                        dmdXcur := ReadReg("dmd_pos_x")
                        dmdYcur := ReadReg("dmd_pos_y")
                        dmdWcur := ReadReg("dmd_width")
                        dmdHcur := ReadReg("dmd_height")
                        If ( dmdXcur != dmdX or dmdYcur != dmdY or dmdWcur != dmdWidth or dmdHcur != dmdHeight ) {
                            WriteReg("dmd_pos_x",dmdX)
                            WriteReg("dmd_pos_y",dmdY)
                            WriteReg("dmd_width",dmdWidth)
                            WriteReg("dmd_height",dmdHeight)
                    Run(executable . " /exit /play -""" . romPath . "\" . romName . romExtension . """",emuPath, "Min") ; hide does not work
                    WinWait("Preparing Table AHK_class #32770")
                    WinWaitClose("Preparing Table AHK_class #32770",,4)
                    Sleep, 500
                    ; script to look for Please answer window, selects Yes I am and hits enter to continue loading table
                    Loop {
                        Sleep 50
                        IfWinExist, Please ; Nag screen the first time a table is ran
                        {    WinActivate, Please
                            IfWinActive, Please
                            {    SetControlDelay -1
                                ControlClick, Button2, Please answer AHK_class #32770 ; Click Yes I am
                                ControlSend, Button1, {Enter}, Please answer AHK_class #32770 ; Click the OK button
                        } Else ifWinExist, Game Info ; unknown window
                        {    WinActivate, Game Info
                            IfWinActive, Game Info
                            {    Send {Enter}
                                Send {Enter}
                        } Else ifWinExist, Notice ; sound not 100% acurate
                        {    WinActivate, Notice
                            IfWinActive, Notice
                            {    Send {Enter}
                                Send {Enter}
                        } Else ifWinExist, VBScript ; all msg boxes from vp script (like vb/vpm version not high enough...)
                        {    WinActivate, VBScript
                            IfWinActive, VBScript
                            Send {Enter}
                        } ;Else IfWinExist, Error ; serious errors - like z buffer too small and so on
                            ; we have some error and we want to see it so we don't send Enter
                            ; Send {Enter}
                            ; Gui, Destroy
                            ; WinActivate, Error
                            ; WinWaitActive, Error
                            ; WinWaitClose, Error
                            ; WinClose, ahk_class VPinball
                            ; Process, WaitClose, %executable%
                            ; ExitModule()
                        IfWinExist, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
                            IfWinActive, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
                                Break
                    Sleep, 500
                    WinWait("ahk_Class VPPlayer")
                    Sleep, 500
                    Loop {
                        IfWinActive, ahk_class VPPlayer
                            Break
                        WinActivate, ahk_class VPPlayer
                        Sleep, 50
                    WinWaitActive("ahk_class VPPlayer")
                    Sleep, 1000
                    ; Give focus to the dmd so it appears on top of the playfield
                    If showDMD = true
                    {    DetectHiddenWindows, off ; don't detect dmd if it is hidden
                        WinActivate, ahk_class MAME
                        If validateDMDLaunch = true
                            WinWaitActive("ahk_class MAME",,2)
                        ControlClick,, ahk_class MAME ; clicking the dmd to set the WS_EX_TOPMOST parameter (AlwaysOnTop)
                        DetectHiddenWindows on
                    FadeInExit()
                    Process("WaitClose",executable)
                    7zCleanUp()
                    FadeOutExit()
                    ExitModule()
                    ReadReg(var1) {
                        RegRead, regValue, HKEY_CURRENT_USER, Software\Freeware\Visual PinMame\default, %var1%
                        Return %regValue%
                    WriteReg(var1, var2) {
                        RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Freeware\Visual PinMame\default, %var1%, %var2%
                    CloseProcess:
                        FadeOutStart()
                        If escClose = true
                        {    DetectHiddenWindows, On ;Or next line will not work
                            Sleep, 50
                            ;ControlSend, Button1, q, ahk_class #32770
                            ControlSend, Button2, r, ahk_class #32770 ; in case q crashes VP, use this
                        ; If ( exe = vp8tag ) {
                        ; } Else {
                            Sleep, 150
                            WinHide, ahk_class VPinball ;This line fixes where the VP Window flashes real quick when closing the window for a cleaner exit
                            WinMinimize, ahk_class VPinball
