Strange issue button with TypeX and Nesica
shitoken
Hi Friends
I have changed to use  ALL Loader recently since it do the the job quite well without errors to launch the games.
But something I cant get solved with using this loader.
When I press the button 2 on my player one the games goes pause and mouse pointer comes out.
I tried disabling the hot keys and AERO from loader config but still have this problem.
If I run the games with ttx launcher as per previous old methods without using ALLGameloader it does not have this problem.
I am using ipac with default mame settings means button 2 is ALT.
Is this the problem with ALL Game Loader ?
Anyone have solution to this, thanks
That's a problem with using Alt, it's made to open that menu with some programs. I had the exact same problem, did a lot of searching and there's no way to disable it from doing that. Utimately what I did was put a different config on my X-Arcade Tankstick; basically I go into Mode 2, which doesn't use Alt, Control or shift just to avoid problems. I don't know much about the ipac, but I'm thinking you are going to need to change your config so alt is not involved.
Hi Joe
I have about 140 systems never had this problem.
I have tested with other loaders as per my above message and came to know now
This problem is  "ONLY" with ALL Game Loader 200% sure this is a bug for users who use decoders with default MAME keymapping inputs.
Other loaders work fine without conflicting with the ALT Button, I am using this loader because it can load all the games.
When I press the button same time fire/punch and pause and on top corner mouse point came out.
I don't have issue with buttons , if use old loader to launch type X or Nesica games.
