rvote
So I'm wondering if someone can help me understand, within RocketLauncherUI, what the difference is, execution and .ini wise, between clicking on the red rocket symbol (Launch selected game through RocketLauncher) and when clicking on the blue magnifying glass (Manually launch a game through RocketLauncher).
The reason being is I'm trying to get my Mattel Intellivision emulation setup for Hyperspin but when I try to launch a game via the rocket symbol I get the following error:   "Unable to load game from file".  Now if I select the blue magnifying glass symbol to manually select the game to launch through RocketLauncher the game loads up without a hitch.  I am able to run the games directly from the nostalgia .exe also so I believe I have everything configured properly.  As far as the module I chose to have associated with Intellivision emulation I chose the Nostalgia.ahk module.  I've audited/scanned the game roms first within the nostalgia emulator itself and then audited the roms from within RocketLauncherUI and everything checks out.  I'm thinking that when you select the rocket icon that rocketlauncher is looking at some .ini or setting of some sort that may be configured wrong whereas selecting the magnifying glass icon has you manually pointing to the specific game rom you wish to load.  Its also worth noting that when I try to launch a game from within Hyperspin I get the same "Unable to load game from file" dialog box appear followed by the Nostalgia 5.0 emulator UI appearing.  I've attached my Hyperspin log file for your perusal.  I appreciate any help/insights anyone can offer me. Thanks in advance
-Raymond-
log.txt
UPDATE:  I found the problem.  For whatever reason the file path to the Nostalgia.ahk module was not correct. Even though I set up the emulator from within RocketlauncherUI and chose the correct module for some reason HLUI did not place the subfolder that the module resided in into the .ini's module= path field.
Problem solved!
Your log says your not using rockerlauncher but hyperlaunch instead you have to change the path in settings.ini                          like so Hyperlaunch_Path=C:\Rocketlauncher\Rocketlauncher.exe
Thanks for your reply.  I saw that the log shows hyperlaunch instead of rocket launcher too.  Even though I found the cause of my games not loading I'll still edit the .ini file to point to rocketlauncher.  Thanks again for responding.
- Raymond -