                            WinClose("ahk_class VPinball")
                    Return
	05:32:47:185 | RL |      INFO  | +0     | BuildScript - Loaded Multi-Player scripts
05:32:47:185 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
05:32:47:185 | RL |      INFO  | +0     | BuildScript - "F:\RocketLauncher\Lib\User Functions\Global.ahk" not found
05:32:47:186 | RL |      INFO  | +0     | BuildScript - "F:\RocketLauncher\Lib\User Functions\Visual Pinball.ahk" not found
05:32:47:186 | RL |      INFO  | +0     | BuildScript - "F:\RocketLauncher\Lib\User Functions\Emulators\Visual Pinball 9.ahk" not found
05:32:47:186 | RL |      INFO  | +0     | BuildScript - "F:\RocketLauncher\Lib\User Functions\Visual Pinball\Emulators\Visual Pinball 9.ahk" not found
05:32:47:186 | RL |      INFO  | +0     | BuildScript - "F:\RocketLauncher\Lib\User Functions\Visual Pinball\Atlantis (Gottlieb).ahk" not found
05:32:47:187 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
05:32:47:187 | RL |      INFO  | +0     | Main - Module is built
05:32:47:187 | RL |      INFO  | +0     | CheckFile - Checking if F:\RocketLauncher\AutoHotkey.dll exists
05:32:47:189 | RL |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             AutoHotkey_H ANSI 32-bit
                    FileVersion                 1.1.13.00
                    InternalName                AutoHotkey_H
                    LegalCopyright              Copyright (C) 2003-2013
                    OriginalFilename            AutoHotkey.exe
                    ProductName                 AutoHotkey_H
                    ProductVersion              1.1.13.00
                    File Size:            802304 bytes
                    Modified:            9/7/2013 - 12:54:32 AM
05:32:47:190 | RL |      INFO  | +16    | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
05:32:47:190 | RL |      INFO  | +0     | Main - Running module
05:32:47:374 | MD |      INFO  | +N/A   | Module initialized
05:32:47:374 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
05:32:47:374 | MD |     DEBUG  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
05:32:47:374 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
05:32:47:374 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
05:32:47:375 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
05:32:47:375 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
05:32:47:375 | MD |     TRACE  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in F:\RocketLauncher\Settings\Visual Pinball\Games JoyIDs.ini under section [Atlantis (Gottlieb)]
05:32:47:376 | MD |      INFO  | +0     | LoadPreferredControllers - Started
05:32:47:376 | MD |     TRACE  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = 1
05:32:47:376 | MD |     TRACE  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
05:32:47:376 | MD |      INFO  | +0     | GetJoystickArray - Started
05:32:47:476 | MD |     TRACE  | +109   | GetJoystickArray - Joysticks Detected: 1000000000000000
05:32:47:478 | MD |      INFO  | +0     | GetJoystickGUID - Started
05:32:47:478 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: B04560BB2FEAE6118001444553540000
05:32:47:478 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (XBOX 360 For Windows) | MID: 045e | PID: 028e | GUID: B04560BB2FEAE6118001444553540000
05:32:47:478 | MD |      INFO  | +0     | GetJoystickArray - Ended
05:32:47:478 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 3.01|045e|028e|B04560BB2FEAE6118001444553540000
05:32:47:478 | MD |      INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
05:32:47:478 | MD |      INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
05:32:47:479 | MD |      INFO  | +0     | ChangeJoystickID - Started
05:32:47:479 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_028e&GUID_B04560BB2FEAE6118001444553540000
05:32:47:479 | MD |      INFO  | +0     | ChangeJoystickID - Ended
05:32:47:479 | MD |      INFO  | +0     | LoadPreferredControllers - Ended
05:32:47:479 | MD |      INFO  | +0     | CheckFile - Checking if F:\JoyToKey_en\JoyToKey.exe exists
05:32:47:480 | MD |     DEBUG  | +0     | CheckFile - Attributes:
                    FileDescription             Convert joystick input to keyboard/mouse input
                    FileVersion                 5.8.2.363
                    InternalName                JoyToKey
                    LegalCopyright              Copyright(C) JTK, 1999-2015
                    OriginalFilename            JoyToKey
                    ProductName                 JoyToKey
                    ProductVersion              Version 5
                    File Size:            1952768 bytes
                    Created:            2/3/2017 - 9:42:39 PM
                    Modified:            12/27/2015 - 10:33:02 AM
05:32:47:480 | MD |      INFO  | +0     | Keymapper - Loading joytokey
05:32:47:480 | MD |      INFO  | +0     | RunKeymapper - Started, using method "load"
05:32:47:480 | MD |      INFO  | +0     | GetJoystickArray - Started
05:32:47:506 | MD |     TRACE  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
05:32:47:508 | MD |      INFO  | +0     | GetJoystickGUID - Started
05:32:47:508 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: B04560BB2FEAE6118001444553540000
05:32:47:508 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (XBOX 360 For Windows) | MID: 045e | PID: 028e | GUID: B04560BB2FEAE6118001444553540000
