JoeC3109 Posted February 11, 2017 Posted February 11, 2017 Hey everyone, I'm working through the process of getting NESiCAxLive setup through HS. I'm aiming to have each game launch separately from the HS database rather than opening the NESiCA launcher. The one problem I seem to be having is with controls; I am using the jconfig.exe fix, and setting the keys in there. However, for a good amount of games, it doesn't seem to be registering. For example, AquaPuzzle seems to take the keys I set there, while Battle Fantasia just ignores the jconfig settings. Has anyone had luck setting controls for these games? Thanks in advance
rastan Posted February 12, 2017 Posted February 12, 2017 I've been having issues with some of the games for a while now... as you mentioned certain games just don't seem to work with the control/settings at all. originally when I had issues setting up the controls for all games.. I jused the taito type x config and simply changed the file name to match the nesicaxlive games... not sure exactly what that did but when I went back into jconfig the controls seemed to work after that. I don't have any clue whats going on... as some games work perfectly with the controls (setup in Jconfig)... I know Battle Fantasia is definitely one of the games that I couldn't get the controls to work for but the thing with that game is I have it for Taito Type X and to be honest the only difference I noticed is the HD wide screen as there is a HD patch for the nesicaxlive games so Battle Fantasia looks better on nesicaxlive as far as it running beautifully in full screen. I gave up on trying to figure out what was going wrong with the control settings and just focused on the games that actually work 100%.. some other games work great with the controls but there were issues when exiting back to hyperspin. I find that some Taito Type X games and NesicaXlive games are best run outside of hyperspin for less headaches.
JoeC3109 Posted February 12, 2017 Author Posted February 12, 2017 Thanks for the input man. Actually got battle fantasia working last night, though it was a pain. There is a readme file that's included with the jconfig fix I found which actually lists each game and what it needs, though it doesn't always work. For Battle Fantasia, you basically need to run it with the TTX_monitor file and set your controls from there. I'm not sure if it uses jconfig at all. I'm aiming to try and get one game or so working a day, so it's gonna be a process. But you definitely find some tricks along the way that help
shitoken Posted February 25, 2017 Posted February 25, 2017 Some games you do not need jconfig at all. If you are using latest ALL Game Loader it will create ttxconfig 2.0 and you can use that , .Jconfig does not work with some games. I got all working with just one left which is pain in the ass cannot get it mapping with either of them. That is magical beats.
JoeC3109 Posted February 25, 2017 Author Posted February 25, 2017 Really? That one works for me with jconfig, I'm in the same boat though. Have them all working except for one or two.
shitoken Posted February 27, 2017 Posted February 27, 2017 Really? That one works for me with jconfig, I'm in the same boat though. Have them all working except for one or two.You mean jconfig work with Magical Beat? I tried many times and ttconfig too. Cannot understand what heck went wrong.Tapatalk を使用して私の A0001 から送信
JoeC3109 Posted February 27, 2017 Author Posted February 27, 2017 Yea, not sure I have a good explanation. Think I just got lucky. Maybe try the newest version of RH loader?
rastan Posted February 27, 2017 Posted February 27, 2017 On 2/24/2017 at 11:04 PM, shitoken said: Some games you do not need jconfig at all. If you are using latest ALL Game Loader it will create ttxconfig 2.0 and you can use that , .Jconfig does not work with some games. I got all working with just one left which is pain in the ass cannot get it mapping with either of them. That is magical beats. do you know where i can find the latest version of All Game Loader RH? Tried google but haven't had any luck from a reliable source... links seem to be down or just suspect at best. I know I had the TTX laoder somewhere but I don't believe they are the same program and it's probably a older version.