05:32:47:508 | MD |      INFO  | +0     | GetJoystickArray - Ended
05:32:47:508 | MD |     TRACE  | +0     | RunKeymapper - Found your keymapper application here: "F:\JoyToKey_en\JoyToKey.exe"
05:32:47:508 | MD |     TRACE  | +0     | RunKeymapper - Looping through controllers to find joytokey profiles for each one
05:32:47:508 | MD |     TRACE  | +0     | GetProfile - Searching for these profiles (| delimited): F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Atlantis (Gottlieb)\Atlantis (Gottlieb)|F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Visual Pinball 9\Visual Pinball 9|F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Visual Pinball|F:\RocketLauncher\Profiles\joytokey\_Default\_Default
05:32:47:509 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Atlantis (Gottlieb)\Atlantis (Gottlieb).cfg
05:32:47:509 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Visual Pinball 9\Visual Pinball 9.cfg
05:32:47:509 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> F:\RocketLauncher\Profiles\joytokey\Visual Pinball\Visual Pinball.cfg
05:32:47:509 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> F:\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg
05:32:47:509 | MD |      INFO  | +0     | GetProfile - Loading Player 1 Profile -> F:\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg
05:32:47:509 | MD |      INFO  | +0     | RunJoyToKey - Started
05:32:47:509 | MD |      INFO  | +0     | WinClose - Closing: JoyToKey ahk_class TMainForm
05:32:47:740 | MD |      INFO  | +235   | Process - WaitClose JoyToKey.exe 2
05:32:47:743 | MD |      INFO  | +0     | Run - Running: F:\JoyToKey_en\JoyToKey.exe "F:\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg"
05:32:47:806 | MD |     DEBUG  | +62    | Run - "JoyToKey.exe "F:\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg"" Process ID: 3512
05:32:47:806 | MD |      INFO  | +0     | RunJoyToKey - Ended
05:32:47:806 | MD |      INFO  | +0     | RunKeymapper - Ended
05:32:47:806 | MD |     DEBUG  | +0     | fadeInTransitionAnimation: LegacyFadeInTransition
05:32:47:806 | MD |     DEBUG  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
05:32:47:807 | MD |     DEBUG  | +0     | fadeLyr3Animation: DefaultFadeAnimation
05:32:47:807 | MD |     DEBUG  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
05:32:47:807 | MD |     TRACE  | +0     | CustomFunction.Init - Starting
05:32:47:807 | MD |     TRACE  | +0     | CustomFunction.Init - Ending
05:32:47:807 | MD |      INFO  | +0     | StartModule - Started
05:32:47:807 | MD |      INFO  | +0     | StartModule - MEmu: Visual Pinball
                    MEmuV: v8.1.1 & v9.12
                    MURL: http://sourceforge.net/projects/vpinball/
                    MAuthor: djvj
                    MVersion: 2.0.1
                    MCRC: 86821212
                    iCRC: 5089D1EC
                    MID: 635038268932497719
                    MSystem: Visual Pinball
05:32:47:807 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Visual Pinball"
05:32:47:807 | MD |      INFO  | +0     | LocaleUtils.i18n - Started
05:32:47:808 | MD |     DEBUG  | +0     | LocaleUtils.i18n - Section "English_United_States" & key "dialog.open" not found, trying section "English"
05:32:47:808 | MD |      INFO  | +0     | LocaleUtils.i18n - Ended, using "Open" for "dialog.open"
05:32:47:808 | MD |      INFO  | +0     | LocaleUtils.i18n - Started
05:32:47:808 | MD |     DEBUG  | +0     | LocaleUtils.i18n - Section "English_United_States" & key "dialog.start" not found, trying section "English"
05:32:47:808 | MD |      INFO  | +0     | LocaleUtils.i18n - Ended, using "Start" for "dialog.start"
05:32:47:809 | MD |      INFO  | +0     | PluginInit - Started
05:32:47:809 | MD |     DEBUG  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating
05:32:47:809 | MD |      INFO  | +0     | CheckFile - Checking if F:\HyperSpin\Databases\Visual Pinball\Visual Pinball.xml exists
05:32:47:810 | MD |     DEBUG  | +0     | CheckFile - Attributes:
                    File Size:            82046 bytes
                    Created:            2/7/2017 - 10:25:00 PM
                    Modified:            2/10/2017 - 6:28:51 PM
05:32:47:810 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
05:32:47:810 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Name
05:32:47:810 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "Atlantis"
05:32:47:810 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Cloneof
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Cloneof
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Publisher
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Publisher" with a value: "Bally"
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Year
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Year" with a value: "1975"
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Genre
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Pinball"
05:32:47:811 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
05:32:47:812 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)"
05:32:47:812 | MD |     TRACE  | +0     | PluginInit - GameInfo:
                    GameInfo Label: Genre | GameInfo Value: Pinball
                    GameInfo Label: Name | GameInfo Value: Atlantis
                    GameInfo Label: Publisher | GameInfo Value: Bally
                    GameInfo Label: Rating | GameInfo Value: HSRS - GA (General Audience)
                    GameInfo Label: Year | GameInfo Value: 1975
05:32:47:812 | MD |     DEBUG  | +0     | BuildDatabaseTable - Ended
05:32:47:813 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
05:32:47:813 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: F:\HyperSpin\Media\Visual Pinball\Images\Wheel\Atlantis (Gottlieb).png
05:32:47:813 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: F:\HyperSpin\Media\Main Menu\Images\Wheel\Visual Pinball.png
05:32:47:813 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: System Logo | Asset Path1:  F:\HyperSpin\Media\Main Menu\Images\Wheel\Visual Pinball.png | Asset Extension1:  png | Asset Type1:  system
05:32:47:813 | MD |      INFO  | +0     | BuildAssetsTable - Ended
05:32:47:813 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
05:32:47:813 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Artwork1: F:\HyperSpin\Media\Visual Pinball\Images\Artwork1\Atlantis (Gottlieb).png
05:32:47:814 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Box Art: F:\HyperSpin\Media\Visual Pinball\Images\Artwork2\Atlantis (Gottlieb).png
05:32:47:814 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Cartridge: F:\HyperSpin\Media\Visual Pinball\Images\Artwork3\Atlantis (Gottlieb).png
05:32:47:814 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Flyers: F:\HyperSpin\Media\Visual Pinball\Images\Artwork4\Atlantis (Gottlieb).png
05:32:47:814 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Letters: F:\HyperSpin\Media\Visual Pinball\Images\Letters
05:32:47:872 | MD |     DEBUG  | +63    | BuildAssetsTable - Searching for a Other: F:\HyperSpin\Media\Visual Pinball\Images\Other
05:32:47:874 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: Letters | Asset Path1:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
                    Asset Label: Letters | Asset Path2:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
                    Asset Label: Letters | Asset Path3:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
                    Asset Label: Letters | Asset Path4:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
                    Asset Label: Letters | Asset Path5:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
                    Asset Label: Letters | Asset Path6:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
                    Asset Label: Letters | Asset Path7:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
                    Asset Label: Letters | Asset Path8:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
                    Asset Label: Letters | Asset Path9:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
                    Asset Label: Letters | Asset Path10:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
                    Asset Label: Letters | Asset Path11:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
                    Asset Label: Letters | Asset Path12:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
                    Asset Label: Letters | Asset Path13:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
                    Asset Label: Letters | Asset Path14:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
                    Asset Label: Letters | Asset Path15:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
                    Asset Label: Letters | Asset Path16:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
                    Asset Label: Letters | Asset Path17:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
                    Asset Label: Letters | Asset Path18:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
                    Asset Label: Letters | Asset Path19:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
                    Asset Label: Letters | Asset Path20:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
                    Asset Label: Letters | Asset Path21:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
                    Asset Label: Letters | Asset Path22:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
                    Asset Label: Letters | Asset Path23:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
                    Asset Label: Letters | Asset Path24:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
                    Asset Label: Letters | Asset Path25:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
                    Asset Label: Letters | Asset Path26:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
                    Asset Label: Letters | Asset Path27:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
                    Asset Label: Letters | Asset Path28:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
                    Asset Label: Letters | Asset Path29:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
                    Asset Label: Letters | Asset Path30:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
                    Asset Label: Letters | Asset Path31:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
                    Asset Label: Letters | Asset Path32:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
                    Asset Label: Letters | Asset Path33:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
                    Asset Label: Letters | Asset Path34:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
                    Asset Label: Letters | Asset Path35:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
                    Asset Label: Letters | Asset Path36:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
                    Asset Label: Letters | Asset Path37:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
                    Asset Label: Letters | Asset Path38:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
                    Asset Label: Letters | Asset Path39:  F:\HyperSpin\Media\Visual Pinball\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
                    Asset Label: Other | Asset Path1:  F:\HyperSpin\Media\Visual Pinball\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
05:32:47:874 | MD |      INFO  | +0     | BuildAssetsTable - Ended
05:32:47:874 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
05:32:47:874 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Video: F:\HyperSpin\Media\Visual Pinball\Video\Atlantis (Gottlieb).*
05:32:47:875 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Video: F:\HyperSpin\Media\Main Menu\Video\Visual Pinball.*
05:32:47:875 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
                    Asset Label: Game Video | Asset Path1:  F:\HyperSpin\Media\Visual Pinball\Video\Atlantis (Gottlieb).mp4 | Asset Extension1:  mp4 | Asset Type1:  game
                    Asset Label: System Video | Asset Path1:  F:\HyperSpin\Media\Main Menu\Video\Visual Pinball.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
05:32:47:875 | MD |      INFO  | +0     | BuildAssetsTable - Ended
05:32:47:876 | MD |      INFO  | +0     | PluginInit - Ended
05:32:47:876 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Atlantis (Gottlieb)
05:32:47:876 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Started
05:32:47:893 | MD |     DEBUG  | +31    | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,
05:32:47:893 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 1 check
05:32:47:893 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Post loop 2 check
05:32:47:893 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
05:32:47:894 | MD |     DEBUG  | +0     | XHotkeyTableCreation - Ended
05:32:47:894 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "F:\HyperSpin\HyperSpin.exe"
05:32:47:894 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "F:\HyperSpin\HyperSpin.exe"
05:32:47:895 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball\Atlantis (Gottlieb).ini"
05:32:47:895 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball.ini"
05:32:47:896 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "F:\RocketLauncher\Modules\Visual Pinball\Visual Pinball.ini"
05:32:47:897 | MD |      INFO  | +0     | StartModule - Ended
05:32:47:898 | MD |      INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
05:32:47:898 | MD |     TRACE  | +0     | CustomFunction.PreStart - Starting
05:32:47:898 | MD |     TRACE  | +0     | CustomFunction.PreStart - Ending
05:32:47:898 | MD |     DEBUG  | +0     | CoverFE - Started
05:32:47:929 | MD |      INFO  | +31    | FadeApp - Hiding Frontend by making it transparent
05:32:47:929 | MD |     DEBUG  | +0     | CoverFE - Ended
05:32:47:929 | MD |      INFO  | +0     | Module Setting - [Settings] - EscClose: false
05:32:47:929 | MD |      INFO  | +0     | Module Setting - [Settings] - ShowDMD: true
05:32:47:930 | MD |      INFO  | +0     | Module Setting - [Settings] - UpdateDefaultDMD: true
05:32:47:930 | MD |      INFO  | +0     | Module Setting - [Settings] - DMDX: 45
05:32:47:930 | MD |      INFO  | +0     | Module Setting - [Settings] - DMDY: 35
05:32:47:930 | MD |      INFO  | +0     | Module Setting - [Settings] - DMDWidth: 300
05:32:47:931 | MD |      INFO  | +0     | Module Setting - [Settings] - DMDHeight: 75
05:32:47:931 | MD |      INFO  | +0     | Module Setting - [Settings] - ValidateDMDLaunch: false
05:32:47:931 | MD |      INFO  | +0     | Module Setting - [Atlantis (Gottlieb)] - ValidateDMDLaunch: false
05:32:47:931 | MD |      INFO  | +0     | Run - Running: F:\Visual Pinball NEW\VPinball993.exe /exit /play -"F:\Visual Pinball NEW\Tables\Atlantis (Gottlieb).vpt"
05:32:47:964 | MD |     DEBUG  | +31    | Run - "VPinball993.exe /exit /play -"F:\Visual Pinball NEW\Tables\Atlantis (Gottlieb).vpt"" Process ID: 9784
05:32:47:964 | MD |     DEBUG  | +0     | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 2880 | Height: 1620 | Window HWND: 0x700a2 | Process ID: 12204 | Process Path: F:\RocketLauncher\RocketLauncher.exe
05:32:47:964 | MD |      INFO  | +0     | WinWait - Waiting for "Preparing Table AHK_class #32770"
05:32:49:994 | MD |     DEBUG  | +2032  | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.10 [ FE = HyperSpin 1.4 | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;3fefed45-68e0-47d0-b0f1-c0f022b1536f] | State: 1 | X: -11 | Y: -11 | Width: 1942 | Height: 1102 | Window HWND: 0x130bcc | Process ID: 11872 | Process Path: F:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
05:32:49:994 | MD |      INFO  | +0     | WinWaitClose - Waiting for "Preparing Table AHK_class #32770" to close
